Set for type of paper on printer
How do I set the paper type for making transparencies for overheads on my Canon Pixma ip 4300?
  • dorisfoster3 Jan 26, 2009
    Duh! I already knew that. It did not have a choice for transparencies. I discovered (and it will be good for you to know) that the 'photo paper pro' works fine and you do not have to clean the printer after you use it.
    Thanks for trying anyway.
    Sergeant:
  • 369 Answers
Right click go to properties of the printer and choose paper type
Posted on Jan 24, 2009
  • DUSHYANT SINGH
    DUSHYANT SINGH Jan 24, 2009
    right click go to properties of the printer and choose paper type
Which settings to use for transparencies?
Hi First it has to be a laser printer. search in the menu / common setting there is a paper type option select transparencies
Feb 20, 2016 | Canon PIXMA MG2520 Inkjet All-in-One...
How set set up type of paper (plain, photo,..) on my Canon Pixma MG 4150?
The type of paper is selected through the printer dialogue in the operating system. The "Control Panel" in Windows or "System Preferences" in OSX.
Jan 20, 2013 | Canon Pixma MP500 All-In-One InkJet...
Canon Pixma IP 4300 printer - 3 blinking panel lights indicate paper jam, however no paper jam is present. I turned off machine, pulled power plug, waited for 5 minutes, turned on printer, but problem did...
It is possible that the printer is having an error due to either a sensor fault ( optocoupler) in the paper detect section or a possible software issue.
So disconnecct printter, and uninstall the soft ware , the reinstall and then connecct printer to be detected and installed.
If the fault stays then the sensor must be checked.
Sep 11, 2010 | Canon PIXMA iP4300 InkJet Photo Printer
I have a lasser printer CANON LBP-5200 can I to print on photografic paper?, how many gr.?
Are you saying photographic paper or do you mean photoprint paper?
Yes, laser printer print just fine on photoprint paper. I use 20 lb or 22 lb bond. 18lb is a little light and is not usually photoprint.
If you mean overhead transparency, you have to try it. On some units the overhead transparency will melt a bit and wrinkle. You may need to try different makes of transparency. Make sure it says OK for laser printers!
Apr 17, 2010 | Office Equipment & Supplies
Can I print on transparencies with my canon mp150 ? If so, what settings/icc do I use?
Yes, but they need to be specially made ink jet transparencies such as this:
Amazon Inkjet Transparencies
Canon recommends their own CF-102 transparency sheets. Set paper thickness lever to the Left and the Media Type to Transparency.
See page 17 of the manual for a list of all Canon specialty papers. Here is a link to the manual:
MP150 Manual
Thanks for using Fixya.
Aug 30, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Can the Canon MX310 print on transparencies?
Manual does not mention Transparencies.
Manual states that It will print T-shirt transfers:
T-Shirt Transfers TR-301
This paper is used to create iron-on transfers. The image is printed inverted.
Paper Support Load Limit: 1 sheet
Paper Output Tray Load Limit:
We recommend that you remove the previously printed sheet from the Paper Output Tray before continuously printing to avoid blurs and discoloration.
Paper Thickness Lever: Right
Media Type:
Printer Driver Setting: T-Shirt Transfers
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
May 16, 2009 | Canon PIXMA MX310 All-In-One Printer
Paper settings
When you change the settings do you hot then 'OK' button to see that the astix is next to it ? When changing settings make sure that you see that astrix next to your changes if not you will return to it's original setting. I alreaded assumed you knew how to access the menu's Make sure you set these setting by"OK" some printers like "Xerox" will make you hit the "Select" key
Mar 04, 2009 | Lexmark C522n Laser Printer
How do I print with transparent paper?
make sure you are using transparencies made for your type of printer. eg:...DO NOT use laser transparencies on an inkjet. and visa versa...
You dont say what kind of printer you have so I cant help too much. Let me know what type of printer you have....make ..model...etc...
and what software you are using.
rick
Feb 16, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Canon ip 4300
Google "canon ip4300". The canon.com entry near the top has a support tab. and enter "paper skew", you'll get a roller cleaning procedure.
As a matter of fact, it didn't solve my problem. The alternative, of having the machine repaired, is, of course, silly vs. buying a new machine. But in the meantime, the lower paper feed still works, albeit slightly less convenient.
Apr 22, 2008 | Canon PIXMA iP4300 InkJet Photo Printer
144 people viewed this question
k24674
jasbo
jasbo
