Question about Bosch Classixx WFL 2462 Front Load Washer
Bosch WFK 2401 Need to slam door several times to lock door
Have a 12 year old Bosch WFK2401 Washing Machine.  It needed new carbon brushes in October, which my husband installed.  In order to open the washer, he ended up having to turn the machine upside down (there was probably easier way but he couldn't get anything else to work)
Since then, the washer works great but the door needs to be slammed shut 2-5 times in order for Door Lock to light and washer to start.  Then everything works fine.  We are concerned that if this isn't fixed, we will either get to a day when we can slam the door 100 times and it won't ever lock or that our clothes will be locked in and we won't be able to unlock it.
Any suggestions on how to fix this?
Sounds like you need the electric "door interlock" replaced. It is a simple matter of seperating the front of the machine enough to unplug the interlock mechanism, remove the two screws holding the mechanism in place and remove it from the back, reverse the procedure to install the new "updated" replacement part (- Bosch #170935 btw. about $37.00 from Sears). - time: approx 1/2 hour if you aren't mechanically inclined.
Posted on Mar 29, 2011
  • Bosch Master
  • 3,463 Answers
I suspect that when the washer was turned upside down , the door lock probably suffered some damage, and is probably the cause of your problem.
You could try spraying inside the lock with WD40, if that does not help, then I would suggest that you fit a new door lock.
Make sure the door sneck and handle are o/k.
Plz rate my solution.
Posted on Jan 24, 2009
Bosch wfk2401 fault 08
Most likely this means you have a belt problem, or the brushes have worn out. If you are confident, UNPLUG the machine, and remove the back cover. It will be obvious if the belt has come off, and you may be able to re-instal the old one, or buy a new one.
Worn motor brushes will be less obvious, but if you're reasonably confident with electronics, you could remove the motor, and inspect the brushes, or get someone else to.
Sep 28, 2012 | Bosch WFK 2401
I have a WFK2401 Bosch washing machine it is not spinning the clothes dry but the water drains from the machine. I did clean out the pump and trap but it is still not working. What do you think it is?
WFK2401 Bosch washing machine This video will show you how to change the pump washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Jul 21, 2011 | Bosch WFK 2401
Bosch wfk2401. machine stops and lights start blinking " error code 03"
washing machine does not spin on any cycle , however the belt is fine. Any recomdenations
Jun 13, 2011 | Bosch WFK 2401
Bosch WFK 2401 - Washer fails to spin.
Check the carbon brushes on the motor.
Apr 20, 2010 | Bosch WFK 2401
I replaced the brushes but machine still does
it may be the belt is loose, can you hear the the drum trying to turn? if so its the motor, take the belt off the motor and see if you can spin the rotor it should spin easily
Feb 17, 2010 | Bosch WFK 2401
Installing carbon brushes on Bosch WFK 2401
Remove rear panel of washer.
Remove drive belt.
Unscrew the 2 bolts that hold motor to tub back.
Remove motor plug
Lever notor back with a screwdriver or similar, keeping a firm hold on motor.and remove motor
At the rear end of motor away from pulley you will see the brushes and the armature.
Remove brushes, and if there is less than 4 or 5mm of carbon left, then replace them.
Lightly clean the armature with emery cloth.
Refit in reverse order. Test.
Jan 12, 2009 | Bosch WFK 2401
Bosch WFK 2401 Full of Cold Water!
put machine near an outside door let the empty hose lie outside that will drain the water out........then check the pump for a blockage ........
Jul 24, 2017 | Bosch WFK 2401
What to check motor brushes..What size screw driver do I need ?
Removing the back panel on my WFK2401 requires two different drive tips, a Phillips P2 and a Torx T30.
Nov 11, 2008 | Bosch WFK 2401
WFK 2401 DOOR does not open anymore
where is this machine i might be able to help over the phone
Apr 23, 2008 | Bosch WFK 2401
Bosch Classixx WFL 2462 Front Load Washer Logo
660 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
