Question about Texas Instruments TI-83 Plus Calculator
How do I rise a value to a power in a TI 83 plus?
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Texas Instru... Master
  • 102,366 Answers
Use the ^ key just above the divide key. For example, to raise 2 to the third power, press 2 ^ 3 ENTER .
Posted on Jan 16, 2013
Testimonial: "Thank you. I was looking for the "x to the y" key like in my former calculator, but the TI-83 uses the ^ key."
SOURCE: TI 83 Plus
linear correlation coefficient where y-axis and x-axis is the same and r=.946
Posted on Oct 06, 2008
SOURCE: TI-83 Plus 1 and 0 keys will not work
Thanks, a new one is about to be bought I think?...
Posted on Oct 23, 2008
  • 8 Answers
SOURCE: TI-83 Plus calculator--fractions
just type it in, e.g. 1/2 or 3/5. if you want to have answers display as fractions, press [MATH] ENTER.
Posted on May 08, 2009
  • 1126 Answers
SOURCE: how to set up four decimal point for TI-83 plus
Do you mean four places behind the decimal point? Page 21 describes setting for fixed decimal point 0 thru 9 places to the right.
http://education.ti.com/downloads/guidebooks/graphing/83p/83m$book-eng.pdf
Posted on Nov 24, 2009
  • 7993 Answers
SOURCE: ti-83 plus ram cleared message when turned on
It calculator tells you Ram Cleared each time you turn it on, the most likely reason is that the backup battery is depleted. Its role is to keep the memory modules electrically refreshed when calculator is turned off. If the backup battery is dead, the memory is erased when you turn calculator OFF. Main batteries no longer supply power and the contents of the memory are cleared.
  1. Check that main batteries are good and inserted in calculator.
  2. Turn calculator OFF.
  3. Replace the backup battery.
  4. Turn calculator ON.
  5. Press the [CLEAR] key to erase the "Ram Cleared" message.
Posted on Jan 21, 2010
Every time i press graph on my ti 83 plus it says ERR:Window Range 1:Range how do i solve this problem so i can graph
You will have to hit the window button on the face of the calculator that is just below the screen and change the values making sure the max value is larger than the min value.
May 02, 2011 | Texas Instruments TI-83 Plus Calculator
Where is the exponent button on a TI-83plus calculator?
To enter a power of ten, use EE, which is the 2nd function of the , key just above the 7 key. To raise a value to another value, use the ^ key just above the divide key.
Nov 14, 2010 | Texas Instruments TI-83 Plus Calculator
How can i get a negative number with my texas instrument TI 83 plus in the Finance application (for present value number)?
Use the (-) key next to the decimal point to enter negative numbers. - is to subtract one value from another, (-) is for negation.
Sep 15, 2010 | Texas Instruments TI-83 Plus Calculator
I ask my TI-83 Plus to calculate (-64)^(3/2) The TI-83 Plus says the answer is -512i, but I think the answer should be 512i. Is the calculator wrong or am I?
You're both right, in a way. (-64)^3 is -262144. The square root of that is +/- 512i. Take your choice as to the sign.
For what it's worth, the TI-84, TI-86, TI-89, and the HP 50g all go with the negative value.
Jan 24, 2010 | Texas Instruments TI-83 Plus Calculator
TI-83 Plus will not let me view a table
I have just done what you said you had done, but I got a nice, correct table of values. You might have discoverd a secret command to clear memory.
Cheers.
Apr 14, 2009 | Texas Instruments TI-83 Plus Calculator
TI-83 countdown
Pressing 2nd then the up or down arrows is how you change the contrast on the TI-83. All you need to do is press the 2nd key then hold the down arrow to get your screen back. The countdown that you saw was just the value the calculator assigns to the contrast. It goes from 0-10.
Hope that helps!
Jan 18, 2009 | Texas Instruments TI-83 Plus Calculator
Find the antilog on the TI-83 Plus for finding pH in chemistry problems
I reccently had the same problem, but I have a Ti-84 Plus,and I am disgusted by how poorly this matter is covered by Texas Intruments. Esp. since the solution is rather simple.
The antilog key is [2nd] [log] or the 10^x. On your screen it should apear as 10^( and then you just input the value that you want to find the antilog of.
When used to solve pH problems remember to input the pH value as a negative number, since pH= -log[H+] then [H+]= antilog(-pH).
Hope that helped))))) ^^
May 10, 2008 | Texas Instruments TI-83 Plus Calculator
Future Value
The example found on Texas Instruments Knowledge Base will demonstrate how to calculate future value on a TI-83 Plus.
The Knowledge Base can be accessed by clicking on the URL below:
http://epsstore.ti.com/OA_HTML/csksxvm.jsp?nSetId=68565&nUsePub=NO&jttst0=6_23871,23871,-1,0,&jtfm0=&etfm1=&jfn=ZG9FB38B4A2AA5FD2B95856A86C456B04891A1DF1818254BD8745136644414BBD77A84F7D2D719EC988ABF354C41ACA7922D
Jan 31, 2008 | Texas Instruments TI-83 Plus Calculator
TI 83 Plus
The examples listed on Texas Instruments Knowledge Base will demonstrate how to compute the NPV on your TI-83 Plus.
The Knolwedge Base can be accessed by clicking on the URL below:
http://epsstore.ti.com/OA_HTML/csksxvm.jsp?nSetId=71547&nUsePub=NO&jttst0=6_23871,23871,-1,0,&jtfm0=&etfm1=&jfn=ZG06CD0B03AAAF941AFC19C76DA52265118B53A25EFCD6CCEA4B0892BBD7051726DCA9C647310C32EA7E6FB7570A304971B4
Jan 16, 2008 | Texas Instruments TI-83 Plus Calculator
Texas Instruments TI-83 Plus Calculator Logo
42 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
