Question about Actiontec (GS503AD3-01) Modem
Lights on my modem are flashing rapidly in unison. The power light is flashing red, connection light is blank, internet light is blank, and each of the four ethernet ports are flashing green. I have pressed the reset button the back of the modem, checked and rechecked all the connections, plugged the modem into an alternate power source...no change.
  • Anonymous Apr 12, 2009
    the power light is red, dsl and internet lights are blank,
    Problem Solver:
  • 14 Answers
--If the Power light is flashing red thanits definately problem with the Actiontec Router --As you have checked with different power source, the possibility of bad power source is no more --May be due to some voltage fluctuation the modem is gone bad.
Posted on Jul 11, 2007
6ya staff
SOURCE:
Star tsp650 printer
Test your modem to see if it works by switching out with a known good one
Try power cycling (keep it unplugged for a few minutes) then plug it back in. My router gets hot and and stops working
Nov 06, 2013 | Office Equipment & Supplies
Tip
Troubleshooting DSL Modems
Ever look at your DSL Modem and wonder what all those lights mean? Why do some flash, while others remain solid? What if your lights are different colors? How do you tell if your DSL Modem is working correctly?<br /> <br /> Each light on your DSL Modem represents a function. The light is an indication of whether that function is working properly. Sometimes the placement and title of each function can vary by modem manufacturer, but they are pretty standard in interpetation. If you look closely your modem, you might find that each function is labeled in small print to help identify them.<br /> <br /> A standard DSL Modem has a light for power, internet, ethernet, link and wireless connection. A healthy DSL Modem will have a steady green light that does not blink or flutter for all features other than internet, ethernet and wireless. A flashing or fluttering light indicates movement and useage. When you are connected to your DSL Modem wireless, the light for this feature will blink indicating a connection and/or active useage. If the internet connection is working properly the color of the light will be green. If the connection is working but experincing a problem the light can turn to yellow or orange. If the connection fails, the light on the DSL Modem can be red or absent depending on the problem causing the trouble. If your service is turned off by the provider, more than likely the light will be "off".<br /> <br /> If your lights turn a different color, are absent or your internet connection fails try power cycling your modem before reporting the trouble to your provider. Power cycling helps the DSL Modem to reset its connection and repair your internet services.<br /> <br /> If you are using a DSL Modem alone to connect to the internet (no additional router) you can power cycle it by first turning off your computer and then unplug the modem itself from the power source at the wall. Wait for 1 to 2 minutes and then plug it back into the power source and wait for the warm up to finish before rebooting the pc.<br /> <br /> The DSL Modem should go through the normal warm up procedures of blinking lights, making them all stable and solid green ect. You will know when its finished warming up when the features are set at solid green (other than eithernet, internet and wireless connection as explained above). When the modem finished the warm up, reboot your computer and check your internet connection.<br /> <br /> Power cycling your DSL Modem can help keep your connection healthy and running at optimal speeds.<br />
on Mar 30, 2011 | Computers & Internet
I restet my linsky wireless adapter and all i get is a flashing blue power light
The flashing blue light is absolutely normal!!! Please follow these steps to configure your computers to your wireless router
Here are the recommended steps to connect to a wireless base router 1. Check and remove power from both your router and the DSL ROUTER/CABLE ROUTER MODEM 2. Wait one complete minute until applying power to modem then wait one minute before applying power to wireless router. 3. Ensure you have green lights across both devices, specifically, the recieved and sent lights. These same lights will tend to blink rapidly when there is active data, at times this will still blink, and a DNS error will prevent you from connecting to the internet. If this is the case, call your ISP Internet service provider 4. Check your authentication Security key on your router first, then check all your wireless devices to ensure they are on the same network name, key, and channel with the same type of encryption as the router 5. Start one device at a time and check for connectivity, if your still experiencing a problem, check the settings on all your wireless adapters, device drivers, internet browser settings, firewalls and proceed. 6. still have problems, connect a rj45 cable from the router directly to your computer to at least see if your wireless settings are bad or if the router may be bad. 7. Contact your ISP to determine if your receiving singal 8. Avoid using a splitter or parital power backup for yours routers 9. Still having problems, change your wireless router only after your ISP changes their faulty modem 10.Attempt the same process when setting up your new wireless router and or modem
Jan 20, 2011 | Linksys E3000 Wireless Router
For some reason the light above the WPS button keeps flashing red. I have tried multiple reboots, none of which have worked. when connected to the ethernet modem, the light stays as a solid red color.
You need to reset your Router before setup manually.
To restore the router to factory default settings, please do the following:
1. Unplug the router's power supply
2. Press and hold the reset button on the bottom of the router
3. Keep the reset button depressed and, at the same time, plug the power supply back in
4. Keep the reset button depressed for another 10 seconds
5. Release the reset button
======================= Manually configuration ==============================
Step 1 : Connect modem - Router - Computer ( Wired )
Step 2 : Open router setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3 : On the left side under internet WAN click Connection Type
Step 4 : leave the Password Blank and click submit
Step 5 : Choose the connection type as dynamic and click next
Step 6 : Leave the Host name blank and click apply
Step 7 : On the left Under Internet WAN Click MAC Address
Step 8 : Click Clone and Click Apply changes
Step 9 : If the Internet status on the top right is connected
Step 10 : Then check if you have internet
Step 11 : if not Then unplug the Power Cable from the Modem And the Router
Step 12 : Plug the power Cord to the Modem
Step 13 : Wait till all the lights are on
Step 14 : Plug the power to the belkin
Step 15 : Check the color of the light in the belkin
Step 16 :If green then Check if you have internet
If not working then call belkin
WIRELESS SETTING UP A WIRELESS CONNECTION
Step 1 : Connect Router - Computer ( Wired)
Step 2 : Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3 : On the left under wireless click wi - fi protected setup
Step 4 : Leave the password blank and click on submit
Step 5 : Disable it and Click on apply changes
Step 6 : On the left under wireless click Security
Step 7 : Enable 64 Bit WEP
Step 8 : Type a 10 digit number on the key 1 ( 2 in each box )
Step 9 : Click apply changes
Step 10 : on the left under wireless click channel and SSID
Step 11 :Change the Wireless channel to 6
Step 12 : Change the SSID to a different name ( no Spaces )
Step 13 : Click apply changes
Step 14 : Now Scan and connect to this network ( Wireless )
Let me know if it works
Aug 16, 2010 | Belkin Wireless Play Router (F7D4302)
Comcast is my service provider and I have had an RCA DCM 245R modem for almost 10 years. Until recently it has worked fine. On an ever increasing basis I am losing internet connection and when I look at...
It can be an issue with the modem or with the line. When the line drops the link then the modem shows only two lights. And, when you power cycle the modem (unplug and replug it) it establish the session again with the comcast.
So, i'll suggest you to get the line checked first and if comcast finds that line is working fine then get the modem replaced.
Rashish
Aug 15, 2010 | Thomson RCA DCM245R Modem
All lights are flashing in unison. comcast says I need a new modem. Is this true?
From my limited experience with this problem, the answer can be yes. If you cannot unplug the modem power plug and reattach it, and then make it "set up" and work, the problem is either a bad line feed or bad modem. The easiest thing to do is try another modem...that will verify if the line is good. If the line is bad, comcast has to fix it for free, to provide your service. It your modem is good, you won't have to replace it and buy another one(however, they may charge a service fee, I'm not sure if or how much- call them and check first). Hope this helps.
Apr 26, 2010 | RCA Thomson Digital Cable Modem (DCM305R)
I have an N+ wireless router that will not talk to my motorola SB5100 cable modem the modem and internet lights flash amber and the setup assistant does not help.
IF Your ISP is Cable then
Step 1 : Connect Modem - Router - Main Computer *(Wired)
Step 2 : Open RSP By typing 192.168.2.1 On the Address Bar of the Internet Explorer
Step 3 : On the left side under internet WAN Click Connection Type
Step 4 : Leave the password Blank And click Submit
Step 5 : Select the Connection type As Dynamic
Step 6 : Click Next
Step 7 : Leave the Host Name Blank And click Apply Changes
Step 8 : On the Left Click on MAC Address Cloning
Step 9 : Click Clone , Apply Changes
Step 10 : Turn off the Modem And the Router
Step 11 : Turn ON The Modem First, Wait Until All the Lights Are ON
Step 12 : Connect the Power To The Router
Step 13 : Wait for 5 Minutes
Step 14 : If The Lights Are Still Flashing
Step 15 : Connect Modem - Computer
Step 16 : Check if It is getting the Internet
Step 17 : If its Not then Restart the Modem And Try It
Step 18 : Make Sure You are getting the Internet When you Connect Modem - Computer
Step 19 : And after that Connect Modem to the Yellow Port on the Router
Step 20 : Check the Lights After 5 Minutes
If it is Still the Same then call Belkin Tech Support
The number is 1800-223-5546
Nov 07, 2009 | Belkin Computers & Internet
When power switch is turned on the Power light is rapidly flashing & the 4 Ethernet lights are flashing. The box is Actiontec GT704wg
I do not have a solution to the problem. However, I am having the same problem. This morning the Actiontec GT704WG power and ethernet lights were rapidly flashing. The modem was non-functional. I could not even connect to the modem through the browser to see if I could find a problem.
The problem lasted a couple of hours. Then all of a sudden the modem started working again. I won't be able to tell if the problem recurs until I restart the modem. And if the problem does occur again, I won't be able to connect to the internet.
Oct 08, 2009 | Actiontec GT704WG Wireless Router...
LIGHTS ON MODEM ARE FLASHING RAPIDLY, HAVE CHECKED POWER SUPPLY AND PUSHED RESET BUTTON, NO CHANGE
You will have to be a bit more clear on which lights on which model of modem is flashing rapidly.
Usually, as long as the internet works, the flashing lights are there to show that the modem is functioning properly and is currently sending packets, transmitting data, etc.
Jun 19, 2009 | Actiontec (GS503AD3-01) Modem
Open Questions:
YAHOO email technical support #{18OO~828O294} contact number usa asif There are two circumstances that can cause someone to want to change his/her YAHOO password: 1 forgetting the YAHOO password and needing to recover it and 2 to change the YAHOO password. The latter can be because the YAHOO password has leaked to someone or the user wants to adhere to the good practice of changing his/her password periodically. It is a good practice to change one's YAHOO password at least once in a month. Contact YAHOO Mail Password Reset 1-8OO-828-O294. For your convenience to contact YAHOO Mail Password Reset We have provided all possible information of YAHOO Mail Password Reset. You can contact YAHOO Mail Password Reset on the given phone number 1-8OO-828-O294. Changing an YAHOO Password The following steps show in detail how to change an YAHOO password when the current password is known: Sign into the YAHOO Mail Account from YAHOO Do you want to recover/reset your YAHOO email password? So you'll be do the some steps to recover your YAHOO password. We'll help you to fix your problem and we'll guiding the some steps to recover your YAHOO password. Follow and do the below steps to recover your YAHOO email password- Go to the YAHOO - login page. Enter your Username or Email address and click next. Click Forgot Password below the Password field. Enter your Email address and click Next. Verify your Email address or Phone Number and click on the Next. Open your Email account and check your YAHOO mail message on your Gmail account. YAHOO is an abbreviation for America Online, one of the country's earliest providers of internet and email services. While YAHOO's dial-up internet is not as widely used as it once was, many people still use the company's email service. It's a great email service that lets you stay connected with your family and friends -- that is if you remember your password. Forgetting your password on any internet service is an annoying and sometimes painful process; thankfully, YAHOO has made it easy to recover or reset your account's password. *Please Read* If you don't remember or didn't sign up with one your alternate email address, or you didn't use a mobile phone to register, you will not be able to reset your YAHOO password. If you find yourself in this situation, create a new account. If you do have access to your alternate email or mobile number, follow the steps below to reset your YAHOO password.
Oct 23, 2019 | Yahoo Computers & Internet
YAHOO mail tech support number #{18OO~828O294} usa asif There are two circumstances that can cause someone to want to change his/her YAHOO password: 1 forgetting the YAHOO password and needing to recover it and 2 to change the YAHOO password. The latter can be because the YAHOO password has leaked to someone or the user wants to adhere to the good practice of changing his/her password periodically. It is a good practice to change one's YAHOO password at least once in a month. Contact YAHOO Mail Password Reset 1-8OO-828-O294. For your convenience to contact YAHOO Mail Password Reset We have provided all possible information of YAHOO Mail Password Reset. You can contact YAHOO Mail Password Reset on the given phone number 1-8OO-828-O294. Changing an YAHOO Password The following steps show in detail how to change an YAHOO password when the current password is known: Sign into the YAHOO Mail Account from YAHOO Do you want to recover/reset your YAHOO email password? So you'll be do the some steps to recover your YAHOO password. We'll help you to fix your problem and we'll guiding the some steps to recover your YAHOO password. Follow and do the below steps to recover your YAHOO email password- Go to the YAHOO - login page. Enter your Username or Email address and click next. Click Forgot Password below the Password field. Enter your Email address and click Next. Verify your Email address or Phone Number and click on the Next. Open your Email account and check your YAHOO mail message on your Gmail account. YAHOO is an abbreviation for America Online, one of the country's earliest providers of internet and email services. While YAHOO's dial-up internet is not as widely used as it once was, many people still use the company's email service. It's a great email service that lets you stay connected with your family and friends -- that is if you remember your password. Forgetting your password on any internet service is an annoying and sometimes painful process; thankfully, YAHOO has made it easy to recover or reset your account's password. *Please Read* If you don't remember or didn't sign up with one your alternate email address, or you didn't use a mobile phone to register, you will not be able to reset your YAHOO password. If you find yourself in this situation, create a new account. If you do have access to your alternate email or mobile number, follow the steps below to reset your YAHOO password.
See all Actiontec (GS503AD3-01) Modem Questions
Actiontec (GS503AD3-01) Modem Logo
557 people viewed this question
Top Actiontec Computers & Internet Experts
Prashant M
Prashant M
Ekse
Joaquim Martins
Are you an Actiontec Computer and Internet Expert? Answer questions, earn points and help others
