Question about Maytag MAV3905EWW 13 Cycle Washer
Maytag dryer does not spin
Checked power supply and tried different settings--does not spin.
    Top Expert:
  • Maytag Master
  • 34,177 Answers
Broken belt? Stretched belt that has fallen off drum?
Posted on Jan 16, 2013
2 Suggested Answers
SOURCE: washer stopped working??
Just to follow up, it was the fuse that caused my problem. Hope this helps someone else!
Posted on Mar 31, 2008
I have a may tag performa gas dryer. When I start it, it spins and heats but it spins very slow. I opened the top and checked the belt and it was tight and does not appear to be slipping. Is the motor...
  • There are a number of different problems which can occur with models of Maytag dryers resulting in them not heating and drying clothes properly. A variety of parts could have broken or been worn out over the course of the time you have been using your dryer or something could just malfunction, as appliances tend to do from time to time. Check warranty information before trying to repair the Maytag dryer yourself.
  • Bad Heating Element
  • Most clothing dryers heat up and dry clothes with a heating element inside the appliance's body. Maytag dryers are no different and sometimes these heating elements break down or burn out, making the dryer cease to get hot. Make sure the dryer is unplugged and the breakers that run the dryer are switched off before inspecting so you don't electrocute yourself. The heating element is in the bottom panel of the dryer and is often a silver part which heats up when the dryer is on. Sometimes the heating element will be cracked or burned out, which means it is broken. Other times it won't look damaged but may not be working. Replace the heating element if this occurs, to see if this is the main problem.
  • Broken Motor
  • Maytag dryers have motors which turn the dryer drum, tossing the clothes so that air and heat can help dry them out completely. When the dryer drum is not turning it means there is something wrong with the motor or that the motor is not getting power. Unplug the dryer and take it apart to inspect the motor. Once you have found the motor, plug the dryer back in and use a meter to see if the motor is getting power. If it is, and isn't working, then there is something wrong with the motor and how it is operating. If the motor isn't getting power, then there is something wrong with the circuits or fuses which disperse power to the motor itself.
  • Bad Switch
  • When Maytag dryers won't tumble or heat the clothes which have been put inside of them, this means there could be a number of different things wrong. However, sometimes there's a simple solution to this problem: The switch on the door of the dryer itself may be faulty or not making the electric connection it should to allow the dryer to run. This is a cheap fix and worth troubleshooting before tearing your Maytag dryer apart. Remove the switch and inspect the two leads to make sure they haven't broken or are still transferring electricity. If they aren't you will have to replace the switch.
  • please stay how helpful it
    Dec 21, 2010 | Dryers
    I have a Maytag lsg7804aae stackable unit. The problem I am having is that the washer will not agitate or fill with water, however the unit will work on the spin cycle in all modes. Opened front panel of...
    timer is good, if you tried it on all the different cycles, must be the water inlet valve, does the hot water work, if you set to warm or hot..if so the cold water valve is shot
    Dec 19, 2010 | Maytag LSE7806A Top Load Stacked...
    Ihave maytag stackable the dryer works but washer stoped with water in it now the washer will not do any thing. i checked voltage at the harness coming out of control button and i have 110 volts at the...
    How many wires go into the lid switch?
    If there's only two wires, short or connect them together and wrap the connection with electrical tape.
    Then put the timer/programmer on the spin cycle and try if the water drains out and the machine goes to the spin phase.
    If this works, then you have a defective lid switch/ lid locker
    Nov 03, 2010 | Maytag LSE7806A Top Load Stacked...
    My dryer is not heating,we have checked all of the settings, and the barrel is spinning so can you please help, the unit is about 4 yrs.old I have a maytag neptune
    check ur breaker first, dryers will run on 120volts but wont heat unless have 240.
    if electric check ur heating element, thermostats, and thermal fuse for continuity with a meter.
    if gas check the ignitor,thermal fuse, and secondary gas coils,
    Feb 05, 2010 | Maytag Dryers
    No power at all. checked circuit braker, made sure door closed, cord is plugged in.
    Check fuse near power supply. If fuse and relay are good, try playing with door switch. If no difference, than the power supply itself will need to be changed
    May 13, 2009 | Maytag PYE2300AY Electric Dryer
    Dryer does not heat... clothes only air fluff, not dry
    sound like the heat coil is broken or burnt out..you can get one at an appliance parts supply store...but the only way to get it in is to take apart the dryer it is the back of the dryer that containt the heat coil...
    Feb 16, 2009 | Maytag Dryers
    NO POWER TO DRYER???
    Hi there, you are experiencing a power supply board failure. this board may have used all its life up and unfortunately, it will have to be rebuilt or replaced.
    Feb 05, 2009 | Maytag MDE9700AYW Neptune 174 Electric...
    Washer stopped working??
    change the pressure switch its the switch that you select the water level with
    Mar 18, 2008 | Maytag LSE7806A Top Load Stacked...
    Maytag MAV3905EWW 13 Cycle Washer Logo
    164 people viewed this question
    Top Maytag Washing Machines Experts
    Bill Long
    John Tripp
    John Tripp
    Dan Webster
    Dan Webster
    Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
