Baxi Solo 3 PF 30/80 pilot light has gone out and there is no obvious way to re-ignite it. Never had a problem in the last 8 years with it and it was just serviced last week. How can I re-ignite the pilot light please?
  • 230 Answers
SOURCE: pilot light will not light
Sounds like you may need a new electronic control module. This is a rectangular shaped plastic box that has wires coming out of it. This is what tells the pilot to light on these older furnaces.
Posted on Jan 28, 2009
SOURCE: Baxi solo 3 70pf boiler problem
This happened to me and it was a rubber pipe inside had perished so it was detecting a loss of pressure. You can see it if you take the main cover off and also the front clipped on cover. Its at the top on the right. You need to replace it with heatproof pipe. Good luck!
Posted on Jan 05, 2010
  • 3238 Answers
SOURCE: Baxi 3 Solo Boiler will not ignite
it could just be the presure switch try bridging it out and see if burner lights
Posted on Jan 21, 2010
SOURCE: Baxi solo 2 30pf will not fire up.. please help!
first off ensure water is getting to boiler, next, No pilot = pressure switch. On my baxi solo 40 pf pressure switch is replaced 8-10 times a year cures your problems,,,,,,,, momentarily , and have had all your other parts,but with no effect to speak of,.......sorry............ solution = [ change boiler ].sounds like gas pressure or lack of water to system or **** boiler like mine .........good luck.
Posted on Mar 11, 2010
  • 120 Answers
SOURCE: how to light pilot light for baxi bermuda sp3
Go to this link.Bottom of page 15 on the manual
http://www.aroundtownflats.com/manuals/Boilers/Baxi/BAXI%20BERMUDA%20SP3%20GCNo.37-077-63.pdf
Basically it says (turn on the power first) Turn the knob to the the star/flame marking. Push the knob in, hold it for approximately 10 seconds. Release and check the small flame is lit. Now turn it to your desired heat setting.
Posted on Jul 21, 2010
Baxi he 24 solo. Local Gas safe Engineer has replaced pcb, condensate trap, overheat and other thermostat, also igniter/sparker and flame failure sensor, Boiler still intermittently locking out (red...
Sounds like its an intermittent flame failure on trial for ignition. Look for the pilot flame drifting away from the sensor when the main valve opens.
Nov 24, 2013 | Heating & Cooling
Have a Baxi solo boiler 340PF, have hot water but no heating, pilot light will not stay on. how do I fix it so I get heating please?
it might be the thermal coupler....it is a piece of wire that goes from the pilot to the thermostat. very inexpensive. .I am a 50 yr old woman, and I changed mine on my furnace twice..Home Depot or equivalent should be able to help. Google "thermal coupler"
Jan 22, 2013 | Water Heaters
WHY CAN I GET HOT WATER BUT THE RADIATORS WONT HEAT UP- BAXI SOLO 2PF SYSTEM?
check the pump see if this is working and the rads are open
Oct 05, 2012 | Heating & Cooling
Baxi solo pfl60 problem. the boiler has for some time been doing this - the fan starts normally when demand is present, then the pilot ignites, then it all shuts down. this happens repeatedly about 6 times...
One thing I would check is the flame sensor. Your boiler may not have this on it but I have seen them act like this before. If you have one I would replace it. Hope this is ofsome help. Thanks
Nov 26, 2010 | Heating & Cooling
Got a baxi bermuda 552, back boiler not working
Hi clean pilot light and change the thermocouple , you will have to remove the gasfire to get to the boiler if unsure best get a gas fitter to do this as this is not easy to explaine , simple job but you have to know what you are doing , it might be you need a service on the bbu and the gasfire then the thermocouple could be done at this time.
Feb 20, 2010 | Heating & Cooling
Heating only fires up for 5 mins and then cuts out plus you
its either your fan,pump,you need an electic continuity test to see if they are working.
ring baxi tech,they are great
or mail me
Jan 10, 2010 | M20 X-Treme Radar Detector
Dec 31, 2009 | M20 X-Treme Radar Detector
Sep 10, 2009 | M20 X-Treme Radar Detector
May 15, 2009 | Water Heaters
How to light pilot light on back boiler?
Hi. we have a baxi bermuda. I know that you need to hold in the silver button on the left while repeatedly pressing red/ignighter button until pilot is lit. Hold in the silver button for at least another 30 seconds.
Good luck, ours wont light anymore so was on here looking for advice.
Cheryl
May 07, 2009 | Kitchen Ranges
Heating & Cooling Logo
542 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
