Question about StarTech.com StarView SV211K 2-port KVM Switch
Outlook express not receiving mail or opening attachments
When trying to open attachments even ones i've opened before i get this message: ''This file does not have a program associated with it for performing this action. Create association in the Folder Options Control panel.
Hope someone can help
Spanner321
    Problem Solver:
  • 11 Answers
Sounds like you need something to open the format of mail you are recieving ie winrar pdf adobe etc try downloading one of these and see if it works
Posted on Jan 24, 2009
  • jodieliddo Jan 24, 2009
    i had to reinstall my system once and had to ring up to get the pop3 server etc make sure you have all these setup
Can't send emails in Outlook Express
Save yourself alot of headaches and use a web-mail service like Gmail.
Oct 27, 2014 | Microsoft Outlook Express
Tip
Duplicate emails in Outlook Express?
When Outlook Express is configured for POP3 mail access it uses a file called pop3uidl.dbx to keep track of which message have been downloaded so that it can download only new messages. Sometimes this file becomes corrupted which results in the same messages getting downloaded again. So we will need a different copy of this file. Please do the following to recreate it:
- In Outlook Express click on Tools and Options.
- Click on maintenance tab.
- Click on Store folder button.
- It will open a small window with a path to the store folder.
- Copy the whole path.
- Click on start and Run.
- Click inside the run box and press Ctrl+V, it will paste the whole path we copied.
- Click on OK. It will open the store location.
- Close Outlook Express.
- In the folder that was opened, locate the pop3uidl.dbx file and right click on it and select rename.
- Rename that to pop3uidlold.dbx.
- Open Outlook Express and you will no longer receive any duplicate messages.
If you are using IMAP account, that can happen if your IMAP account is the default mail account and OE is configured to both open directly to the Inbox (which downloads headers automatically) and check for new messages when starting (which also downloads headers automatically). To stop the duplicates, simply choose one option or the other, but not both:
In Outlook Express click Tools > Options, then
1. Remove the check mark for When starting, go directly to my ‘Inbox’ folder
OR
2. Remove the check mark for Send and receive messages at startup.
If you already have duplicates showing, click Tools > Synchronize Account or Synchronize All.
on Nov 18, 2008 | Microsoft Outlook Express
I cannot open dbx files
If you cannot open the .dbx file, you need to have Outlook Express installed on your computer. Usually outlook Express is the default email client for Windows XP. http://www.dbxconverter.com/ you can try to use this link to get teh converter of .dbx files to .pst files that you can use and read using Microsoft Outlook (Third Party) or Windows Mail (default for Vista) Windows Live Mail(Windows 7).
Cheers!!
Sep 02, 2010 | Computers & Internet
Outlook Express Not Receiving Attachments From One Sender
  1. Open Outlook Express
  2. Click on Tools->Message Rules->Mail
  3. Check the Mail Rules and Blocked Senders tabs
This is just a preliminary check for anything that may be modified that could be causing your problem. Since the issue is with a specific sender, I would check there first.
Feb 27, 2009 | Microsoft Outlook Express
I'm unable to open .eml attachment in Windows Vista.
Here's some info: E-mail message saved by Microsoft Outlook or other e-mail program; may also contain an e-mail attachment, or file sent with the message. Note: If EML files will not open in Outlook Express, try the following:
  1. Open My Computer.
  2. Select Folder Options from the Tools menu.
  3. Click the File Types tab.
  4. Under Registered file types, select EML Outlook Express Mail Message, then click Advanced.
  5. Click Open, then click Edit.
  6. Type the following line in the "Application used to perform action" box:
    "C:\Program Files\Outlook Express\MSIMN.EXE" /eml:%1
  7. Click OK twice, then close the window.
EML files may also be opened in Internet Explorer since they are formatted the same as .MHT files; changing the file extension from ".eml" to ".mht" should cause the file to open directly in Internet Explorer.
Hope this helps.
Dec 25, 2008 | Computers & Internet
Can't Open Attachments In Outlook Express
If you cannot open attachments while using the Outlook Express e-mail client, your security settings may be too high. When you try to open attachments, you may see the following message: “OE removed access to the following unsafe attachments in your mail.”
To check your e-mail security settings:
1. Open Outlook Express.
2. Click on Tools in the menu, and scroll down to Options.
3. Click on the Security tab.
4. Make sure “Do not allow attachments to be saved or opened that could potentially be a virus” is UNCHECKED.
5. Click on the Apply button. Click on OK.
You should now be able to open attachments.
Sep 30, 2008 | Computers & Internet
Attachments to E-mail won't come up
Turn Off Attachment Blocking in Outlook Express 6.1 SP1 Introduction Many viruses are transmitted through files attached to e-mail messages. For this reason, blocking of attachments is now a standard feature of many e-mail programs, including Outlook Express 6.1 SP1. Attachment blocking has been available in Outlook Express for some time, but it is now turned on by default.
When using Outlook Express to read your e-mail, you may notice a yellow message stating: “OE removed access to the following unsafe attachments in your mail: filename(s).” Please note that the attachment is still included in the message, you simply cannot access it because of a security restriction that can be turned off. These instructions explain how to turn off this restriction.
Procedure
  1. In Outlook Express, select the Tools menu, and click Options.
  2. Select the Security tab, clear the Do not allow attachments to be saved or opened that could potentially be a virus check box, and click OK.
  3. You should now have access to all attachments in your e-mail messages. Remember, you should never open an attachment unless you are certain it does not contain a virus. It is recommended that you save the file first, and then open it from the saved location.
Jul 26, 2008 | Gateway Computers & Internet
Outlook express
dear fando,
This is usually down to a corrupt or over-full email inbox. Outlook Express is not very good at holding large amounts of emails especially if they have large attachments. I had a user this morning with a 2.5 GB inbox.
Backup/rename Inbox (C:\Documents and Settings\(User)\Local Settings\Application Data\Identities\{GIU}\Microsoft\Outlook Express\inbox.dbx -> inboxbak.dbx).
Outlook Express will have created a whole new Inbox.
Your email should now work.
Best wishes.
Jan 04, 2008 | Audio Players & Recorders
Winmail to Outlook express 6
Outlook Express does not display any message attachments if TNEF-encoded file (winmail.dat) was received. If you are expecting some attachment, but do not see any, it still can be there.
To decode such a message perform the following steps:
  1. Save the whole e-mail message to an *.EML file via File, Save As, or Drag-and-drop.
  2. Open the *.EML file in a text editor such as Wordpad or Notepad.
  3. Locate the line Content-Type: application/ms-tnef;, and change the Content subtype to something else, such as Content-Type: application/zzz;
  4. Locate the line name="winmail.dat" and change to name="winmail.tnf". You may change the winmail part as well, if desired.
  5. Save the *.EML file from the text editor.
  6. Double click the *.EML file from the Windows File Explorer. This will open the message in a mail window and the TNEF attachment should now be available for saving.
  7. Drag the saved attachment into the Winmail Opener program. Decoded attachments will then be there and can be dragged or opened.
Dec 07, 2007 | Microsoft Office Outlook 2003 for PC
StarTech.com StarView SV211K 2-port KVM Switch Logo
Top StarTech.com Computers & Internet Experts
Alun Cox
mbowen171
mbowen171
Are you a StarTech.com Computer and Internet Expert? Answer questions, earn points and help others
