Question about Ricoh Aficio 220 Laser Printer
Ricoh Aficio 220 - Connection with computer
I would like to know how to connect ricoh aficio 220 to computer. I need proper driver and pc card.
    Sniper:
  • 86 Answers
Please use the link below and scroll down to choose your Operating system, and download and install the printer driver.
http://www.ricoh-support.com/enduser/downloads/downloads.asp?fileid=241&ricohmodelid=5&url=http%3A%2F%2Fsupport%2Ericoh%2Ecom%2Fhtml%5Fre%2Fmodel%2Faf22%5F27%2Faf22%5F27en%2Ehtm
Hope you have a printer controller type 270 installed on your Aficio 220, already.
It can be connected with a parallel cable or ethernet cable if you have a network card installed in the printer controller of the Aficio 220.
Good luck and please rate me, thanks.
Posted on Jan 26, 2009
Can i print from my computer with ricoh aficio 220?
Hi
Yes, you can connect it using a network, parallel cable or a usb cable.
Please let me know if you need more help and do not forget to rate this solution.
Feb 24, 2011 | Ricoh Aficio 220 Laser Printer
Use ricoh aficio 220 as network printer
If you have the print/scan option installed on the copier, just to go the Ricoh website and download the print driver, and you can use it as a network printer.
Feb 23, 2010 | Ricoh Aficio 220 Laser Printer
I need the module to connect to my computer. Is
When turn on printer. Doesnt clean. Comes up Refer Troubleshooting & REGULAR MAINTENANCE
Dec 01, 2009 | Ricoh Aficio 220 Laser Printer
I need the service manual for the Aficio 220
hello there here is several links that will help you out ok
best regards michael
  1. RICOH AFICIO 220 Service Manual RICOH AFICIO 220 - It's a complete service manual, and it's in PDF format. ... i got my service manual for philips vr685-02. Thanks a lot for my very clear and ...www.user-manuals.com/service-manual-RICOH-AFICIO220.html - 73k - Cached
  2. Ricoh Service Manuals - Copier Service Manuals Ricoh Service Manual/Parts catalog CD's for FT, NC, Fax, FX, Afico, AP, MLP, SLP, ... Ricoh Service Manual/Parts catalog CD's for FT, NC, Fax, FX, Aficio, AP, MLP, ...www.knowthesource.com/index.php?cPath=26 - 57k - Cached
  3. AFICIO 220 RICOH AFICIO 220 Owner's Manual ... for delivery information. Model: AFICIO 220. Type: Owner's Manual. Delivery: ... Manual received - Many thanks for an excellent service. Alain Fagan - 2006-04-11 ...www.manuals-in-pdf.com/55709-p-11284.html - 65k - Cached
Sep 14, 2009 | Office Equipment & Supplies
Ricoh Aficio 1027 network connection problem with vista x86
It will not work to directly connect a network cable directly from the network port of the printer directly to your computer. You will have to use a cross-over cable and configure your TCP/IP settings manually. However, to utilize network printing and have internet access, you will want to get a router and connect your modem to the ethernet port of the router, then a network cable from pc to switch port on router, and a network cable from printer to a differnt switch port on router. Most consumer routers have a built in 4-port switch, so that should allow enough connections. You may want to consult a local IT company or Ricoh dealer for the rest of the setup. This will allow the framework for network printing and/or scanning.
Jul 28, 2009 | Ricoh Aficio 1027 All-In-One Laser Printer
HOW to configure ricoh aficio 2032 on nework and install it on more than 1 pc. this printer is connected via ethernet cable to dlink switch, where my other pcs are conected. but i cant connect it on any...
You install driver for the Aficio 2032 on all computers where you want to be printed from it.
Then you will go to Printer driver properties and then need to be created port TCP/IP and write the address from the printer it's same as connecting a computer on network
Jun 30, 2009 | Ricoh Aficio SP C210 Laser Printer
Trying to scan w/ Ricoh Aficio SP C210sf
Could be a driver issue. Go to: http://www.ricoh-usa.com/downloads/software.asp?tsn=Ricoh-usa and find, download and install the driver for your Ricoh device.
Jun 11, 2009 | Ricoh Aficio SP-C210SF Printer
How do I connect a Ricoh Aficio 350 directly to personal computer
I believe the copier only has a tcp/ip port for connection, so you will still need to run it through a router, or if the PC is not on the internet, you can connect the machine directly to the ethernet port on your pc using a 'crossover' cable
You will need to download the Vista driver from Ricoh Here:
|http://www.ricoh-usa.com/downloads/downloads.asp?tsn=Ricoh-USA&path=http://support.ricoh.com/bb/html/dr_ut_e/rc2/model/x35_45/x35_45en.htm
Mar 23, 2009 | Ricoh Aficio 350e Printer
I need ricoh aficio mp 1600le driver, how do i get into.
Here is the driver page:
http://www.ricoh.com.sg/downloads/drivers1.aspx?path=http://support.ricoh.com/bb/html/dr_ut_e/ra/model/mp16/mp16en.htm
copy and paste the link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Nov 11, 2008 | Ricoh Aficio 1515MF All-In-One Laser...
Printing from PC to Copier with USB cable
The drivers might have a tough time recognizing a 250 as a usb device on your computer. There wasn't a USB interface created as an option on your copier. Does your copier have a network adaptor on it?
One idea that will work on your copier is a parallel print server either wired or wireless. I've done this for a few of my 220/250 customers.
Nov 05, 2008 | Ricoh Aficio 250 Copier
999 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
fares
Level 1 Expert
Michel
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
