The printer ink does not flow thru the filters in the printhead housing. it seems that the residual inks have dried up and blocked the filters / little pockets that the heads of the ink cartridge sit in wile loaded in the printer. Is there a fluid that will dissolve the dried inks ?
    Sergeant:
  • 369 Answers
Please go to controll panel and choose faxes and printers and select your brand of printer showing there and right click and go to properties and u will find a printer priferences tab and can to manatanenece like clining the nozel and hed etc and should fix the ink flow
thanks
Posted on Jan 24, 2009
Epsom print EX-200 wont print after l changed the ink cartridge
Did you pull the tape off the top of the ink cartridge?
Oct 17, 2015 | Office Equipment & Supplies
How do I fix my printer it prints blank sheets it acts like its printing but the paper is still blank I did nozzle and print head checks nothing still blank
I hate to state the obvious, but how long has it been since you've changed the ink cartridges on the printer. If you have done both the nozzle cleaning and print head alignment and nothing appeared on the paper, I don't know what else it could be.
This following suggestion is very rare - if you recently replaced the cartridges and your printer hasn't printed since then, it is possible that you installed them incorrectly; OR perhaps you left the head protector tape on the cartridge. But then it wouldn't "see" the cartridge.
In the "rare" situations, you should try to remove and replace the cartridges to assure that they are properly installed.
Mar 05, 2015 | Epson Stylus CX6600 All-In-One InkJet...
The printer has been sitting and never used. all hooked up and paper comes thru with nothing. thanks if u can help.
Hello hol0,
If the printer has not been used the ink cartridge may be dried/clogged. This happens when ink does not flow for long periods of time. The cartridge may be full of ink (therefore, not giving low ink level warnings) but unable to flow due to clogged pathways. Try a new ink cartridge and that should fix your problem!
Hope this helps!
Jul 01, 2011 | Canon PIXMA MP210 InkJet Printer
Canon MultiPass MP730 purchased 2004 NOT Printing Black INK- did: new canon ink tank inserted (never used refills) ran: printhead maintenance mannually cleaned print head w/ rubbing...
You could clean the black ink cartridge. For this you need to remove the black ink cartridge which is present in the printer. In order to clean the laser or scanner block you could use a cotton swab as it would fully clean the dirt. You need to clean the grime and the dried ink present in the printer. This would remove all the hindrances which prevent the ink from flowing. Cleaning the printer heads would also help to solve the problem.
Dec 02, 2010 | Canon Office Equipment & Supplies
Why isnt printer printing full page, only printing every second line, has ink dried up in cartridge? do I need to clean some heads or something??
Yes flush it!
Flushing the print head of the cartridge directly from the tap water
1. Open your printer cover
2. Remove the cartridge
3. Place the printhead directly on a tap water running slowly. This will help flush the dried ink that clogged in the printhead.
4. Turn the printhead over, bottom side up until you see the ink flowed out from the printhead, do this until you see the a smooth flow of ink..(better result if the water is warm)
5. Tap water contains residual minerals that can clog also the printhead..so it is advisable to final flush the printhead with a distilled water (it has no impurities) and dry it with cloth..
6. The last thing to do and it will take you sometime is to soak the printhead portion of your cartridge in a mixture of ammonia and hot distilled water, (please make sure that the contact point of the cartridge to the printer is not soak).. Place the printhead on the hot water and leave it there for about 4 to 5 hours..move it on different location from time to time..After soaking, rinse it with distilled water and dry it with cloth...
After doing the instructions, return back the cartridge to the printer and do the printhead alignment..
Try printing a test page and see the outcome...
Sep 25, 2010 | HP Photosmart 2575 All-In-One InkJet...
Have ink, but its not printing. the paper is doing the right thing ,but not putting ink on paper
Please make sure that the print head is not clogged. The ink can flow out easily from the print head. How do you know if there is no dry ink clogging the print head? Remove the cartridge and run the print head in a soft smooth paper, see if the inks was left in the paper proportionally. If no ink marks then its clogged.
flushing the print head of the cartridge directly from the tap water will help ....Open your printer cover, remove the cartridge..place the printhead directly on a tap water running slowly. This will help flush the dried ink that clogged in the printhead. Turn the print head over, bottom side up until you see the ink flowed out from the printhead, do this until you see the a smooth flow of ink..(better result if the water is warm).. tap water contains residual minerals that can clog also the printhead..so it is advisable to final flush the printhead with a distilled water (it has no impurities) and dry it with cloth..
If you find this information very helpful, would you be kind to rate this solution. Thanks
Aug 18, 2010 | Brother MFC 420CN All-In-One InkJet...
I have an iP4500 Canon and I have trouble with the ink
Hi!
There are different possible and safe ways to clear the clog in your cartridges..
The basic steps is to clear the clog using the printers software utility that is installed in your computer...how? on your control panel..double click printers and faxes, when your printer icon appear.. right click on it and click properties to bring up the utility..on the maintenance service tab...press the button for cleaning the cartridge.
the second thing to do is flushing the printhead of the cartridge directly from the tap water ....Open your printer cover, remove the cartridge..place the printhead directly on a tap water running slowly. This will help flush the dried ink that clogged in the printhead. Turn the print head over, bottom side up until you see the ink flowed out from the printhead, do this until you see the a smooth flow of ink..(better result if the water is warm).. tap water contains residual minerals that can clog also the printhead..so it is advisable to final flush the printhead with a distilled water (it has no impurities) and dry it with cloth..
If you find this information very helpful, would you be kind to rate this solution and vote below.. thanks..
Jun 01, 2010 | Canon Pixma iP4500 InkJet Printer
Why wont the colors print out dark i even replaced the ink already. still nothing i have only owned it for like 6 months
Sounds to me like the printhead needs to be cleaned out, it has ink residue on it from the other cartridges you had in there. Page 47 in the manual for your printer explains how to remove the printhead from the printer. Here is the link to the manual for your printer: http://www.kodak.com/global/plugins/acrobat/en/service/manuals/AiOPrinters/5100AiOPrinterUG_EN-US.pdf Inside of the printhead you'll see holes where the ink cartridges are normally above. Those holes need to be cleaned out. I suggest you soak the bottom of the printhead in some warm water overnight. This will enable for the ink residue to fade away and then you can take out the printhead from the warm water and dry it all off. Put it back into the printer with the cartridges installed and then print a few diagnostic pages to give the ink a chance for it to flow properly.
Jun 11, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
k24674
jasbo
jasbo
