Question about John Deere Garden
John deere la125 sputters when started - John Deere Garden
  • 10865 Answers
SOURCE: john deere 420 trouble starting getting gas and
The engine needs air, so be sure the air filter is clean. If it is not, replace it.
The engine needs spark. Replace the spark plug and be sure that the battery has a complete charge.
The engine needs good fuel so be sure the gas is newly purchased, not gas that has been sitting around for months.
Posted on May 19, 2009
harlan301
  • 205 Answers
SOURCE: john deer 310 g wont start after it sitts a day
if its turning over check your spark. if you have spark remove the air cleaner and spray some carburetor cleaner to see if it start than stops- let me know
Posted on Oct 14, 2009
nova2nv
  • 197 Answers
SOURCE: John Deere 425 AWS no start, no nothing???
If engine cranks over and have no spark try a time delay module located under thermostat housing.
Posted on Nov 13, 2009
  • 11 Answers
SOURCE: 320 john deere mower starts sputtering and pulling
How old is the battery, and is it in good condition?
Posted on May 05, 2010
  • 66 Answers
SOURCE: My John Deer L120 riding mower is shutting down
Two things to consider....fire and fuel. Lets start with the simplest....check and replace the fuel filter, drop bowl off the bottom of carb to make sure float is working properly. If this dosen't work...your looking at a new coil. Some coils will go quickly where others are gradual. As they heat up...they will stop working until allowed to cool down again. www.nnyparts.com
Posted on May 30, 2010
John Deere la125 somebody rigged PTO so it's engage always and causing mower not to start or starts hard.what am I looking for to correct this?
find the wires to the PTO and trace then back to the switch
connect correctly(Probably done because of a faulty switch in the first place )
May 26, 2016 | John Deere Garden
Wiring diagram for john Deere model # 125
John Deere Riding Mowers
Richard, Check the attached links,instruction and guides for wiring diagram. Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Wiring diagram for john Deere model 125 Google Search
John Deere Lawn Mower Battery Keeps Dying
HOW TO TEST REPLACE SOLENOID ON LA125 JOHN DEERE MOWER
john Deere model 125 Schematic Google Search
Apr 08, 2016 | John Deere Garden
Have a John Deere La125 with only 13 hrs on it. Starts, but won't go in to fast throttle without wanting to die. It seems to be running a little rough in just idle mode. What could the problem be?
Hi Marsha:
If you've been running in a dusty situation it may be that the air filter is clogged. There should be a cover that you can remove to get at the filter. Remove it and give it a good clean.
I may be frowned on for this suggestion, but if you have blown or vacuumed it so it's nice and clean, start it up without the filter, just for a minute, and see how it runs.
Re-install the filter before you go back to work.
May 28, 2015 | John Deere Garden
La125 john deere
Check the blades for true. If one is bent from hitting something that will cause uneven cuts.
Sep 08, 2014 | Garden
Have john deere l130 that doesn't have spark
Sounds like the plug boot may not be on all the way. You may also have to check the spark plug gap.
May 04, 2014 | John Deere L100 Series
My john deere la125 seems to be drawing power wile shut down, it take a week for the batter to go dead, i've pulled the batterer and it stays charged up , I've checked the charging unit and i
What you do is power off the machine, and disconnect the negative battery cable. Put a test light or volt meter between the battery negative terminal and the disconnected negative battery cable.
You will likely have a light or voltage reading...Then you start disconnecting things....I suggest the alternator.
When you have the correct component disconnected and the test light or volt meter shows no current.
If this component is the alternator, they have diode sets inside (or somewhere else in the charging circuit) Typically one diode fails and this causes the draw that you describe. The system often still charges, but at a slightly lower capacity with the failed diode.
Doc
Nov 23, 2012 | Garden
John Deere LA125 riding mower, three years old, 84 hours, Briggs 21 hp engine. I mowed the lawn. I cleaned the machine with a water hose. Now, IF it starts it will die after about 10 seconds. I took the...
Bought a new John Deere LA125 IN 08 only has 106 hrs on it, maintained it to a tee, changed oil etc, now it smokes, blue smoke, smells like burning oil, it does this when i rev up or down or when theres a load on the engine, but doesnt smoke all the time, i chaanged my plug which was amazing it would start it has the 21 horse briggs and stratten engine. Any help appreciated.
May 09, 2011 | Garden
How does it start
You need to disengage the pto or the seat switch is not working.Try bouncing on the seat a few times and take a look at the pto switch wires,let me know what you find out.
Apr 23, 2010 | John Deere 420,1020,2010,2020,2510,2520...
Garden Logo
51 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
