Question about Vizio VO Televison & Video
Power supply What does the power supply on the E71VA look like and where is its location?
  • Vizio Master
  • 933 Answers
You listed the incorrect model # is it a E371VA? The power cord should lead you to the power supply board. The 3 prong cord plugs into the power supply. Power supplies are usually either on the lower left corner or towards the middle of the set.
Posted on Jan 16, 2013
  • Russell Jan 16, 2013
    Yes E371VA The Vizio logo lights up but no picture no sound no menu nothing
Fuse locations vizio e470vle
The fuse will be located on the power supply board. The power supply board is the one that the power cord plugs into. The fuse should be close to where the power cord plugs in at.
Dec 06, 2012 | Vizio E470VLE 47 Class Widescreen LCD HDTV
Where are the fuses located on a 37 inch flatscreen magnovox?
The fuse can be located on the power supply board. To locate the power supply board, trace the TV wire back into the TV. The area where the TV wire is soldered inside the TV is the power supply board. There is fuse on the board. So this means you have to disassemble the TV....
Regards.
Walesarumi
Sep 28, 2011 | Televison & Video
Black screen no sound
You have a bad power supply...do a search online at Google, Ebay, or Shopjimmy.com and match up you numbers from your power supply. Requires taking off the back of the set and locating the power supply (located by tracing the AC plug (from the wall socket wire)) and unscrew and unplug the power supply.
Jun 02, 2011 | Sanyo DP46849 46 in. HDTV
Where is the power fuse located
fuse is located at the power supply section.to get to the power supply you need to remove the back cover of your monitor..after you remove the cover you can see the power supply..and the fuse is place on the pcboard and there are two fuses the primary fuse and the secondary fuse....be careful when replacing the blown fuse...do it only once once you replace the fuse and blown again there is a problem on your power supply...replace your power supply with a new one...
hope this could help you...goodluck!
your rate is important to this help tnx..
May 11, 2010 | ViewSonic N2751W 27 in. LCD Television
Fuse for gx150 power supply
The fuse is located inside the ATX switch mode power supply and it is solder onto the circuit. There are dangerous voltages inside this power supply. I suggest you get a new switch mode power supply because failure of a component inside the power supply has caused the fuse to blow and replacing the fuse would most likely not fix the power supply.
Apr 03, 2010 | Dell Computers & Internet
Cannot locate the fuse in the liteon power supply
The fuse is internal, and soldered to the circuit board. It can be replaced by soldering - an old-timers trick is to get a new fuse (with pig-tails) and just solder in parallel with the old - no removal needed.
Jan 31, 2010 | Lite On LiteOn 150W LPX Power Supply...
Need power supply for Hp 336044-B21 KVM Switch. (DVE Switching Power Supply, Model DSO-142L) in the last two month I lost three same switches with the same problem - power supplies...
There are a few things that you can do. First; try to go online to HewlettPackard.com and locate the power supply. Second;go online to ebay and search for the power supply. Last;locate a Batteries R Us store in your city. They have a huge supply of batteries and power adapters. If you do not find a HP adapter the store person can help you find one that is complimentary to your HP adapter.
May 29, 2009 | HP 336044-B21 8-port KVM Switch
I plugged the printer into 220 volts inlet ,burned power supply
Cheaper to replace the machine than buy a power supply - unless you find a parts machine somewhere.
Mar 21, 2009 | Brother MFC-5840CN All-In-One InkJet...
Power Supply Bestec ATX-250-12E Rev.P6
Normally if you open the PSU up warranty will be void. ( if it's Under Warranty). if not once you open the unit the fuse's are located right nest to the power input.
Jan 01, 2009 | Gateway Emachine Bestec ATX-250-12E PS...
Televison & Video Logo
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
