Question about Zebra LI4278 Barcode Scanner
Code 93 not reading
Code 93 enable barcode were
Cannot read bar code
If it will not read any bar codes, then it must be repaired. If it only reads selective bar codes, then perhaps the one you are trying to scan may not be of the type it recognizes.
This scanner will read the following codes: LS 1004/LS 1006: UPC/EAN, Code 39 full ASC11, Code 128, Code 93,
Codabar, Interleaved 2 of 5, Discrete 2 of 5; LS 1000: undecoded
Mar 09, 2015 | Symbol LS-1006 (ls1006i0001900z) Handheld
Voyager MS9540 scanner...how do I enable code 93?
Go to www.honeywellaidc.com and click on English under North America. In the search bar type in 9540. You should only get one result for Voyager 95X0 Series of Single-Line Laser Scanners. Click on the heading and under the picture on the tab bar choose documents. Under user Guides choose MetroSelect Single-Line Scanner Configuration Guide. On page 14 you will find the barcode to scan "Enable Code 93" . Page 14 is also labeled as 2-6. Good Luck
Oct 01, 2012 | Metrologic Instruments MS9540 Voyager...
How can i progamm the 2208, so it will scan code 39 and code 93
The Quick Start Guide has a Default Barcode. Scan that. Code 39 and 93 should be on by default. If not download the Reference Guide and there are barcodes in that manual that enable/disable all symbologies.
Dec 05, 2009 | Symbol LS2208 Handheld
I cannot scan code93
Code 93 is not enabled on default. Scan the Enable Code 93 barcode from Adobe page 190 of 342 from the LS2208 Product Reference Guide. You didn't say which scanner you have but most Motorola scanners use the same barcodes. If the scanner does not accept this barcode then look up the PRG for your scanner and find the barcode in that manual. You may also need to scan the Code 93 Any Length barcode from the next page if your barcode is less than four characters.
Oct 23, 2009 | Symbol Computers & Internet
Hello, i am new to using the barcode scanner can you please tell me how i can use it. I have it enabled but it seems like it is not working, because when i have any bar code in front of the scanner and...
The barcode reader can only be used by any application developed. To read barcodes for a program like notepad, excel, etc.., then there is a program that sends the reading of the scanner into the keyboard buffer. You can also read barcodes with the camera. The buttons are also programmable.
Oct 01, 2009 | Symbol MC70 Barcode Scanner
Scanner enters immediately upon every entry. I need to make multiple entries then enter all at once.
You can create a barcode in Code 39 that contains $M. Then scan the Enable Code 39 Full ASCII barcode from the Symbologies section of the LS4000 Series Product Reference Guide (Adobe page 93 of 182). If you are unable to create the barcode Knowledge Article ADC-00266 contains the $M barcode. You may run into problems with your application if it does not see a Control M as an Enter. If this is the case the article contains instructions for addressing this problem as well.
Jun 09, 2009 | Symbol LS 4000i Handheld
Enabling NCR 7875 flatbed scanner to read Code 128 barcodes
On a 7876, you need to scan the sequence “17130” is to add 128 tag readability. Not too sure if the 7875 is the same.
Feb 18, 2009 | NCR 7875
VB With MC9090S
If you are willing to use VB.NET, then it will be easy. You would need the Symbol EMDK. With that and VS2008 (Express should be fine as well), you only need few coding steps:
1) Add reference to dlls
Symbol.dll and Symbol.Barcode.Dll
2) Finder a scanner
s = Symbol.Barcode.Device.AvailableDevices.First()
3) make a reader
r = New Symbol.Barcode.Reader(s)
4) add data
d = New Symbol.Barcode.ReaderData(1, 1024)
5) enable laser
r.Actions.Enable()
6) enable reading
r.Actions.Read(nrd)
7) add handler
AddHandler r.ReadNotify, AddressOf r_ReadNotify
8) read data in event
msgbox(d.Text)
That is all there is too it. Good day.
Jan 22, 2009 | Symbol MC9090 Barcode Scanner
Scanner doesn't scan all barcodes
these scanners are user configurable, to prevent scanning of an inappropriate barcode, only the required barcode schema are enabled, if you look in your code book you will find that there is a page with listings and examples of the various different barcode schemes, in the section before that there should be a list of barcodes that allow you to program the device to use whichever barcode scheme you wish (as long as it is compatible with the scanner)
so you can enable the scanner to read 128, code 39 or EAN and also you can configure prefixes / suffixes depending on your software's requirements
Oct 10, 2008 | Falcon 4420
Zebra LI4278 Barcode Scanner Logo
Top Zebra Computers & Internet Experts
Mike
Gareth Cockram
Gareth Cockram
Are you a Zebra Computer and Internet Expert? Answer questions, earn points and help others
