Question about Oki Brand Oki MC561 MFP Multifunction Laser Printer Copy/Fax/Print/Scan
Error code 054 - Oki Brand Oki MC561 MFP Multifunction Laser Printer Copy/Fax/Print/Scan
What does error code 0x9D mean?
it is not a common error code, please call 1 300 361 054. Or click HERE.
Aug 26, 2014 | Epson WorkForce WF-3520 All-in-One Inkjet...
Need to get code for 3-1 remote # 1519001
TV Brand 3-in-1 Code Radio Shack Cat. No.
Akai 098
Anam 068, 180
Anam National 055, 161
AOC 019, 030, 052, 137
Candle 030, 046, 056, 186
Capehart 052
Citizen 030, 039, 046, 056, 060, 092,
186
Concerto 056
Contec 158, 180, 185
Craig 161, 180
Crown 039
Curtis Mathes 030, 039, 060
CXC 180
Daewoo 019, 039, 091, 092
Daytron 039
Electrohome 039
Emerson 039, 158, 177, 178, 179, 180,
181, 182, 183, 185, 236, 270,
280, 282
Envision 030
Fisher 154, 159
Fortress 093
Fujitsu 179
Funai 179, 180
Futuretech 180
GE 021, 027, 029, 047, 051, 055,
174, 178, 282
Goldstar 001,019, 039,056, 106, 178
Hallmark 178
Hitachi 038, 039, 056, 095, 097, 145,
151, 173, 227
Infinity 054
JBL 054
JVC 053, 169
Kenwood 030
Kloss 046
Kloss Novabeam 024
KMC 106
KTV 039, 180, 280
Logik 016
Luxman 056
LXI 047, 054, 148,154, 156
Magnavox 020, 024, 028, 030, 054,
096, 186, 187
Marantz 030, 054
Memorex 016
154 16-229
178 16-254
16-263
16-280
MGA 019, 030, 150, 155, 178
Mitsubishi 019, 098, 155, 178
Mitsubishi Unified 150
MTC 019, 030, 056, 060, 091
Multitech 217
NAD 156, 166
NEC 019, 056, 170
NEC Unified 030
Onwa 180
Optonica 093, 165
Panasonic 051, 054, 055, 162
Penney 018, 019, 021, 030, 039, 047,
060, 135, 149, 019, 020, 024,
028, 030, 054, 186, 187
Phillips 000, 054
Pioneer 038, 166
i think this will help you a lot.
Aug 03, 2009 | Televison & Video
Panasonic fax uf-550 check printer
this code 054 =
Communication error occurred while transmitting.
1. Reload the document and send again.
2. Check with the other party.
Jun 17, 2009 | Panasonic Panafax UF-550 Plain Paper Laser...
That code is for a bad LASER unit.
Try a new toner cartridge first.
May 21, 2009 | Panasonic Panafax UF-550 Plain Paper Laser...
I have a panafax uf755e showing error code 054 and it won't print the fax's
054 is a laser unit error. Switch off/on..to clear. Otherwise it's an engineer job and unlikely to be cost effective.
Apr 12, 2009 | Panasonic Panafax UF-885 Plain Paper Laser...
Panasonic UF-490 erroe codes 887 & 054, how to clear?
Your laser unit has failed. It's uneconomical to have it repaired.
Mar 05, 2009 | Panasonic PanaFax UF-490 All-In-One Laser...
Info Code 054 - Printer Error - cannot be found in manual
sorry to tell you its the lsu laser unit in the machine the only way to fix it is to replace the part
Dec 08, 2008 | Panasonic Panafax UF-585 Plain Paper Laser...
UF-788 Error Codes...
You have a bad laser unit, no parts are available anymore.
Nov 20, 2008 | Panasonic Panafax UF-595 Plain Paper Laser...
Error message
o54 means you have a bad laser unit. Try unplugging power cord and replug.
Sep 02, 2008 | Panasonic UF-590 Plain Paper Laser Fax
Printer error 054
That's because you need to take out cartridge and put it back! See is there any jamed paper inside!!! Error 054 is about cartridge!! Can't read that cartridge is inside the printer!!!
Feb 07, 2008 | Panasonic Panafax UF-585 Plain Paper Laser...
Oki Brand Oki MC561 MFP Multifunction Laser Printer Copy/Fax/Print/Scan Logo
264 people viewed this question
Top Oki Brand Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you an Oki Brand Office Equipment and Supply Expert? Answer questions, earn points and help others
