Question about Cuisinart DCC-1200 Coffee Maker
Have gone through the instructions..set the time of day...should there be a light so one can see what time it is..
    Top Expert:
  • Cuisinart Master
  • 39,039 Answers
If you are referring to an AM or PM indication, yes there should be one
Posted on Jan 16, 2013
La crosse atomic model wt 8005 clock instructions
The WWV broadcast is not really strong in some locations, so if things have changed in your area, like the location the clock is in or addition of items that produce interference like flourescent lights, change them back to the way they were. If that does not work try setting the clock near a window for several days and see. If you dont get synchronized time then the receiver in the unit may have gone out.
Jan 27, 2014 | Home
Brinks 42-1009 ez vacation timer instructions
The Brinks 42-1009 EZ Vacation Timer is preset with 7 full days. You cannot choose when it goes on and off.
To set, spin the dial (clockwise only) until the arrow in the upper right of the center face is near the current day and time. Plug everything in and switch the upper tab to the right. On certain days, it will turn on in the early morning as well as evening or late night.
You cannot choose when to turn the light off. However, if you are home, you can turn the light on by switching the upper tab to the left. Remember to switch it back to the right in order to activate the timed on/off periods.
Jun 10, 2012 | Hampton Technologies Brinks Timer
Problem #1. On model #DT300 the instructions under Set Time of Day # 3 does not change the day. The only place I can get the day/s to change is under the programming. What is wrong with it. I have...
Thank you for very clear question, and timer identification.
1) I don't have repair for defective timer.
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#DT300
http://waterheatertimer.org/pdf/DT300-series-manual.pdf
2) Choose DT300 format
#3 says to press-and-hold CLOCK button until display shows 24H or 12H
Then release CLOCK button.
Next press HOUR button to select either 12H or 24H
This lets you choose am-pm format -or- choose military-time format where 11pm is 23
3) Set current time
Press-and-hold CLOCK button throughout whole current time setting.
Do not release CLOCK button until current time settings are finished.
Next, press HOUR button, and then MINUTE button, and then DAYS button until current hour, minute and day display.
If this step does not work, then timer has gone bad.
Replace with locally available Utilitec 155671 from Lowes or Westek TE06WHB from Target
http://waterheatertimer.org/Woods-timers-and-manuals.html#59377
4) How to set DT300 timer program for full week of operation.
Each program requires you to set program 1 ON time and program 1 OFF time
Be careful to avoid program conflicts and overlaps so timer works as expected.
For program 1 ON time, you press PROGRAM button until 1 and ON display.
Release Program button.
Then select hour, minute and days. In this case you want all days of week, so you keep pressing DAYs button until whole week displays: Mo Tu We Th Fr Sa Su
Then you set program 1 OFF time, you press PROGRAM button again until 1 and OFF display.
If you set ON time for all days of week, and OFF time for Tu Tuesday, then timer will not work correctly.
5) Read manual and add a comment for additional help
Aug 18, 2011 | Hardware & Accessories
Timer has worked in the past as programed. However, upon resetting timer to correct time of day then setting "ON" & "OFF" porch light seems to come "ON" two hours...
I test timers.
Timers go bad.
EJ351 has 1 year limited warranty.
Wiring is correct or timer would not operate.
Bulb is good.
I would reset timer again and re-program.
If timer still will not function, then timer has gone bad.
Following page has manual:
http://www.intermatic.com/products/timers/consumer%20indoor%20timers/in-wall%20timers/ej351c.aspx
Reset instructions: Move the control lever to the OFF-CLEAR position for about
20 seconds. The red indicator light will go off and any previous
time settings will be cleared from memory.
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you via e-mail while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Feb 23, 2011 | Intermatic Programmable 24 Wall Switch...
Utilitech model 0141224 wall switch timer. used on outdoor lighting to set up to 7 on/off cycles each day. im trying to turn on my porch light in the evening and off in the morning. there are NO...
As luck would have it I'm 60, and learned how to program your 0141224 wall switch timer.
You can see instructions with big print and pictures on following page.
Press CTRL key on keyboard and use scroll wheel on mouse to make web print bigger.
http://waterheatertimer.org/Program-wire-Utilitec-LW60418.html
Add a comment any time.
You have wired your timer correctly and the lights turn on when you push on-off button.
If lights do not turn on, we need to review the wiring.
Your timer looks like photo below.
I'm going to parrot back the manual with some extra words.
To start, press the reset button and clear any programming
Programing overview:
Each program has ON time ... and OFF time
So you set program1 ON and then set program1 OFF
When you set program1 ON, you choose the Day, hour and minute you want program1 to turn ON.
And then you set program1 OFF, and choose Day, hour and minute for program1 to turn OFF.
Your ON-OFF times for program1 should be on same days.
For example program1 ON for all-days-of-the-week, but program1 OFF is for TU Tuesday, then timer will not work.
IN this case, program1 OFF should also be set for all-days-of-the-week.
Let's start.
Setting the clock:
Press and hold CLOCK button
Keep holding CLOCK button and press DAY button until display shows current day (MO TU WE TH FR SA SU)
Press Hour button until current hour with am pm displays
Press MIN button until current minute displays.
Release clock button and current day and time show on display
At no other part of instructions do you press and hold one button while pressing other button.
Setting programs:
Press PROG button until "1" and 'ON' show on display
This is program1 ON
Press DAY button to choose which days for program1 ON.
You can choose: all-days-of-the-week and MO TU WE TH FR SA SU show on display
Choose individual days and MO or TU etc shows in display
Choose weekdays MO TU WED TH FR
Weekends SA SU show in display
Next step
Press HOUR button to select hour for program1 ON
Press MIN to select minute for program1 ON
Now program1 ON is ready, next, you will set program1 OFF
Press PROG button until "1" and 'OFF' shows on display
This is program1 OFF
Press DAY button to choose which days for program1 OFF.
( Remember, you want same days for ON and OFF)
Press HOUR button to select hour for program1 OFF
Press MIN to select minute for program1 OFF
Now program1 ON and OFF are ready, next, you will set program2 ON by repeating same steps above.
You can set up to 7 programs.
If you don't want to set program2, or any more programs, that's fine.
To exit programming and save your program, press CLOCK.
Now current time shows in display.
Final step: set MODE
Press MODE button until AUTO shows in display. You want AUTO for programming to operate lights. That's it, timer is ready.
If you're going on vacation, press MODE button until RDM shows in display, and then timer turns lights on-off at random
Copy and save these instructions to your computer so you have them next year.
Dec 04, 2010 | Intermatic Inc. ST01C Digital In-Wall...
I have a HB88RC Intermatic 7 day / 7 event timer. I have followed the "easy set instructions" I have program 1 set to turn on X-mas lights at 4:30 PM and go off at 11:30 PM. For all seven...
Just program it as noted previously and put the timer in Auto. Set the clock to 1 min BEFORE your earliest timer program is set to come on. When the clock hits the correct time, it will turn on. Then set the clock to the correct time and you're golden.
Dec 03, 2010 | Intermatic HB88RC - 7-Day Programmable...
I'm trying to set the times on a paragon amf 7 day timer
There should be 2 trippers for each day, the trippers slide on the outside of the dial and would point to the time of day you want your lights on and off. The silver trippers may be gone on that aged time clock, but are easily obtainable.
Jan 14, 2010 | Paragon Amf 7008-00 Timer 7 Day 120 Volt...
Time keeping.
Check in the instructions about the time zone setting and that the feature for auto day light savings are turned on.
If you go to the manufacture site for many of these watches, they have downloadable PDF instructions. They also have service centers that can give support.
Jerry G.
Mar 18, 2008 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
Cuisinart DCC-1200 Coffee Maker Logo
Top Cuisinart Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
880runner
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
