Question about Logitech Wireless Desktop MK320 Mouse & Keyboard Combo
How to Clean MK320 Keyboard
Keys sticking
3 Suggested Answers
rdpruitt
  • 39 Answers
SOURCE: Keys Sticking
no! you don't want to do that if you unscrew the back plate all the plastic suction cups with fall off and you will never be able to type on it, until you place the suction cups back what you want to do is get some WD-40 (the tool for fixing almost everything) or a can of pressurized air with a areosole top and aim it at the key or under it, press it and it will blow every piece of junk under the keys cleaning it.
Posted on Feb 09, 2010
Testimonial: "Yea, I resisted temptation. I ended up using Q-tips and rubbing alcohol. Had to cram the Qtip in between the keys. Took a few to do the job."
jharvey572
  • 447 Answers
SOURCE: My keyboard has some keys that are hard to press and they stick after being presswed. Can I clean them some how or is it toast?
not nessesaraly toast, from a pc mag, remove any batteries and wash in warm soapy water,then rince and leave in a warm place tn dry properly.if this works you still got keyboard if not it was toasted anyway.you got nothing to lose by trying.
Posted on Dec 31, 2011
Testimonial: "I went one step further. I figured it was toast anyway, so I grabed one of the offending keys with a needle nosed plires and pulled. It came out and I cleaned out some gook and it was fixed. I did the other offending keys and fixed them all. It now works fine."
How do I remove the keys on a Logitech MK700 keyboard to clean properly?
Try using simple flat-head screw driver. It should remove easily, but i don't think that'll solve your problem.You should pry apart your keyboard with screws and use damp cloth to clean the board, as well as rubber buttons. I'm not so certain about that, but you should try it. Dusan
Jul 09, 2014 | Logitech Wireless Access Duo Optical...
When typing on keys it put multiple letters
The keys are sticking. Has something been spilled on it? Try these things:
Compressed air under the keys.
A blunt thin knife to jiggle keys slightly, be careful.
A damp cloth.
Feb 16, 2014 | Kensington KeyFolio Pro 2 Universal...
Something is under my keyboard and keys are sticking, how to clean this
The keys on the keyboard should pop off easily with steady pressure from a corner of the key. It's probably best to have it unplugged and battery removed before attempting to clean it.
You can fix the troublesome keys with a dry lint-free cloth or a moistened Q-Tip rather quickly. Unless it is a large and/or sticky mess under the keys you should be able to clean them without cleaner. Only used cleaner meant for keyboards and electronics.
Make sure it is completely dry before powering you laptop up.
I also advise having a can of compressed air around, you can get it at any electronics store.
However if you would prefer to do a thorough job there is also a how-to here http://www.computing.net/howto/simple/keyboard/
good luck!
Jul 18, 2012 | Compaq Presario CQ56-115DX Laptop
I can not tell if the caps lock is on with my MK320 Wireless Logitecfh Keyboard. Help.
The Software included with your keyboard should show onscreen confirmation when you press that button, the numlock, and the function lock keys!
Aug 01, 2011 | Logitech Wireless Access Duo Optical...
How do you open the wireless mouse for the MK320 so I can change the battery??
To change the batteries in your Logitech MK320 desktop keyboard and wireless mouse, simply turn the mouse over. Move the on/off switch to the off position. Press the battery button and slide off the cover. Insert the batteries negative side first. Replace cover. Turn mouse on.
For a detailed visual diagram, click here:Logitech MK320 Suppport
Apr 04, 2011 | Computers & Internet
Sticking keys,mainly commonly used keys like ; - s , a ,u . e . all other keys okay !
What do you mean, exactly, by sticking? Do they not fire when you hit them?
Nov 19, 2010 | Smith Corona Wordsmith 200 Typewriter
Dora 204 SP Olivetti Typewriter I have an intermittent sticking returns key Causes paper to run on. Can I do anything about it, or can you tell me of a Service Centre in Hampshire n UK.
hello
take Q-tip cotton , apply small portion on hammer letter keys and carriage -- moving parts only
dip and smear into vasaline, wipe off excess. apply to the keys sticking or to carriage return key . this is amechanical sticking , so apply to where the part (carriage or moving part) applies. Also, take a plain paper , keep tapping the key and then return key carriage , until sticking stops and until the vasaline dissipates . repeat the typing for about 1-2 mintes until excess vasaline is no longer present on paper after typing.
repeat this process anytime the keys stick
hpe this helps
Nov 14, 2010 | Office Equipment & Supplies
Keys sticking
I don't know which keys are sticking, but if they do stick, it usually means it's time for a new keyboard. Desktop keyboards are relatively easy to clean. No so with laptops.
I'd be looking for a new keyboard. Try E-bay first for the best price.
Nov 03, 2010 | Acer Aspire 5735 Notebook
Keys stick on the keyboard T D V F IN particular.
If you use a laptop then the keys should be able to come off. You probably have something stuck underneath the keys. Get a small screwdriver and slowly prise the key off. give the key a good wipe underneath the key and on the connetion.
Mar 19, 2010 | Dell 0Y3740 Keyboard
Keys sticking. The keys at both ends are sticking or won't go all the way up and strike the paper.
Try trickling some White Spirit into the typebar slots and working the keys repeatedly.
Jan 10, 2010 | Olivetti Linea 198 Typewriter
Logitech Wireless Desktop MK320 Mouse & Keyboard Combo Logo
147 people viewed this question
Top Logitech Video Game Consoles & Games Experts
Lyle Siemens
Lyle Siemens
Rob boss
Level 1 Expert
Are you a Logitech Video Game Console and Game Expert? Answer questions, earn points and help others
