Question about Minolta C350 Color Printer/Scanner/Copier
MINOLTA C350 ERROR CODE C0200 - Minolta C350 Color Printer/Scanner/Copier
  • Minolta Master
  • 6,359 Answers
Cyan image unit replace it. Reset code by opening and closing the front door. Also try reseating it.
Posted on Feb 08, 2015
4 Suggested Answers
jqsababa967
  • 145 Answers
SOURCE: C0200
CHECK YOUR CARONA AND CARONA BLOCKS,
Posted on Oct 04, 2008
goalie39
  • 469 Answers
SOURCE: error code c0200 minolta ep4050
C0200, charge corona failure.
The high voltage wire used to charge the photo-conductive drum is broken or shorted.
It will need to be repaired or replaced.
It is usually a fairly simple job, but you may need the replacement wires to complete the job.
It could be someone has pressed the scoritron grid tensioner and allowed the grid to drop onto the drum.
Great care must be taken when working around the drum area.
If you open the front of the machine.
drop down the transfer section (yellow or green handle)
flip out the toner bottle.
you should see to recessed screws, one behind the toner bottle, one on the far right side of the unit. loosen these all the way,
there may be a plug in each side to disconnect.
you should now be able to slide the unit out.
set it down in some paper, the corona will be the long metal housing stretching front to back on the drum unit.
Remove it by sliding it one way, then it should open like a hinge, open it all the way and it should pop loose of the main unit.
The corona wire is behind the grid, it is the thickness of a human hair. If it is broken you will need a replacement, if the grid was off when you opened the unit up reinstall the grid and reassemble.
If the corona shell or the scoritron is discolored, clean them with a glass cleaner and soft cloth.
Keep the drum covered with paper so it is not exposed to direct light for any great length of time, do not allow the drum to be exposed to direct sunlight.
Hope this is of some help.
Ed
Posted on Apr 19, 2009
firecontrol7
  • 6359 Answers
SOURCE: Konica Minolta C350 colour copier T096 error code??
Transfer belt code C096 mite try open and closing the front door where you put the toner. Also remove the image transfer belt and then reseat it.
Posted on Jul 19, 2009
How to remove error C0200 on bizhub c350?
C0200 - Cyan PC Drum Charge Corona Malfunction. Did you mess with this imaging unit? You won't be able to reset if the malfunction is still present.
Konica Minolta Error Codes & Solutions - http://www.kmcodes.com
Drum, Transfer Belt and Fusing Unit Firmware Reset - http://www.bizhubreset.com
Drum and Toner Chip Reset - http://www.chipreset.eu
Transfer Belt and Fusing Unit Reset Kit - http://www.resetkit.eu
Aug 15, 2014 | Konica Minolta Office Equipment & Supplies
How to remove error C0200 on Minolta bizhub c350?
Error code c0200 minolta EP 4000
Sir, right below the drum area when you open the machine front door is a assy. with two very fragile gold plated wires that transfer the image from the drum to the paper. The paper moves over this wires during the copy process. They mite have broken giving you a C0200. Or the same type of wires are above the drum on the drum unit which must be removed to see them mite be bad. did you open close the front door to see if the machine will reset?
Jun 25, 2014 | Minolta EP4000/5000 CS/PRO Copier
Error code c0200
The error code C0200 deals with the transfer or separation charge corona wires. I would replace the two wires and see what happens. The code can not be rest till the problem is fixed. Good Luck
Nov 08, 2013 | Minolta EP4000/5000 CS/PRO Copier
Konica minolta bizhub c350 error codes c-0510
eror code c-0098 meaning ??????????????pls tell me the solution
Jul 31, 2012 | Konica Minolta Bizhub C350 Digital Copier,...
Apr 10, 2009 | Minolta Office Equipment & Supplies
Minolta EP 2050 copier
C0200: PC Drum Charge, Image Transfer/Paper Separator Coronas Malfunction.
Most probably a broken corona wire. It can also be caused by dirty coronas wich can be washed with water and soap and dry them well. If the problem persistes must look for the conections and HV1, wich suplies the coronas. GOOD LUCK.
Oct 31, 2008 | Minolta EP4000/5000 CS/PRO Copier
Malfunction code C0200
A C0200 is a Charge Corona problem and it is a Minolta error code.
Jan 23, 2008 | Office Equipment & Supplies
357 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
