Question about Health & Beauty
Salter 9180 error message - Health & Beauty
I have a Brother MFC-9180, it has a DR8000 in it. The machine come up on the display saying "Change drum soon" which I have done, the new drum did not come with a page to feed into the drum. I want to...
Did you reset the drum counter?
When you replace the drum unit with a new one, you need to reset the drum unit counter by completing the following steps:
  1. Turn the the machine's power switch back on.
  2. Press Menu => Machine Info. => Reset Menu.
  3. Press the Up or Down Arrow key to choose Drum.
  4. Press OK.
  5. Press 1 to reset the drum unit counter.
  6. Press Stop/Exit.
I hope this helps.
Or Try this:
http://welcome.solutions.brother.com/BSC/public/as/au/en/faq/faq/000000/002800/000037/faq002837_009.html?reg=as&c=au&lang=en&prod=mfc7220_us_as
Oct 20, 2013 | Brother International Brother MFC-9180
Can I connect Brother MFC 9180 to MacBook Pro?
Use a usb cable or connect through a wireless connection if MFC has such a capability.
Jan 21, 2013 | Brother MFC-9180 Printer
My Salter bathroom scales (model 929) are showing an ERR message. They seem to think everything weighs more than it does as if u press gently on them the weight goes up really quickly until limit reached...
The best day chessboard type is the traditional type of weight, in contrast, electronic weight scale error degreehighestelectronic
tems, affected by environments, bumps can make reading deviation.The use of electronic weight meter can more precisely?
Electronic scales are generally placed in the hard flat floor use, not on the carpet or other soft object surface by using.Each weight to body weight in the same place, the same time, wear the same clothes.
Hello, I just see a online stores
http://www.tmart.com/Digital-Scales/ sell digital scales. Some advice, for reference purposes only and finally I wish you luck!
Jul 25, 2011 | Salter Health & Beauty
Using Salter Mibody scales software - when trying to upload from the usb stick, i get the following error message - Wrong Data: Cannot update. Database or objet is read-only. I am running on Vista. Any...
I had this problem in Windows 8 recently , my solution was to enable administrator settings by right clicking the shortcut
- click properties - click shortcut tab - click advanced
- tick run as administrator
- click ok - click apply - click ok
Then to be sure I right clicked shortcut
- click properties - open file location to find where it was installed
- right click salter mibody.exe
- click properties- click compatibility tab
- tick run this program as administrator
- click apply - click change settings for all users
- click apply - click ok - click ok
not sure what bits of this made it work :)
but it worked for me
Feb 06, 2011 | Health & Beauty
'out 2' error message shows on a brand new Salter Disc Electronic scale.
Below is a solution for the "Out2" error on the Salter scales.
I have a Salter Model 1400. It was dropped and started to display the "out2" error on the LCD display. I looked for solutions on-line but could not find anything which showed a solution. With no solution in hand I figured I would at least try to find out if my scale was salvageable. I removed the screws, there are two below the 9V battery, two under the footpads, two under the "model sticker", and two larger screws holding the scale plate to the base. After all the screws are successsfull removed, the case of the scale comes apart easily. I started looking at the small circuit board and looked for damage, and also tried several things, turned on and off the unit while it was apart but still saw the "out2" error. I then removed the circuit board, there are many screws holding it down. Looking at the LCD display, I noticed that there must be proper contact between the LCD display and the copper contacts on the circuit board, or nothing is displayed. Perhaps, "out2" is an indication that it can not display "out" anything because after it was dropped the LCD display moved enough that it no longer aligned with the contacts on the circuit board. I noticed that there is quite a bit of "play" or area of movement around the LCD display and the case. There were no cracks or damage so I assume that the loose LCD display is common even with a scale that was not dropped. I was able to align the LCD display, by moving it several times and realized that after pressing the ON button, I no longer saw the out2 error. So I decided to put something in between the LCD display and the case so that the LCD display would not move and therefore would align. It took some playing around, but I eventually took a very small piece of papertowl, about the size of my thumbnail and rolled it up and placed it between the LCD display so it made the LCD display snug and would no longer move around. I screwed on the circuit board, and voila, no more out2 error! It started working perfectly.
Jan 19, 2011 | Salter 2001 electronic kitchen scale
Brother printer mfc 9180 Blobs on page at certain intervals
The blobs are probably dried toner on the drum. The solution is to use a soft piece of cloth and rub the blobs off the drum through the gap at the front of the drum unit. The drum can be rotated by turning the gear cog on the side, then once the residue has been removed from the drum and it is clean, the blobs should have disappeared. I wouldn't use any solution on the drum, just gentle rubbing should suffice.
May 20, 2010 | Brother MFC 9180 All-In-One Laser Printer
The display on my salter bathroom scales is flashing error, i have changed the batteries, this did not help
I held the two arrow and set buttons together for a few seconds and it cleared
Oct 19, 2009 | Salter Health & Beauty
I have a brother mfc 9180 and the error message keeps coming up replace the drum. I have done this How do I reset it
your new drum should have had a plastic "starter sheet" installed just level with the exit hole. this sheet resets the counter, and should not be removed before fitting the new drum. The sheet will be automatically ejected when you have fitted new drum. If you still have this sheet it can be refitted to the drum, then reinstall the drum. Works for me ! MFC 9180
Jun 05, 2009 | Brother MFC 9180 All-In-One Laser Printer
Health & Beauty Logo
48 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
