Question about Roland VersaCAMM VS-640
Print head fuse
Have a problem on the cyan who overflow on the media. Try to change the print head by on i keep in a office of an older customer. This print head killed my fuse. I put a new print head and after that every time i switch on the machine the fuse has burnt
How do I correct error c4152?
Magenta Print head (print head has the LASER inside of it that writes the image on the drum) in this case it is the magenta LASER. Open and close the front door to reset. If it comes back replace the print head. Normal done as a set of all four. (Black, Magenta, Yellow, and Cyan). Worse case is the relay board is bad or the Image control Board$$$$$$$$$$$$$$$$.
Try this site as a start:
Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Jun 04, 2015 | Konica Minolta Konica Bizhub C353 Drum...
Why is my Canon Pixma 4820 suddenly leaving lighter lines through color pictures.
Worn print head. And for what they charge for a stinking print head you can get a new printer for less with a warranty to boot!
Mar 24, 2017 | Office Equipment & Supplies
Installed Office Depot ink cartridges, BCI 6 C and Y in my MP780. Worked ok at first, but then started getting "wrong cartridge" msg, Per canon rep, turned off mach, disconnected power, took out...
This is an example of why 2nd class refills are junk. I would try to gently clean the printer out. While a lot of people disagree with this advice, a mixture of 90% alcohol in a tiny pipit works well. Then use some lint free q-tips. Most cartridges have electronic chips on them that report the status of the cartridge. Refilled ink cartridges may have bad or defect chips.
Jan 04, 2011 | Canon PIXMA MP780 All-In-One InkJet...
Will not print cyan
The cyan print head may be blocked. Try several deep cleaning of the print head to see if it can clear the blocked cyan print nozzles. Also check the cyan cartridge, make sure it is not empty.
If none of this works then the print head needs to be replaced. NOTE the print head is not a cheap item, you may consider putting the money towards a new and better printer.
Nov 13, 2010 | Canon I960 InkJet Photo Printer
One colour, Cyan will not print.
Some nozzle on print head is clodged. Remove the head, on some cloath, spill water and few times press head nozzles on it ( bottom side ), dry it and then do the head cleaning. If dont help change print head, when print head is changed its also recomended to change absorber and purge unit too.
Jul 02, 2010 | Canon PIXMA iP4000 InkJet Photo Printer
When my screen shows that some items are to print in blue they actually print in red.
Sounds like you are missing cyan. Change the cyan cartridge. If you have not used color on the printer recently, the head may be blocked.
If the head is blocked, try putting the color cartridge on a piece of * slightly * damp piece of paper towel. This should draw color out of the head onto the paper. Once you get blue (cyan), you should try printing again.
Jun 12, 2010 | HP OfficeJet K80 All-In-One InkJet Printer
I have a mutoh toucan lt i have 3 problems with it 1, i just replaced a print heda and need ot know hwo to set the individual voltage for it. 2. the language keeps getting reset to japanese. i...
Mutoh Toucan LT error E105 fuse 4 error
This Machine is 5 year old ,the problem start with System error E111 Head over heat 2,I replace the ribbon on Cyan was printing OK on small size job,wen I try to print a large size panel the machine will stop and display error E11 Head over heat 2 .
Were is the fuse 4 on this older model?
If the fuse went, is have a problem in the printer head?
PLEASE HELP
Ralph
May 29, 2010 | Office Equipment & Supplies
Printer does not print magenta and cyan. Change
The print head is clogged.Try unclogging manually.Open the cover and first remove the ink cartridges.Then open the holder and remove the print head.Run hot tap water and put the print head with the nozzles up to stream water.Hold that 5 mins then turn the print head around
with the nozzles down.Hold that for every color of 5 mins.Then put the print head in hot water with the nozzles down.Left it water about 15 mins and then you must very nice to dry.When the print head dry put it in printer and start cleaning.If this not help you need to replace the print head.It's part number is QY6-0049.
Nov 12, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
Brother MFC-420CN Multifunction Printer Problem
power off, remove all carts, power on, reinsert carts, say yes to questions
fails then replace cyan or ink well is covered in ink
Jan 10, 2008 | Brother MFC 420CN All-In-One InkJet...
Roland VersaCAMM VS-640 Logo
26 people viewed this question
Top Roland Office Equipment & Supplies Experts
Michael Harrier
Ravi
Chas Peters
Level 1 Expert
Are you a Roland Office Equipment and Supply Expert? Answer questions, earn points and help others
