Question about Ovens
Favorit electric stove, model no : BOA 099 BUILT IN OVEN. It's oven is tripping the ELCB.
3 Suggested Answers
SOURCE: Stoves Gas Oven
i am having the same problem but i have been told it is the cooler fan so i have ordered a new one,the fan unit requires running as it is linked to safety sensors the equal air preasure and if not equiled by the fan moter it cuts everything off and in my case it trips the mains power but may not in your case
Posted on Oct 05, 2009
  • 43014 Answers
SOURCE: The glass shattered on my Favorit BOA 099 oven door but apparently it`s discontinued ? Where do I source a new glass / door from ?
Only a suggestion. but a good glass company could make one for you jst take the door off the stove and take it to them. tempered safety glass can be cut to fit .
Posted on Jan 20, 2015
Jan 20, 2015 | Ovens
Everytime I try to push the sensor for bake, broil, or convection and "off" light up in the clock window and nothing happens. This is a thermador built in oven modelSMW272ZP. Any ideas why it started doing...
Hi, Check fuses on the stove. Check the breaker panel for correct breaker and if breaker has tripped.
Then you will have to ask a technision to look at it further. Good luck
Mar 17, 2014 | Thermador SMW272 Electric Double Oven
Circuit braker trips as soon as i switch oven on
It is possible there is a heavy short on the oven and so the circuit breaker cuts off the supply when the oven is switched ON.
You will need to disconnect the coils to the ovens one by one till it is confirmed of the shorted coils. A test of the coil also will indicate the fault. If this is a ELCB then the ground leak within the oven /poor ground connection of the outlet can also cause the issue. make sure there is no damping in the connections of the power to leak and trip the circuit.
Jun 17, 2011 | Smeg S1100MFX5 Electric Single Oven
Grill trips my electrics on Stoves 720EF
I had problems with tripping and it was a faulty RCB on the consumer unit. But it wasn't just one appliance causing the problem.
Have you isolated it to the top or bottom oven. If it is the main oven, then it could be anything associated with the operation of that component, i.e. the oven control knob,the oven thermostat, the element, the element fan, the overheat thermostat all could have insulation that is breaking down that could cause this problem.
Before you go and buy anything and if you have the time and patience and confident enough and know what you are doing, I would remove the oven from the cupboard, take off the top and back covers, note the wiring for the element, take the leads off the element and run the oven with the element disconnected and see what happens. That should prove whether it is the element or anything else.
BE CAREFUL.
Jun 06, 2010 | Stoves 720EF Electric Double Oven
Frigidaire gallery stove, oven not working,
Morison,
The same thing happened to me about a week ago. I was preheating our electric oven, heard a very loud bang/pop. Checked and the oven had PF (power failure) I went downstairs and the breaker was tripped. Came back upstairs and to look at stove, the burners are working fine so I continued to preheat oven after a half an hour the oven was only slightly warm. Did you ever find out what was wrong?
May 04, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Zanussi zbf260x built-in oven keeps tripping out
Probably due to a fault on the oven heating element. Check continuity and earth with a multimeter if you can but it's odds on you will need a new heating element.
Dec 26, 2009 | Zanussi ZBF260 Electric Single Oven
Element blew in oven; now stove doesn't work....
Sounds like the loose oven element caused a short circuit, which may have fried a wire inside the range. Or, it may have tripped the circuit breaker (or blown the fuse) for the range circuit. Check your electrical panel. If the circuit is open, don't reset it until you've removed the remnants of the oven element.
Sep 14, 2009 | Frigidaire Ovens
My oven wont work?
check your breaker to see if it tripped,sometimes the breaker will trip and one or the other wont work.meaning the stove top or oven.also check and see if their are any breaks or burn spots in bake element and your broil element.
Mar 12, 2009 | Frigidaire FEB27S5A Electric Single Oven
Electric stoves
if the model has a digital clock and when the power went of it may have fried the little computor.if you dont have trip switchs in fuse box
Nov 07, 2008 | GE JGRP17 Gas Single Oven
Stoves Gas Oven
Jul 07, 2008 | Stoves Premier 900GRa Gas Double Oven
Ovens Logo
44 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
