Question about Baumatic Ovens
Got a baumatic oven not working ,fans working model no bo612bl
The oven just stopped ,fan his wqrking but not the oven
SOURCE: Baumatic oven not heating up
Hi Damien,
Many thanks for your help - unfortunalty have tried this and it dosent work... BOO
Thanks,
Chris
Posted on Mar 29, 2008
barkencoa
  • 3463 Answers
SOURCE: fan oven not heating up
If fan is working then the element has probably gone
Posted on Nov 30, 2008
barkencoa
  • 3463 Answers
SOURCE: Baumatic fan assisted oven not heating up
The oven element has failed, you need to fit a new element.
It is a straight forward repair to do.
Remove inner rear panel of oven, you will see the round element at rear.
Unfasten element, detach wires, and fit new element.
Refit rear panel, and test.
Plz rate my solution.
Thanks.
Posted on Jan 24, 2009
SOURCE: Fan Oven blows Fuse over 175 Celcius -Baumatic BT2760SS
Hi, I was cooking and my oven jut went off, looked in fuse mains box and had tripped. So put back on and now the fan works but no heat...Can you give me some idea what it mite be.
Posted on Jul 23, 2009
SOURCE: No heat from oven but fan and light works
Timer might be blocked on auto, you need to get it back to a manual setting.
Posted on Oct 18, 2009
My Baumatic B180W-B oven does not heat up. The
If the oven is electrically heated, then more than likely, the oven element has failed.
This is located behind a removeable cover at the rear of the oven.
Feb 21, 2010 | Baumatic B187 Electric Single Oven
Baumatic oven not heating up. Grill and fan fine.
if it is the b180, the answer (having just fixed this) is really simple.
The coily bit is the oven element - it will have gone. A new one from eBay cost me about 6 quid.
[WHEN IT ARRIVES !]
Turn the power off.
Inside the oven use a philips screwdriver to remove the 4 screws (KEEP THEM !)
You will see a coily thing and a fan.
You unscrew 3 more screws (2 on the left and 1 on the right).
(KEEP THESE TOO!)
now ... bit tricky, have the new one inside the oven and take each wire off one at a time and put it on the new element.
Screw it back on but DONT put the last panel back in.
Turn the oven on maximum for about 2 minutes and see it glow red.
Turn the oven off. Make a cup of tea and have a couple of biscuits while admiring how good you are and waiting for the element to cool down!!!
Put the final panel back in place. Whole thing (including a cup of tea) takes about half an hour.
Jan 27, 2010 | Baumatic B180 Electric Single Oven
Oven does not heat up in fan oven mode but fan runs. works fine in convection mode. Baumatic B723SS-A
whilst the fan is running the heating element which is usually in parallel with it should heat.. This usually means a faulty element..
Dec 17, 2009 | Baumatic Ovens
Good evening i have a BT2431SS baumatic cooker,i have no heat in main oven yet i have the hob and the grill that work ok.
If it is a fan assisted electric oven, and the fan is wrking o/k, then it will probably be a faulty oven element.
This is located at the rear of the oven compartment behind a removeable cover.
Please rate my solution.
Thanks.
Nov 24, 2009 | Baumatic Ovens
Fan works but oven doesn't heat
Check at the terminals and look for burned wiring
Sep 24, 2009 | Ovens
Fan oven not heating up
Nov 29, 2008 | Baumatic B904SS Stainless Steel Electric...
No manual
The light bulb is the oven light.
The snowflake with 3 raindrops is Defrost Mode (fan runs with no heat to reduce defrost time)
The 2 lines up top & down bottom is Traditional Cooking (heat from top & bottom elements)
The big circle with a fan is the Fan forced Oven
The small line at top only is the Grill Mode
The larger line at top only is the Double Grill Mode
The line up top with the fan underneath is Double Grill with Fan mode
The line on the bottom with fan on top uses the lower element with the fan for delicate dishes
The manual can be found on the Baumatic website - www.baumatic.com.au - select your product which takes you into another page & you will see on the left hand side a link to "View User Manual"
Nov 11, 2008 | Baumatic B187 Stainless Steel Electric...
I have the same model steel finish was looking for parts mysel and came across yr dilema... I had that problem before . I always turn left knob to fan.. turn heat to whatever say 200 then click the button with the hand signal and i never touch any other button it alays does the job for me.. i cant cook so never need to touch ant other button ,,,, its a timer issue that stops it heating up swtch it all off at spur or mains start it up again
DamienPJennings@aol.com hope this helps
Jan 13, 2008 | Ovens
Ovens Logo
35 people viewed this question
Top Baumatic Ovens Experts
ashburton
Andy Fraser
Andy Fraser
Are you a Baumatic Oven Expert? Answer questions, earn points and help others
