Amazon basics mouse driver - Computers & Internet
Free driver download for logic world precision optical mouse
world precision throwing me off
according to amazon
logic world mouse of any type
dont require a driver
if USB computer should automatically pick up the driver
check device manager and see what mouse driver is being used
if wireless .......even if you .have you lost the driver disc
computers will recognize the usb plug
Mar 31, 2017 | Optical Mouse Computers & Internet
I have a dell precision m4400 and the mouse has a mind of its own where I have no control over it through the touchpad or using an external mouse,
Boot it to safe mode and see if the problem goes away. If it does then it may be a driver issue, if it does not then take a q-tip and wipe all the way around the edge of the screen. Then reboot and try again.
Feb 13, 2016 | Dell Precision M4400 Notebook
Mouse idles, takes a full second to "wake up."
Hi. Normally gaming mouses can come with some software that will help fix that issue and make it more comfortable to use but as we all know this is not a gaming mouse. It sounds like the optical sensor ( bottom of the mouse) is either dirty or may just be bad. I have looked up the mouse and overall it has a lot of bad reviews. A lot say the mouse dies in 1 month. My best suggestion is to return it if you can and get a better one.
Some ideas - ( around your budget )
http://www.amazon.com/E-3lue-E-Blue-2-4GHz-Wireless-Optical/dp/B00DPC015E/ref=sr_1_sc_1?s=electronics&ie=UTF8&qid=1391198620&sr=1-1-spell&keywords=gamgin+mouse
http://www.amazon.com/E-3lue-2500DPI-Optical-Black-Gray-EMS140/dp/B0095ONNTC/ref=sr_1_sc_2?s=electronics&ie=UTF8&qid=1391198675&sr=1-2-spell&keywords=gamgin+mouse
http://www.amazon.com/dp/B00F3L19KQ?psc=1
Hope this helps. let me know what happens!
Jan 31, 2014 | INLAND PRODUCTS INC MICE WIRE OPTICAL USB...
Why can't I get a new usb mouse and keyboard to work on a very old Win98SE system that has working usb ports, but the old mouse and keyboard were ps2 connection?
You need to go to the manufacturer of both the keyboard and the mouse web sites and download the windows 98 drivers for both of them and install them.
Jun 28, 2012 | Computers & Internet
I have a Microsoft Wireless Notebook Optical Mouse 3000 which was working yesterday but is now not responding. The red LED on the bottom of the mouse is flashing, but the green LED on the USB receiver only...
you might have to uninstall the mouse then restart your computer then reinstall the mouse and its drivers
make sure the battery is good (has full charge)also you might test the usb device for the mouse is inserted correctly into the usb port (if applicable)
click start control panel mouse you should see 4 tabs buttons,pointers,pointer options and hardware under hardware you can troubleshoot also you can select properties under driver you will have options to update driver,rollback driver or uninstall and under hardware you can troubleshoot
in xp
hope this helps
Feb 01, 2011 | Microsoft Wireless Notebook Optical Mouse...
Drivers without having to use Driver Det.
keeping it simple-- all mice load with windows drivers first so if your mouse is not working in the most basic mode on multiple pcs the nthe mouse is dead. contact logitech for out of warranty credit.
Jul 16, 2009 | Labtec Mini Wireless Optical Mouse...
Mousse isn't working on desk top dell
is that a wireless mouse oe a wired mouse?
May 02, 2009 | Dell Dimension 8400 PC Desktop
The laser mouse jumps all over the screen
Are you using a mouse pad. Try turning it over.
Basically if you have a shiny surface below the mouse, it will behave this way.
Mar 18, 2009 | Computers & Internet
My wireless mouse is not working and im trying to download free software
hi you need to check two basic things. first that either mose is not working properly or driver of that. try to re install the mouse driver and also plug your mouse in another system to check that mouse is ok or not
Mar 02, 2009 | Logitech 9311570403 Mouse
Computers & Internet Logo
3,103 people viewed this question
David Payne
David Payne
