Question about HP LaserJet 3055 All-In-One Printer
Sir, I have a HP 3055 laserjet. It prints and copies fine. but when i try to scan documents,the bulb gets stuck in the middle of scan and fails to scan. I have re installed the software but the problem persists. kindly assist..
Do u have a program problem? installing the drivers and all? i have a problem with this especially when i'm on vista..
Posted on Feb 03, 2009
  • 535 Answers
U have to serivce your scanner its need to open it if u have warrenty then go in service center if not then open it then clean it put there some white gress its avlible nearest electronic store then try to scan
Posted on Jan 24, 2009
3055 glass
There is no need to change the mode. When the document is loaded on the document feeder, the screen displays "DOCUMENT LOADED" and shall copy or scan this document. To copy or scan from glass, DO NOT LOAD ANY DOCUMENT IN THE FEEDER. The printer will automatically copy / scan from glass.
May 10, 2013 | HP LaserJet 3055 All-In-One Printer
HP 3055 All In One laserjet prints all black pages
Odds are that you have a bad toner cartridge; especially common when using remanufactured cartridges. (Staples, Corporate Express, etc.) Replace your cartridge with an OEM HP cartridge and you should be OK.
Feb 22, 2010 | HP LaserJet 3055 All-In-One Printer
Hp laserjet 3055 scans larger than print area
When you place a document for scan, you must select the portion you want to be scanned.
You must also set the resolution which is set to 300 by default, if you want a actual size then set the resolution to 75, which is 3% larger then actual image.
It will reduce size in KB or MB of your image and it will be exact size.
Similarly, when you want to print, you must select option "Exact Fit" and print your document.
Everything will be normal.
Nov 06, 2009 | HP LaserJet 3055 All-In-One Printer
Unable to scan on HP Laserjet 3055 on Windows XP
Sounds like a software issue - U might try contacting HP but do not hold your breath. If machine is out of warranty they want nothing to do with you and will refer you to some forum or whatever. Or they might tell you to get a new scanner compatible with a newer OS.
Jul 02, 2017 | HP LaserJet 3050 Printer
When trying to copy papers do not feed but if you scan they will
HP LaserJet 3050z, 3050 All-in-one, 3052, 3055, 3390 and 3392 versatile printer - Error reported: Document Feeder Jam ISSUE: How to correct the HP LaserJet 3050z, 3050 All-In-One, 3052, 3055, 3390 and 3392 versatile printer if this error is reported: Document Feeder Jam SOLUTION:
  • Clear the jammed media from ADF (HP LaserJet 3050, 3050z).
  2. Remove any jammed media with care.Take out the page gently. NOTE: Take care not to tear the paper. c01075162.gif
  3. Close the ADF cover plate.
  • Clear the jammed media from ADF (HP LaserJet 3390, 3392, 3052 and 3055).
  1. Open the ADF cover plate. NOTE: Check whether all packaging straps inside the ADF are removed. c01075163.gif
  2. Unload the jam clearance component.Lift the two handles with both hands until the component clutch is released.Rotate and lift the jam clearance component, and then put it aside. c01075164.gif
  3. Lift the green handle, and rotate the paper picker until it is opened. c01075165.gif
  4. Gently remove the page without tearing it.If you feel resistance, go to the next step. c01075166.gif
  5. Open the ADF cover plate, and loosen the media gently with both hands. c01075167.gif
  6. When the media are stopped, pull the media out gently along the shown direction. c01075168.gif
  7. Close the cover plate of the flat scanner (HP LaserJet 3390, 3392, 3052, 3055). c01075169.gif
  9. Insert the jam clearance component to reinstall it.Press the two reeds until the component is properly engaged.Install the clearance component correctly. Otherwise, paper jams will continue to occur. c01075171.gif
Have a good day
Jun 22, 2009 | HP LaserJet 3055 All-In-One Printer
Not scanning or copying when using the ADF on HP laserjet 3055
Based on the assumption it's mechanically ok, check the cable connection between the document feeder and the base, if damaged or worked look it can cause errors. If it is a sensor error, check for a small bit of paper or even a staple from a prior jam.
Jun 18, 2009 | HP LaserJet 3055 All-In-One Printer
HP 3055 model scaner problem
i want repair HP laserjet 3055
Scanner error 6
Sep 15, 2008 | HP LaserJet 3055 All-In-One Printer
Document loaded showing 3055
Sensor flag would have got stuck, check adf paper presence sensor
Oct 09, 2017 | HP LaserJet 3055 All-In-One Printer
HP LaserJet 3055 Won't Scan
My hp 3055 is working fine on the network bt problem is "SCAN TO" Button is not being configured with the PCs.It displays all the PC names bt not able to scan. it diplays an error "Unable to Connect".
can any body help me out of this matter
Dec 27, 2007 | HP LaserJet 3055 All-In-One Printer
HP LaserJet 3055 All-In-One Printer Logo
54 people viewed this question
Ben Johnson
