Question about Emerson White 3.5 Cu. Ft. Chest Freezer
Emerson 3.5 cu. ft chess freezer lost power
Doesn't freeze the light is not on and I don't how long its been like this. I just noticed it today.
Haier 5.3 Cu ft Chest freezer. power is on but compressor doesn't run. There is click sound but nothing happens after.
The click sound is the compressor starter relay closing but if nothing further happens it is likely that there has been a compressor failure
Apr 11, 2013 | Haier 5.3 cu. ft. Chest Freezer HNCM053E
Emerson 2.8 Cu. Ft. doesn't automatically turn on after power outage
Check breaker. Was there a surge of electricity when the power went out. This may be a simple fix. Sounds like the breaker is tripped. Test the outlet with a light to see that power is to it.
Feb 04, 2013 | Emerson 2.8 Cu. Ft. Refrigerator - Silver
Not cooling
i've had that happen to me before it it might be the freon
Sep 14, 2012 | GE 3.1-cu. ft. 2-Door Compact Refrigerator...
Ffu20fc4cwo won't freeze food
Check power to and from the thermostat first
Sep 13, 2012 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Magic chef freezer temperature indicator light on, not usually on?
Is it a red light? If so it's not reaching temperature (the alarm is about -12c) If it's a yellow light, you've accidentally switched on "fast freeze". If it's a green light it's just the power supply light.
May 08, 2012 | Magic Chef 5 cu. ft. / 142 liter Chest...
20 cu ft freezer top 1 foot things don't freeze completely. Bottom 1 ft things don't freeze completely. But the middle 18 cu ft its frozen.
Gas is low, also check for air flow obstruction, this may fix it,,also seals at the base of the door....Russ
Aug 22, 2011 | Frigidaire Freezers
Have a Haier 5.3 cu.ft. about 1.5 yrs. old. It freezes ok and cycles off ok, but it doesn't cycle back on unless I tap it near the control. If it doesn't call for more cooling it won't cycle on...
The thermostat is bad....
You will need to replace that t-stat..
That is not that hard to fix and you can easilybuy the parts yourself online...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
Here is one site that I recommend http://ping.fm/zJDAM
heatman101
May 17, 2011 | Haier Freezer HUF168PA 16.8 Cu. Ft....
My haier 5cu.ft. freezer stop freezing
Sounds like the unit has quit, or check the wall outlet to insure there is power there.
Nov 23, 2008 | Haier 5 cu. ft. / 142 liter Chest Freezer...
Emerson White 3.5 Cu. Ft. Chest Freezer Logo
44 people viewed this question
Top Emerson Freezers Experts
Dennis Boxerman
AJMAL KHAN
John Tripp
John Tripp
Are you an Emerson Freezer Expert? Answer questions, earn points and help others
