HP Scanjet G3010 gives a blue/green band down side when scanning
HP Scanjet G3010 gives a blue/green band down the right hand side when I scan in colour. This doesn't happen when I scan in black and white. What am I doing wrong?
  • 2022 Answers
SOURCE: Yellow band when coping & scanning
this is problem with your scanner it is good if you can get servicing of your all in one printer
Posted on Sep 24, 2007
SOURCE: scanning document leaves streak down right hand side
Thanks for the tip...the problem is NOT a black line but a wide yellow line on the right side of the paper. It starts out about a quarter of the page in width and diminishes in size to about a half inch in width after many repeated scans.
The glass IS clean , and even when the glass had some smudges here and there, I never had a yellow stripe problem!
Scanner bulb is bright and even the entire length of bulb (no dark areas) so I don't think it is the bulb!
Posted on Dec 26, 2007
  • 2794 Answers
SOURCE: RICOH AFICIO 1022 ADF scanning with a black line down right-hand side
There is a tiny spec on the scanner glass. Cleaning it will make the line go away.
Posted on Jul 11, 2008
  • 859 Answers
SOURCE: How to scan slides with HP 1610
Will you help me help you with a little more information please?
Thanks. When you attempt a scan with your backlight setup are you able to instruct the scanner through its settings and options that you are using a transparency backlight at 6300K? If these options are there, what light temperature options do you have besides 6300 or is that the only one. And are your slides in standard tray or in a plastic jacket? A standard tray is a clamshell device where you lay your slides in frames and when done close and snap the clamshell closed.
Posted on Jan 04, 2009
  • 2120 Answers
SOURCE: 11 blue dots print out down the left hand side of documents
it sounds like the CYAN toner cartridge is leaking.
Posted on Jan 23, 2009
Cannot save in pdf format after scanning thru hp g3010 scanner using win7 pro
Hi abdul_haq779,
This problem couldd be resolved by printing the format that you get via your scanner for e.g. jpeg into pdf , by using a free pdf printer tool.
Once you have an image scanned via your scanner , you can just print the image in pdf mode.
May 10, 2011 | HP Scanjet™ G3010 Flatbed Scanner
Is it possible to set the scan area on a HP G3010 scanner? For example, set the area to be 8" by 11" ?
I have the same problem with a HP psc 1600. It always scans 8.5 x 11.69. Unless I manually crop each scanned page, the pdf output is put on legal size to accomodate the height greater than 11".
Sep 26, 2010 | HP Scanjet G3010 Flatbed Scanner
The scanned image consists of columns of red, purple and green.
i have same problem here. anyone help solve to me for this problem
Jun 18, 2010 | HP Scanjet™ G3010 Flatbed Scanner
HP Scanjet G3010 scans blue page always
check by changing the tonner of that printer.
check by reinstalling the drivers.
check its head.
Mar 02, 2010 | HP Office Equipment & Supplies
Slip adapter is part of the scanner ? How to use slip adapter to scan negative film ?
The film goes into the adapter and the adapter mounts on the underside of the lid.  Complete manual available free at
May 21, 2009 | HP Scanjet G3010 Flatbed Scanner
Installing HP Scanjet G3010
While installing the software, I registered my purchase with HP. It was quite some time before the confirmation eMail appeared which allowed me to follow a simple chain of links to troubleshoot the problem. It turns out that this device does not like being connected through a non-powered USB hub. The full problem description can be seen at...
Aug 28, 2008 | Office Equipment & Supplies
Reinstall you software for the scanner .
Jul 23, 2008 | HP Scanjet G3010 Flatbed Scanner
Negatives to pictures
The manual didn't show negative and slide support. I recommend you some of the hp products like HP Photosmart C7180 All-in-One, HP Scanjet G3010, HP Scanjet G4010, etc.
Feb 02, 2008 | Canon PIXMA MP150 All-In-One InkJet...
55 people viewed this question
