Question about Dirt Devil Featherlight Bagless Upright Vacuum
Dirt Devil Vision bagless not working
Hi
I cleaned my Dirt Devil Vision bottom brush and nothing blocking in white pipe also .
But my Dirt Devil Vision is not cleaning carper .
Let me know what to do about this .
  • Anonymous Mar 22, 2014
    height adjustment
  • 281 Answers
Make sure your brush roller is turning.unplug the vacuum and see if you can turn the brush roller by hand.if it turns real freely then your belt is more than likely broke
Posted on Apr 09, 2009
  • 294 Answers
Check the dirt cup filter. remove the dirt cup and check for proper suction. if you have good suction, check your belt
Posted on Jan 24, 2009
Hi I have a dirt devil vision. Hose works, but does not vacuuming the floor. Belts are not broken. Larger belt is moving, smaller belt that moves the brushes does not.
hi krueger, sorry for the problems but hers an idea how about turning on the vacuum and put your hand under the part where it sucks uo the dirt off the floor and i guessing you would have a little suction, since the brushes are not moving its going to not pick up as well as it should my guess is that the belts need to be replaced even if one is moving, i would change both belt to be sure and also are you smelling a burning smell if so then that would prove fact to needing new belts, hope this helps, Jamie
Dec 14, 2012 | Dirt Devil M086700 Vision Bagless Upright...
Hi my dirt devil vision vacuum is having problems. I turn it on and its sounds like its working, but it is not cleaning. Is there a quick fix?
Check there is no blockage in hose. If bagless check filter they clog up quickly I personally dislike bagless vacumns
Dec 18, 2009 | Dirt Devil M088905 Vision Bagless Upright...
How do I repalce the belt on Dirt Devil Swivel Glide upright vac?
Four screws hold the bottom plate in place. Turn the vac upside down and remove the screws that hold the cover(bottom plate) over the brush roll in place. Remove the plate and you are there.
Oct 22, 2009 | Dirt Devil M088910 Swivel Glide Vision...
Replacement of the belt instructions
should be just 2 screws by the beater brush, bottom front of the machine, pop them out and remove brush to remove hairs etc. put new belt in .
Jun 15, 2009 | Dirt Devil Vision Turbo W/Bonus Upright...
Changing the belt
there are 4 screws on the bottom 3 around the grid and 1 towards the back of the bottom plate.lift it off, but make sure you clean the old rubber off the motor shaft or your new belt won't last
Mar 01, 2009 | Dirt Devil M086700 Vision Bagless Upright...
Is there a reacll for the dirt devil ultra vision turbo bagless vacuum?
Go to the store and read the recall announcement.
Aug 25, 2017 | Vacuums
Dirt Devil Vibe No Suction
Sounds like there is a clog somwhere. Check the hose - you can undo the hose with a screwdriver but because of that bend use a pipe cleaner or a long wire to see if there is anything blocking the tube. Next check the dirt channels from the bottom of the hose on the Dirt Devil Vibe once the hose has been taken off. Check that the bottom part is clear and then tip the machine over, remove the bottom sole plate (4 screws, 2 at the front and 2 at the back near the rear wheels) to check the roller brush - sometimes if there is an obstruction in the dirt channel from the roller brush suction will not get through.
Dont forget however that there are two filters on the Dirt Devil Vibe. The top filter has to be unscrewed and then unlocked. Tap it a couple of times to dislodge any dirt and then lift out the second part filter at the top of the bin.
Dont forget to rate if this advice works. Thanks.
Jul 30, 2008 | Windsor SR12 Sensor Bagged Upright Vacuum
Dirt devil en vision
download manual here
http://www.dirtdevil.com/CustomerService/Manuals/
Jun 15, 2008 | Dirt Devil CE5500 Floor Keeper Upright...
Dirt devil vision bagless vacuum- not working
You didn't say how it runs before going off. You could have a clog in the hose or dirt inlet by the brush roll. There is a thermo protector on one leg of the wire going to the motor, if it is bad, it could be sensing the motor getting hot and casuing a shut down. Could be just a bad connection somewhere and vibrations casuing it to loose contact. Could also be a problem with the motor.
Apr 15, 2008 | Vacuums
Dirt Devil Featherlight Bagless Upright Vacuum Logo
1,569 people viewed this question
Top Dirt Devil Vacuums Experts
Nick Olsen
JoeVacs
Are you a Dirt Devil Vacuum Expert? Answer questions, earn points and help others
