Question about Goldstar Heating & Cooling
Supply me with card # PWB6870A20012A, ASM 6871A10041 for a 260000btu air con,,indicate price..CIF Zambia
AIR CON RUNS ON 3PHASE
SOURCE: My Blueway air con is not cooling , fan works but is not cooling
More than likely the capacitor is bad internally
Posted on Jan 21, 2009
notsomot
  • 67 Answers
SOURCE: Remote Control Unit-Fujitsu Air Con. Model:AR-DL1 is broken.
If you contact Fujitsu in your country and you will be able to buy it straight from them, if they are still available. Now I have to warn you as a Fujitsu warrenty agent they are very very expensive.
I would prolly recommend getting a universal remote. ALOT cheaper
Posted on Jan 23, 2009
SOURCE: LG AIR CON - thermistor fails
Yes - I've got the same problem too. Unit is less than 6 months old, so not happy!
Posted on Jun 17, 2010
bobotfel
  • 236 Answers
SOURCE: AIR CON REMOTE CONTROL NOT WORKING
replace your receiver board it may be defective.
Posted on May 16, 2008
  • 415 Answers
SOURCE: TECO AIR CON SYSTEM MANUAL
Perhaps the manufacturer can assist you with obtaining an electronic copy. Try this link:
http://www.teco.com.au/component/tecofaq/?search=show&task=showcatid&from=browse&divisionname=+Household+Appliances&categoryname=Air+Conditioning
Posted on Feb 25, 2010
What is the best size kw. ANY BRAND Air Con is Equivalent to suit Air Con : Conia Air Con Model : CA242 S/N:ca24220970353
KW is not the number that you need to be concerned with. The newest rating for HVAC is called SEER. If yours is older it might be listed as TON.
Dec 09, 2016 | Heating & Cooling
The unit does not run and the display indicates "EH"....What does this mean?
EH is emergency heat. It could be the thermostat is not set of configured properly. Find the instructions and wiring diagrams for both the thermostat and the air-con to double check wiring of the thermostat to the air-con
Oct 10, 2015 | Heating & Cooling
Mercedes E300 Elegance. 1998 model. Intermittent supply to magnetic clutch on air conditioner pump. I have taken temporary supply from cigarette lighter socket. and air conditioner works fine. What can be...
You seem to have a bad connection between the air con switch and the clutch. trace the wiring backwards from the clutch to the air con switch. A wire or connection may be corroded, damaged or chafed.
Aug 28, 2013 | Sony 4.72" x 2001' Wax/Resin, TR4085plus...
I have a Nissan Navara after service in Zambia to my regret it heats up now when put air con on how can I get this problem fixed. Thanks Dinah
Did they bleed the cooling system of air that must be done. What kind of shop was this, oh Zambia that answers my question.
Oct 18, 2012 | 2008 Nissan Navara 2.5
My car's air-con (Tuczon 2007) suddenly stopped thrice! First time (only after 1 year) brought it to a service center and told me its relay just needed cleaning. 2nd time same thing; 3rd time told me...
Hello! You can search replacement part on eBay
Here link for example https://www.ebay.com/sch/i.html?_from=R40&_trksid=p2050601.m570.l1313.TR0.TRC0.H0.Xtucson+2007+air+con+swich.TRS0&_nkw=tucson+2007+air+con+swich&_sacat=0
Jun 19, 2017 | 2007 Hyundai Tucson Limited
My air con is not working.it has gas in the system,relay is ok,air con switch is ok but the air con compressor does not turn on when air con is on.when you direct the compressor or brigde the relay,the...
You may have freon in system but compressor won't engage unless it's full under pressure. By jumping the the relay you're doing damage to compressor by running on low pressure. Have system evacuated and recharged to proper amount of freon - usually 4 lbs of freon
Jan 30, 2011 | 1994 Hyundai Excel
Air con fan works but no cool air the compressor doesn't appear to start
It may need regassing, air con runs out after a while as its 2005 it most likely needs to be regassed/refilled!
Jan 14, 2010 | 2005 Ford Futura
My 1997 cadillac sts idles very rough
if it idles rough when air con is turnd on ur idle my be running to low to start with the air con is a pump and will take power from the engine and wen u turn on ur air con there is a clutch on ur pump witch engages witch will couse the revs to drop
Apr 26, 2009 | 1991 Cadillac DeVille
May 12, 2008 | LG Art Cool LA121CNP wall/window Air...
Heating & Cooling Logo
80 people viewed this question
Top Goldstar Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you a Goldstar Heating and Cooling Expert? Answer questions, earn points and help others
