Question about BenQ E2200HD 21 inch LCD Monitor
BENQ E2200HD GOES ON SLEEP MODE AFTER 7MINS
MONITOR SLEEPS AFTER 7 MINS
4 Suggested Answers
jemmyrash
  • 180 Answers
SOURCE: Benq 24" wont comes back after sleep mode
Try to install the OS once again.
If it turn up the same again then it may be the logical board problem.
Posted on Apr 13, 2008
ag66339
  • 127 Answers
SOURCE: BenQ E2200HD monitor won't output sound
You do not have the necessary drivers installed. Go to the manufacturers website and download and install the recommended drivers.
Posted on Sep 22, 2009
  • 732 Answers
SOURCE: Benq E2200HD No Cable Connected!
mnk1001, Possible Failure of internal "switch-mode-power-supply"/ "CCFL inverter supply" of E2200HD. Will need to investigate to see if SMPS is in emergency shutdown mode. Please post back if you find out root cause of failure. 12fixlouie
Posted on Apr 11, 2010
BenQ G2400W power save mode works find with DVI but will not go into power save using HDMI cable.
Look on the remote find the button under menu then on the screen find sleep timer or power saber and turn off.
Terry
Jan 31, 2015 | BenQ G2400W Monitor
My computer goes into sleep mode when i turn it on
The computer is not going into sleep mode. it is a problem though. Your computer is not giving a video signal to the monitor and it is the monitor going into "Sleep mode".This could be any number of things -but an easy fix is to check your RAM and that your connections are all good. (not necessarily in that order).
Apr 19, 2013 | Packard Bell Computers & Internet
Windows sleep mode problems
Sleep mode on a Windows 7 PC saves power without you having to turn your computer off and without losing any work. This option cuts the power to your monitor, powers down the hard drive and pauses all functions until you awaken the computer from hibernation. Whether you have a laptop, desktop or workstation, putting your computer into sleep mode will lower your electric bill and save money! Click the "Start" button in the lower left corner of your desktop. In the lower right corner of the Start menu, next to the "Shut Down" button, is a button labeled with a small, right-pointing arrow. Mouse over the arrow. The Shut Down menu appears. Point at "Sleep" and click on this option. Your Windows 7 computer goes into sleep mode. Wake your computer from sleep mode by jiggling the mouse. There may be a delay of a few seconds before your hardware powers on. All of your open programs are still open and your work is intact, just as you left it before the computer entered sleep mode. Configure your Windows 7 PC to go into sleep mode automatically when it is not used for a certain amount of time. Click "Start" and select "Control Panel." Click "System and Security." Click "Power Options." A menu opens. Click on "Choose when the computer sleeps" and select the number of minutes of inactivity. You can also set a separate time interval to put your monitor into sleep mode. If you set both to 10 minutes, then your PC and monitor will automatically go into sleep mode after 10 minutes of inactivity
Dec 21, 2012 | Computers & Internet
I have my acer p205h 20 inch monitor hooked up to my tobshiba laptop and it works great except it will not go into sleep mode when laptop goes into sleep mode the monitor goes to there is not signal check...
Unfortunately, this is a standard problem, as when your laptop goes into sleep mode, it shuts off power to the secondary monitor, without giving it the signal to go into sleep mode. You could try digging around your settings, but most likely you'll just need to turn off the monitor when you're not using it.
Mar 01, 2011 | Acer P205H Widescreen LCD Monitor
When the CPU switch on, the system running upto 10 minutes. after that the monitor screen automatically off.
Here is artical I found on how to disable sleep mode on a monitor, this would be for VISTA or 7, if you are using XP it's a bit different. ____________________________________________________________ How to Disable Sleep Mode on a Monitor
Your computer monitor or laptop screen will enter sleep mode after your computer remains idle for a set period of time. You can disable sleep mode if you prefer the screen to remain illuminated. You merely need to change a setting in the Windows Power Management properties box.
Difficulty: Moderately Easy Instructions
  1. Click "Start" and "Control Panel".
  2. Click "System and Security" and "Power Options". This will bring up a new dialog box.
  3. Click the menus to the right of "Turn off the Display" and set them both to "Never". This will disable sleep mode.
Read more: How to Disable Sleep Mode on a Monitor ' eHow.com http://www.ehow.com/how_6953659_disable-sleep-mode-monitor.html#ixzz1CiGFFyLk
Feb 01, 2011 | Acer AL1916W 19" LCD Monitor
Screen Turn's on.You seen Acer load up Splash Screen for less then a min, Stay on until Windows Xp Load up screen then goes into sleep mode. Encontered same problem when I connected Xbox360 with HDMI to...
  • Hello chaleebradsh, the "Monitor" as well the Computer have "Power Saving Modes," [Sleep, ScreenSavers, and Hibernation]; so what you want to do is "Change the way the Computer / Monitor Sleeps!" From the Desktop Screen, click on the "Start Button," next in the [Start Search Window], type: power. In the next [window] that opens, you should see, from your point of view; a "list" in the (left column) "Change when the computer sleep, the wording may be different, but it will be clear enough. Now all you have to do is change the way the Computer and Monitor "Sleep, or Turn-off." If the Monitor have its own "settings;" just find them by the [button on the monitor], and do the same thing as above; but I'm sure the computer will take care of both. "I hope this information is of help; thanks for using FixYa, paul7of9"
Jan 31, 2011 | Acer AL1717 17" LCD Monitor
Apr 08, 2010 | BenQ E2200HD Monitor
Sep 21, 2009 | BenQ E2200HD Monitor
Apr 12, 2008 | BenQ FP92W LCD Monitor
BenQ E2200HD 21 inch LCD Monitor Logo
35 people viewed this question
Top BenQ Computers & Internet Experts
JP Services
JP Services
Tony
Tommmix
Level 1 Expert
Are you a BenQ Computer and Internet Expert? Answer questions, earn points and help others
