Question about Philips 27PT543S 27" TV
TV loses picture after 2 o3 seconds. TV is on but picture black
If you turn tv on and set input to a AV input with no signal like a DVD input with the DVD's power turned off. It will often stay on. Sometimes the TV will stay on when set to a station after the tv has been on for some time but set to a open AV position. It seems to shut the video off when the tv is turned on and set to a Station channel other than a open Video input. Sometimes it will stay for some time if you turn the tv on ,leave on an open AV input position for 10 or so minutes. Then turn to an AV input with a DVD player attached and on then it will play the Dvd sometime for the whole DVD.
  • 52 Answers
SOURCE: Attention No Video Input
Check your input cabling and connectors and make sure you have a good input signal. Put another tv on this same input cable and see what happens. Keever
Posted on Mar 09, 2008
  • 124 Answers
SOURCE: Channel 91 say av input
Hi , Most older Television allow you to access the AV input line by selection a high channel. That is a normal function on your television. What are you trying to do since you do not have the remote control? Thanks, Mike
Posted on Nov 02, 2008
Shuttle83
  • 1139 Answers
SOURCE: Analog / Digital stations
Hello mikekahan,
OK you are not going to like this but here we go any way. First of all I need to explain how your channels are created.
When the RF signals come into the headend of the Down converters they are separated into pre channelized designations DC (Down Converter) 4 Stream 1 (DC 4-1, DC 4-2...) now once this is done the down converter signal is fed into a channel processor which takes the incoming signal from the Down Converter remodulates it and puts it on an assigned channel 4-1 could become channel 4, 4-2 could become channel 5 and so on. Once this is done you end up with your regular channel line up for analog channels, now for digital its a little different you have IRDs (Integrated Receiver Decoders) which take the off air or satellite Digital RF signals and convert them into MPEG Streams which is the fed into what is called a SEM (Motorola Architecture) Stream Encryption Module which assigns numeric designations to the MPEG streams and then converts the MPEG streams back into RF. Now at this point we have analog and digital signals what then has to happen is the the analog signals must be turned into MPEG streams to go through the system so what happens is from the channel processor the analog signal is put into a SE (Stream encryptor) Like the SE1010. This takes the analog stream and turns it into am MPEG stream and feeds it into the SEM also and the SEM assigns a numeric designation just like the digital signal and this can sometime follow the same numeric designations as was obtained from the Down Converter, So what you end up with is analog and digital signals having the 4-1, 4-2, 5-1, 5-2, ..... format. This is where other equipment comes into play These designations are then kept in a database and are matched to their proper channels by use of the DAC and RADD along with an IPG server. These allow the SEM to assign true channel designations to the converted channels, now the SEM DAC, and RADD talks to your STB, this is way the channels are correct because the SEM and the DAC/RADD are matching what is on the IPG (Interactive Program Guide). When you remove your cable box the tuner in your TV does not know how to deal with the DAC, RADD and IPG signals so it only displays the RF information which is the 4-1, 4-2, 5-1, 5-2 data.
I hope this helps,
Shuttle83
http://www.electron-age-technologies-llc.com
Posted on Feb 27, 2009
  • 6 Answers
SOURCE: My Magnavox plasma screen tv, model number:
You either have a cold solder joint in your horizontal deflection circuits or your or in your horizontal output circuit. please be careful due to the fly-back transformer still holds power even unplugged until you discharge it.( ground it out). Hope this helps.
Posted on Jan 03, 2010
SOURCE: AV channel on magnavox tv
This worked for my 20" Philips Magnavox 20MT4405/17 TV, it might work for you as well. DISCLAIMER: This is just a solution that I pieced together information from various internet sources, as I could not find a free copy of the service manual to verify this. Furthermore, I am not a technician of any sort.
Enter your TV's service menu by pressing this sequence of buttons on your remote while the TV is on:
062596 Menu
Use the arrows on your remote to scroll down to "Options", push the right arrow to enter options.
Change the 7 options parameters in order to (write down the original values in case this does not solve):
OP1: 065
OP2: 215
OP3: 065
OP4: 162
OP5: 204
OP6: 201
OP7: 000
You need to enter all 3 digits for every number, even if there are zeroes. You use the numbers on the remote to do this.
Turn the TV off with the built in power button.
Unplug the TV for 10 seconds.
Plug the TV back in, turn it back on.
If this does not solve your problem, reset the values of the options in the service menu to the values you wrote down earlier because you have a different problem than what this fix works for.
Posted on Mar 18, 2010
Model no. dtq2605fc how do we hook up a dvd player to this?
There are several ways to hook up a DVD player to a TV.
The simplest method, which works with any TV, is to use the DVD player's RF (radio frequency) output on channel 3 or 4, connect the output cable to the TV's antenna jack, and put the TV on the appropriate channel. There are two problems with this method, though. First, I'm not aware of any new players that have RF output these days. The manufacturers don't include it, figuring you'll be using the direct audio and video outputs. So if you're trying to connect a new player, you likely don't have this option. Second, if the player does have RF out, it's usually not stereo sound and the picture quality can suffer.
If the set has AV input jacks available, you would use those and select the AV input from the remote control or front panel. There are some possible problems with this method too. The biggest one is that if you've lost or thrown away the original remote, you might not be able to select the AV input. (Don't laugh, many people don't realize they should keep the original remote even if they never use it.) And on TV sets with only mono sound, you need a Y-adapter cable to combine the right and left audio outputs into one channel, so you lose any stereo effects.
The last way is for TVs without an AV input and DVD players without RF output. You use an RF converter (also called an RF modulator), which takes the audio and video signals from the player and makes a channel 3 or 4 signal you can tune in as I described earlier. RF converters are available at Radio Shack stores, most TV retailers and from many sources online. They're easy to connect, but you'll need an AC outlet nearby since they need power.
One of these methods will work for you, and you'll be watching DVDs soon. Thanks for using Fixya!
Apr 05, 2011 | Daewoo DTQ-13V1FC TV
What channel do I set the TV on so that the dvd will play
Hook audio/ video cable from dvd player to AV input of tv and select that AV input in tv to watch dvd playback picture.
You will see yellow jack (for video signal output) and red-white jacks (for audio left-right output signal) at rear of dvd player, plug AV Cable and hook it in AV input of tv, make sure yellow pin connected in yellow jacks of dvd and tv.
Thanks.
Feb 18, 2011 | Sony DVP-SR200P DVD Player
My screen is blue and it wont let me see anything
Hello
Your TV is not getting any signal at all to process, or the tuner inside your TV is faulty. Blue back screen comes, when there is no signal to any of its input or faulty tuner. Just connect the tV with any other video source, like VCR or DVD , connected to its AV terminals and set the tV to take input AV, and check whether picutre comes in or not. If picture comes with AV connection, make sure that your tVs tuner is faulty and should be replaced. If no picutre comes with AV connections too, the Chroma Ic insie your TV is faulty, and should be replaced. OK.
Feb 17, 2011 | JVC AV-32S575 32" TV
I have a toshiba 19w330db tv and already have a virgin media box and toshiba SD220EB dvd player connected. I am trying to connect a nintendo wii using the AV cable provided and am using the audio L R...
Do I understant this correctly? You are using a composite video cable (A/V y,r,w) and connecting it with the component video input (and then telling the TV to use the YPbPr source). You need a component video cable (3 RCA plugs on each end - red, green and blue) and an audio cable (2 RCA plugs - red and white) for the Wii. It wasn't included with the Wii but it does have the component video ports. Otherwise you would need a SCART to composite connector to work with the input. Alternatively, you could get an HDMI cable and connect that between the Wii and the TV (depnding on the age of the Wii).
If I've read this correctly, you have the media box and dvd player sharing the SCART input (EXT1).
I hope this helps.
Dec 26, 2010 | Toshiba Televison & Video
TV screen goes black but tv is on. But will stay on sometimes.
i have a 2000ish 32 inch trinitron Wega and i have had the EXACT same problems as you have, except mine was blacking out more and more frequently, but yes if u changes the channel or hit return onto the same channel you're watchin the picture wil come back, but not very long, about the longest it'll show a steady picture is 1/2 hr, but it's usualy going black within every 10-15 mins or so.
I took it to a Sony approved/recommened repair shop and aftet having a look i was told it would cost $200 cd including taxes to replace a 'vacuum tube' or something like that, i wish i could be more specific anout the part. I'm still considering whether or not to go through with the repair. I might just buy a working/used newer Tube Flascreen with HD for another couple hundred dollars. If there was a newer 2003+ 32 or 36" Sony that has a good track record I would love to hear suggestions. I don' trust flat panels, way too mny horror stories, and for every 1 i hear about there's probably 10-20 more.I'll give them another 5 years or so to get their acts together.
On the other had, if i do decide to get my 32" wega fixed i will post the results and the exact pt numbers of the pts used i the repair. Your problem is exactly the same as mine, to the letter. I'm a mechanic by trade, but i have a good feeling they're not going to give me correct pt # until i have payed them to fix it. Or else i'd order the part and install it myself.
Good Luck,
Aaron
Jan 24, 2009 | Sony Televison & Video
57HX81 Toshiba. picture gets squiggly on dvd input
Perhaps 2 things. Does TV get a picture without DVD connected? If so I would bet you have a faulty connection in your signal board where the in jacks are at the back of the TV . Check to make sure cable from DVD are not bad, I have used cables before and got a false positive. Try turning and spinning the jacks once you have a picture.Make sure your signal board is firmly pressed into its slot on the signal board chassis. Thats it for now. Good luck.
Jan 20, 2009 | Toshiba 57H81 57" Rear Projection...
No image from inputs 1 and 2
i just spoke to a tech guy and his solution worked for us. turn everything off including the dvd player or whatever you have in your video inputs.
pull the tv power cord out from the back for 30 seconds. plug the cord back in. turn on the set for 30 seconds. then turn on your dvd player. you should now see a picture.
we had something funky happen to our cable the day the set starting giving us trouble. pulling the power cord apparently allows the tv to reset.
good luck.
Aug 29, 2008 | Sony BRAVIA KLV-40U100M 40 in. HD-Ready...
Hi! name's wesley. anyways, here's the problem. i just bought a new samsung 32' lcd tv and everything is great except for one thing: when i connect my ps2 to the "av 2" input, the sound comes out...
There is a problem with the AV2 input. Since this is a new set, return it for repair or exchange. DO NOT open it up as that would void the warranty.
Dan
Jun 05, 2008 | Samsung Televison & Video
1}DVDR 3480 playback on many Dvds widescreen insteadof 4.3 as set. 2) my Vcr. has 3pin phono. Dvdr scart to Phono .Xt2 says nosignal. Phono tophono (cam socket) no signal .cannot copt tape to DVD. 3)B W...
1) The 4:3 / 16:9 option only optimises playback for that particular type of TV. The 4:3 setting also allows you to set the output between:
  • 4:3 PS - expands the picture vertically and horizontally which gets rid of the black bars, but you also lose the left and right edges of the picture.
  • 4:3 LB - Letterbox format, displays the full picture from the disc, with black bars top and bottom.
The PS option loses the bars on 16:9 widescreen DVDs, but may still leave bars on true cinema widescreen DVDs, which are 21.7:9
This is normal.
  • 16:9 - Optimises the picture for a widescreen TV. Again True cinema widescreen DVDs will still have black bars.
2) All of the external inputs will show "No signal" until there is actually a signal playing into them.
EG to copy VHS to DVD, you will need to select the relevant scart or phono input, and press play before the recorder will register a signal and allow recording.
Some bought VHS videos have copy protection, and may cause problems when copying to DVD.
3) Greenish playback maybe caused by colour setting on TV being too high. Also check Hue or Tint settings on the TV, if it has them.
4) For some reason, in their infinite wisdom, Philips omitted the Video Plus facility from this model.
Apr 28, 2008 | Televison & Video
Philips 27PT543S 27" TV Logo
101 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
