Question about GE 30 in. Profile JGP979 Gas Cooktop
One burner won't spark
Ignitor does not spark to ignite gas burner on the right rear burner
catriver
  • 878 Answers
SOURCE: Gas not igniting
aknot, make sure each burner cap has a good ground to the burner. You can use some light sandpaper to scrub them. Where the burner fits around the ignitor is a small orfice. Use a paper clip or small sharp object to clean out the orfice. Try this first. Catriver..post back.
Posted on Mar 19, 2007
SOURCE: not igniting
how do i change the ignitor
Posted on Feb 08, 2008
milten1
  • 1304 Answers
SOURCE: The igniter on the right front burner of my GE Gas Cooktop
the very first thing i would do here is to check the ignitor itself
under the head cap you should see two screws, once those are out you will be able to lift the burner plate, lift the burner plate, you will see, or should see the ignitor, and the wire.
i check this for voltage by unplugging the ignitor and olding the wire close to a ground, the metal body is good. Turn on the ignitor, becareful it is live. yhou shgould see a spark comming from the wire
if not check to make sure that wire is in position and on the spark module
if you do see a spark this way, just order the replacement ignitor
and install it when it arrives
appliancepartspros.com
part number AP3191250
Posted on Oct 17, 2009
heatman101
  • 43501 Answers
SOURCE: GASS COOKTOP-electric ignition sparks continuously w/gas is of
Here is a tip that I wrote that will help you with that...
http://www.fixya.com/support/r4033033-gas_range_repair_burners_keep_clicking
heatman101
Posted on Apr 23, 2010
heatman101
  • 43501 Answers
SOURCE: Electric ignition for one burner on counter top ge
Here is a tip that I wrote to help people troubleshoot problems with their cooktops not igniting.
Cooktop Range Stove spark ignition does not work
http://www.fixya.com/support/r5649407-cooktop_range_stove_spark_ignition_not
heatman101
Posted on Aug 18, 2010
I have the star burner model, w/ extra-low simmer. The center burner will not light at all by itself. The right rear burner will self-ignite if you turn it to low, and then slowly rotate the knob clockwise...
Center burner won't light: If there is a bright spark (check all ignitor points at night with the lights out and look for consistent brightness of the sparks) then it's likely that the burner slots are dirty or the air/gas mix is wrong. If you can light with a match, but the spark won't light, then go for cleaning the entire burner assembly thoroughly with a brass bristle brush (available at most automotive stores). The proper air/gas mix has to flow over the spark to ignite. Weak spark, improper air/gas or misdirected gas flow that misses the spark can all cause this issue.
RR burner lights only on low setting. Again, check the air gas mix and clean all parts. Something like a small spider web inside the air mix chamber (area between the orifice and the burner can cause this and is difficult to see. Disassemble, clean thoroughly, reassemble and test. Extra low simmer burners (two on the left side) use their own control module with electric gas valves and variable electric control switches. The burner works on low, so these are not likely the problem.
Most folks want to find a bad part, and that can happen, but stove tops get dirty and cleaning usually helps. If not, you have a clean top to work on.
The indicator lens and/or the retainer are either broken or the retainer is missing. It's best to replace these as they are not expensive. When the top is off while cleaning is an perfect time to replace the lens.
Mar 30, 2017 | Thermador 37 in. SGSX365 Gas Cooktop
One igniter produces no spark. is it bad? can i
Looks like you may have a bad ignitor. Try adjusting the arc gap. Sometimes of the ignitor is too close to the burner, the ignitor will not spark. It may also be that te burner is dirty and needs a little cleaning to allow for the electric ignitor spark to arc accross, thus producing ignition. Good luck.
Jul 14, 2010 | AEG 34942G-M Gas Cooktop
After cleaning one of the small burners will spark
make sure the little hole right by the ignitor isn't plugged.
Jun 15, 2010 | Dacor Preference SGM365SS Gas Cooktop
Igniter doesn't spark on only one burner
There are three parts to the ignition system typically.
The ignitor that is either in the burner or outside the burner.
The spark ignitor switch that is located on the burner control. (( one for each control ))
The spark modual. the modual creates the hi-voltage spark.
If the burner that does not ignight with its control does not spark but does spark with one of the other controls then the spark ignitor control switch is bad.
You can test it with one of the other burner control knobs. (( just try a working burnder and when it clicks look at the bad burners ignitor and look for the spark.))
If the bad burner that wont ignight does not spark then either your modual is bas or the ignitor is shorting out.
If you see any little spark but it does not spark from point A to Point B like the other burners then your ignitor is shorting and should be replaced.
If your ignitor is ceramic and it is cracked, then it should be replaced.
Jan 13, 2010 | Miele KM360GSS 23 in. Portable Gas Cooktop
Spark ignitors on ge jgp636 either don't work or lght wrong burnr
Electric gas igniters sometimes get stuck in one position causing a clicking sound. The clicking sound that you hear is the electric arc that is pulsing from the igniter conductor (wire) to ground (the gas burner). It receives power from the electrical outlet that the stove is plugged into.
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good “blue” arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
Dec 19, 2009 | GE Profile JGP636 Gas Cooktop
The igniter on the right front burner of my GE Gas cooktop does not work....I must use a lighter or match to ignite....What can I do? There is no clicking sound when I turn on the burner?
Oct 17, 2009 | GE 30 in. JGP328 Gas Cooktop
Two of five cooktop burners fail to light
you can try to scratch the area where it grounds to with a wire brush or screw driver this will help sometimes. sometimes when it archs down try tighten the screws to lift up the ignitors into the hole better. or if this doesn't work replace the ignitors.
Jun 07, 2009 | Jenn-Air JGC8536 Gas Cooktop
Jenn-Air JGC8536 Gas Cooktop ignitor replacement
One burner doesn't consistently light. Igniter sparks but not the same as the other - "good" burners spark at top of igniter and moves around to light, "bad" burner sparks toward the bottom and doesn't move much. I can use the burner by lighting with a match and it works fine. Have tried cleaning with a toothbrush without much success
Dec 12, 2008 | Jenn-Air JGC8536 Gas Cooktop
Thermador Gas Range - Griddle ignition will not spark
I have a Thermador Gas Range PG364GDBS - Oven, 4 burners, and center griddle. All are gas. The four burners and gas oven work fine. The griddle just stopped working, no spark. Turning on the griddle control, the gas valve opens(hear it), gas flows (smell it), but the ignitor will not spark (no loud or faint spark that I can hear). I got a replacement ignition device (mount at the burner) thinking it might be the problem, but still no spark. I checked the AC voltage at the terminal and measured 39 VAC between the terminal and ground. Not sure if that is the correct voltage. Any insights or advice would be great.
Dec 07, 2008 | Thermador SGS36GS Gas Cooktop
Ignition sparking repeatedly
I have a Creda gas stove ,yesterday some water boiled over. I have a continuous spark ever since and the stove is not even on. Is there any way to reslove this without calling a repair person?
May 01, 2008 | Cooktops
GE 30 in. Profile JGP979 Gas Cooktop Logo
Top GE Cooktops Experts
Dan Webster
Dan Webster
Jim London
Jim London
Are you a GE Cooktop Expert? Answer questions, earn points and help others
