Question about Measuring Tools & Sensors
Dial calipers .06 off from zero
I am trying to reset dial calipers to zero - currently off .060"
If your handy, buy a hand remover and reset the hand. This is done after popping off the bezel, but this is for generic brands. Different brand have different ways of removing the hand and dial face, such as the brown and sharpe. Be careful and you will never see you tool upside down again.
Posted on Feb 28, 2009
  • 3 Answers
With the caliper set to zero, you must turn the dial body to set it to zero. This should be done every time before the caliper is used.
Posted on Jan 25, 2009
How do you set a 722 starrett digital caliper to zero.
Just ran into the same problem. Bought a caliper at a garage sale and it needed new batteries. When i put them in it was reading .006. I held the M button down for 2 seconds and it reset to .000
Jun 16, 2012 | Starrett Electronic Caliper
I HAVE A MITUTOYO 6 INCH ELECTRONIC CALIPERS,MODEL # CD-6 CS. IT NO LONGER CAN SET ITSELF TO ZERO WHEN THE JAWS ARE CLOSED AND IN THE ZERO POSITION. PRESSING THE ZERO ABS CODE FOR 2 SECONDS AND THE...
The answers above by Kerry Littleton have nothing to do with our calipers. The answer above by Bob Pulver is well-intentioned but doesn't address the real issue.
The real issue is the ORIGIN button is little-used and a bit reluctant to "make". The solution is to use a blunt plastic probe to REALLY PUSH down the button and hold it. The caliper will reset to zero.
Dec 24, 2010 | Mitutoyo Dial Calipers
The face on my dial calipers is turned 90 degrees to match up to 0. How do I adjust it to be correct and readabel?
There should be a small set screw you can loosen by hand and adjust the face of the dial to zero with the jaws closed....this is typical of most calipers...it allows you to zero the dial on a given thickness of material and only read variations based on that thickness.
Take care.
Dec 09, 2010 | Mitutoyo Dial Calipers
How do you rezero a 505-637 mitutoyo dial caliper
Fully close the caliper. The pointer should be pointing about straight up or close to it. Losen the knurled screw which is located on the circumference near the bottom. Now grab the dial and turn until the zero lines up with the needle. Re-tighten the knurled screw.
Dec 03, 2010 | Mitutoyo 0 150mm X .02mm Dial Caliper
Trying to factory restor my lg 9800 but dont have security code since I bought phone used how can I reset to erase all the previous owners **** ?
1 - Open the Flip
2 - Press MENU >> Then ' 0 ' [ zero ]
3 - At the Service Code prompt enter six zeros
4 - Choose option 12
Phone should REBOOT and RESET to Factory Defaults... But, if you want to go to the pre-activation stage, that's a different process...
1 - Flip Open, Press Menu
2 - Press 0 followed by 000000 [6 zeros at the Sevice Code Prompt]
3 - Choose Option 1 [ Service Program ]
4 - Click the OK soft button [brings you to the * Phone Number (MDN)* screen]
5 - At that screen enter 10 zeros - to replace your current phone number
6 - Click the OK soft-button
7 - At this screen repeat step number 5
8 - Now click END
Phone will REBOOT by itself and the screen will now display " Initial Programming Required " - This is what the Sales Rep sees when he/she opens the box and boots the phone the very first time to program it to your account
Nov 25, 2010 | Cell Phones
My caliper is .030 off of zero I don't know how this happened . How can I fix this problem
Just loosen the screw that clamps the dial in place, close the jaws, and turn the dial to zero. Then tighten the screw clamp
Sep 18, 2010 | Mitutoyo Dial Calipers
Fowler 12" dial caliper measures 0.025 when shut, how do I zero
There should be a small thumb screw near the dial that you loosen to turn the dial to zero it, then re-tighten the thumb screw.
Apr 27, 2010 | Fowler Shockproof Dial Caliper - 0 - 6"
I zero my caliper and go out an inch and then close and it is rea
The dial and needle are not aligned properly. I have several calipers (all vernier) which were past down to me from my father. Some are almost 75 years old and still measure +/- 1000th! I'd go out and get a good old fashioned caliper.
Feb 17, 2010 | Mitutoyo 505 677: Test & Measurement...
How to reset zero position reading on a mitutoyo 505 629 dial caliper?
unless they have changed them there is asrew like a watch winder on the dial it self ,undo it slightly and turn the dial to the desired position then retighten the screw
Nov 08, 2009 | Mitutoyo 505 677: Test & Measurement...
Measuring Tools & Sensors Logo
683 people viewed this question
Top Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
