Question about Electrolux WT30H240DU Dishwasher
Dishwasher electrolux wt30 error code c8 - Electrolux WT30H240DU Dishwasher
  • Official Brand Answer
  • 4,342 Answers
Hello Said Raji - Are you certain the error code is C8? Could it possibly be CE? If so, it typically indicates that the dishwasher has detected a configuration error. A professional will need to check the wiring connections between keypad and main control board.
Posted on Jan 18, 2013
  • 246 Answers
SOURCE: DISHWASHWER WT 65 EIM:ERROR CODE C8.WHAT DOES IT MEAN?
according to the manual...error code 8 indicates a problem with the control panel. here is the link to this manual...page 21 of the pdf http://manuals.electroluxusa.com/prodinfo_pdf/Kinston/154671101en.pdf
Hope this helps you! PS, this model number in the link may or not be similar to yours I had a problem locating your exact machine..so let me know if it isn't the right one and I'll go look some more. meantime...is there another model number on the inside side of the washer door?
Posted on Jun 21, 2012
ironman89
  • 60 Answers
SOURCE: Info. re. addition of detergent....WT30
there is a place to put the soap on the front of that one.just unscrew the cap.. that's a really nice dishwasher by the way. i've never had the pleasure of installing one.
Posted on Sep 07, 2009
taran_2005
  • 10515 Answers
SOURCE: Need of installation guide or instructions for
You could download the manual from :-
http://products.celco.ca/miva5/merchant.mvc?Screen=CTGY&Store_Code=C&Category_Code=EL_Dishwashers
You need to have acrobat reader to view the file.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Jan 26, 2011
  • 10 Answers
SOURCE: Electrolux dishwasher error c8 What does this
C8 means that at the rinse phase the boiler did not empty.
The reasons are ..
1) the nozzles are blockled
2)Drain pump out of order
3) bad luck
now you must reset c8 from the parameter in order to start again the diswasher
kostas
Posted on Feb 11, 2011
  • 2509 Answers
SOURCE: Electrolux dishwasher wt65h shoing
If there is a set button hold it in for 5 secs!
I hope I have been of help but please do not hesitate to ask if you have any further questions.
I appreciate your vote if you appreciate my reply and remember, even if you don't vote for me a please and thank you goes a long way
Posted on Mar 06, 2011
Electrolux wt30 commercial dishwasher Detergent not going into machine
Detergent dosing pump turning? It may be triggered to run when filling or at the start of a wash cycle. Report back.
Feb 22, 2015 | Electrolux Dishwashers
C8 fault code
C8 = During rinse phase boiler doesn't empty
possible causes:-
Are the rinse arms clogged?
Does the rinse pump work correctly?
Is there water in the level sensor tube?
Is there scale in the boiler?
Does the boiler level sensor work properly?
CAUTION: RESETTING THIS ALARM WITHOUT FIRST ELIMINATING THE CAUSE IS DANGEROUS; THE BOILER HEATING ELEMENTS COULD WORK DRY, FURTHER DAMAGING
THE INTERNAL PARTS OF THE DISHWASHER.
CAUTION: C8 IT MUST BE MANUALLY RESET AFTER ELIMINATING THE CAUSE OF THE
MALFUNCTION
Jun 25, 2014 | Electrolux Dishwashers
C8 error on Electrolux commercial dishwasher
A C8 error means that the boiler isn't emptying correctly during the rinse phase. Check to make sure that the boiler and the spray arms are clear of scaly buildup or anything else that could plug them. You want to make sure that the rinse pump and the level sensor are in proper working condition too.
If you do find something that you think could be the cause of the emptying problem, check it out before you reset the code. This is one of those really important codes, because if you just reset it without fixing it, the boiler heating elements may end up working dry and that can seriously damage your equipment.
Hope that's helpful!
May 08, 2013 | Dishwashers
Reset electrolux c 8 error
Hello cjsmith12345 - Are you certain the error code is C8? However, if you are receiving an error code E08 it typically indicates a shorted keypad, or a faulty User Interface Board. Depending on the model, these components may be the same. To reset, turn the power off to the unit for two minutes. This may be done by either unplugging it or flipping the household circuit breaker off and then restart unit. If error reoccurs, I would strongly recommend contacting a professional to make the necessary repairs. Unfortunately, most electronic parts cannot be returned so it is always a good idea to get the appropriate diagnosis prior to making any unnecessary part replacements.
Mar 04, 2013 | Electrolux Frigidaire Professional Series...
Jun 21, 2012 | Electrolux Dishwashers
Electrolux wt55 error code c8
If there is a set button hold it for 5 seconds.
The reasons are ..
now you must reset c8 from the parameter in order to start again the dishwasher
May 05, 2011 | Dishwashers
Electrolux dishwasher wt65h shoing error code c8. How do I reset? Another posting said to reset from the parameter? can someone explain?
Mar 06, 2011 | Electrolux 504199 Dishwasher
Need of installation guide or instructions for Electrolux wt30 dishwasher. WT30H208DU
Sorry for the delay - manuals for professional/industrial appliances are much harder to obtain than domestic ones, but this should be the manual you're looking for. This covers installation and operation of all Electrolux WT30 dishwashers and has specific references to the WT30H:
http://products.celco.ca/celco_resources/products/DW_WT30_um_en.pdf
The manual will open in a new browser window. You can then print the file and/or save it to your PC by clicking "File" in the top-left corner of the window, then choose "Print" or "Save As...".
If you are unable to open the file, you will also need to download and install the latest version of Adobe Reader:
http://get.adobe.com/reader/
If you have any difficulty downloading the file, please let me know and I will provide an alternative download source.
Regards,
BElectric
Jan 26, 2011 | Electrolux WT30H240DU Dishwasher
Electrolux dishwasher error c8 What does this mean please??
The reasons are ..
3) bad luck
kostas
Nov 08, 2010 | Electrolux 504199 Dishwasher
Sep 07, 2009 | Electrolux WT30H240DU Dishwasher
Electrolux WT30H240DU Dishwasher Logo
519 people viewed this question
Top Electrolux Dishwashers Experts
Mike
Garth Jackson
Are you an Electrolux Dishwasher Expert? Answer questions, earn points and help others
