Question about Intermatic Inc. ST01C Digital In-Wall Timer
Timer quits shutting the lights off and time flashes 12:00AM
Our timer is a model EJ500 about 1 year old. In the last week it has quit shutting the lights off twice and the time starts flashing 12:00 AM. All I have to do is reset the current time and it starts working again. Any suggestions?
David
  • Anonymous Mar 24, 2014
    The lights are currently working on a 12 hour cycle 5.30 to 5.30 - we want to make it later
Check the battery
Posted on Feb 05, 2010
    Problem Solver:
  • 12 Answers
Intermatic is a reliable mfg. if you have a it wired to directly to a light and only a light, you most likely have a defective timer. Bring it back and purchase a rotary timer with on-off switch. more reliable. I too installed the same type of timer and went through 3 before installing intermatics rotary timer/switch.
Posted on Jan 25, 2009
Model JTP15. Why did beeper on timer quit working?
The beeper failed from old age. Sixteen years is a lifetime + in the appliance business.
Mar 02, 2016 | GE Ovens
How to open to repair Woods 24 Hour Digital Outdoor Timer with Photocell Mfr # 13660
1) Copy following link to identify timer, and select replacement if needed.
http://waterheatertimer.org/Woods-timers-and-manuals.html#2001
2) There is no reset button on this type of timer.
Nor is there a repair manual for $16 timers.
Generally people buy another timer since the timing chips and parts are delicate, easily damaged by power surge, and often quit working before 1 year warranty expires, and usually last a few years before no longer functioning. The photoeye sensor is often a failure point.
3) Check outlet for 80% rated voltage.
Check timer on different outlet.
Use circuit analyzer and test outlet for correct polarity and grounding.
Test and replace GFCI outlets as needed.
Dec 01, 2012 | Woods Outdoor Lighting Timer
Fujitsu halcyon economy light and operation light flashing
I have a fujitsu DC inverter model no. ASYG18LFCA not a week old as yet, when I turn it on it works fine for 5mins. then stops and after a short time the timer and economy lights start flashing, can anyone help on this, please.
Derrick
Apr 02, 2012 | Heating & Cooling
I have aMicromark MM9533 7day electronic timer (could be quite old), but cannot set it because I have lost my instructions. I can set the time ok, but when I try to set each day's on/off times, it...
There are eight timer on/off events, you set each of the on and off time pairs for a particular day of the week or combination of days. If it is that old, mine was bought in 1999 and just rediscovered, you should change the button battery found under the screw panel. The timer doesn't work the way you seem to be describing.
Sep 02, 2011 | Vacuums
Just installed a in-wall digital timer model 59018 and when we try to program it when we hit the clock button the unit shuts off so we are unable to set the time (or anything)
Woods 59018 single-pole 7-day 7-program timer, color white:
http://waterheatertimer.org/Woods-timers-and-manuals.html#59028
I test timers and 3-5% arrive defective, and they never work. Some stop working within 1 year, and some last quite a while.
Timers are affected by line interference and polarity issues. So wiring in home has to be correct before timer will operate as expected.
Timer has to be installed correctly with each wire correctly connected.
Press manual override button and see if lights turn on-off. This will indicate if your timer is wired correctly. If lights do not turn on-off with manual override, the open link above for wiring instructions.
To begin programming, reset timer by pushing in the round reset button with toothpick or paper clip.
12:00 am Mon should display.
If the above items are all correct, then defective timer is suspect.
If you try multiple timers, and each timer has same problem, then line interference or bad wiring is suspect, or you are buying from somebody who has a bad batch of timers.
Try wiring same timer at neighbor's house and see if it works there.
Jul 04, 2011 | Woods InWall 7 Day Digital Programmable...
Dryer model mde6657byw will not turn on . after I pull on the start knob and hold, it should turn but will not
How old is this modle? Lots of times even after a few years the timer will quit working,Those are timers in that knob and once they quit,,they need replaced and they are never a cheap date.
Mar 07, 2011 | Maytag Dryers
My GE Smart Digital timer won't shut off at the assigned time, but it will shut down manually.
I am guessing that you have digital in-wall timer GE 15071 or GE 15086
To identify timer for sure, see images at following link:
http://waterheatertimer.org/GE-timers-and-manuals.html#15071
Manual for 15086
http://waterheatertimer.org/pdf/GE-15086-Manual.pdf
If this is new timer, the problem could be a couple things.
1) Circuit has electrical problem that is affecting timer electronics.
Use circuit analyzer from Home Depot electric department and test any receptacle on same circuit breaker as timer.
2) event1 ON was programmed but event1 OFF was not programmed. To review events, press Prog button once to see event1 ON and press Prog button again to see event1 OFF. When review is complete, press clock key to return to current time.
3) event1 ON and event1 OFF are programmed with conflicting day schedules
4) event1 and event7 have conflicting schedules
If this is new or old timer:
5) Timer needs to be reset because of internal glitch. Press and hold reset button for a moment and timer display will start flashing 12:00 am MO
6) These timers can go bad any time. I test timers and 4-6% arrive defective, and most quit after couple years, but some can last quite a while. This is why I suggest using a circuit analyzer to check if circuit is causing difficulties.
Dec 26, 2010 | Hardware & Accessories
I have a LER4634EQ1 WHIRLPOOL electric dryer. Last week it started to shut down before completing a cycle. The other day it completed the cycle but the clothes weren't dry. It also makes a loud noise when...
if the noise is a rumbling sound tha that would be your roller's.the other problem sounds like a bad timer.time to think,do i put that kind of money in a 12 year old dryer or get a new one.
Nov 05, 2009 | Whirlpool LER5636P Electric Dryer
Intermatic Inc. ST01C Digital In-Wall Timer Logo
389 people viewed this question
Top Intermatic Hardware & Accessories Experts
Craig Butler
Craig Butler
Gene Haynes
Jay Finke
Jay Finke
Are you an Intermatic Hardware and Accessory Expert? Answer questions, earn points and help others
