Question about Bosch Ovens
How do I program the Bosch oven control board?
I replaced my oven control board and need to know how to program the new board.
4 Suggested Answers
pride applia
  • 232 Answers
SOURCE: Bake at low temp. Heating element vs control board
you need a meter that checks voltage (220) and continuity. turn off breaker remove screws that hold element in carefully pull it out just enuff to remove wires.remove wires check for continuity on element if there element is good. tape the leads to the wires turn on breaker, turn on oven if no 220 volts bad board or broken wire.
Posted on Feb 17, 2010
Macmarkus
  • 2605 Answers
SOURCE: I have a Bosch built-in
Welcome to FixYa,
I'm looking at the diagram for your oven and I do not see a P17 connection, however you said it is a connection on a relay. Can you identify which relay it is connecting to i.e. K5, K3, K7 or K8 ?
K5 is the bake element or "DE" ( down ele. )
K3 is the convection element or "RE" ( ring ele. )
K7 is the inner broil element or "RE" ( internal up ele. )
K8 is the outer broil element or "EUE" ( external up ele. )
I should be able to help move you forward in this regard if you can clarify this matter. I'll watch for your reply.
Regards,
Macmarkus :)
Posted on Dec 02, 2010
  • 586 Answers
SOURCE: Bosch Singe Oven Mode HBL-645-A
Hello there,
All you need to do is to unscrew the screws around the top of the oven and you will have access to take off the top cover, then you remove the screws that are holding the front control panel in place, then you fix in the new one and screw it back on, then you cover the top back and screw it back on the oven.
There are lots of screws around there so please you can start from anyone.
That is the picture that carries the way the screws are on the oven. That will do the job for you.
Posted on Aug 28, 2011
Bosch oven error code F43; breaker reset doesn't work. Door ok (though it locked while using broiler). Beeps continuously. Worth fixing? OK to use gas burners without power? Smells very gassy.
Don't use any appliance that smells of gas or partially burnt gas. Time for a new one or a professional Bosch service engineer. Your call?
Here is the Error Code
F43Upper (or single) oven motorized latch will not lock; defective or jammed upper (or single) oven door or latch switches; defective latch motor or its wiring.
  1. Check P24 connector on the power board.
  2. Ensure door latch switches are operating properly.
  3. Check that neither latch switch nor common wires are pinched to the appliance chassis.
  4. Check P10 connector and check if latch motor wire is pinched to the appliance chassis.
  5. If F43 persists, replace power board.
Read more: http://www.appliancepartspros.com/repair-help/bosch-fault-codes.html#ixzz4TKlEr5YM
Bosch Fault Codes AppliancePartsPros com
Dec 20, 2016 | Bosch Ovens
Bosch HBL 645 Convection Oven -- No Heat
first out put voltages measures,when output voltages ok , then see the control circuit.after tnat every thing ok. replace heating elements.
Dec 10, 2007 | Bosch HBN 442 / HBN446 Electric Single...
Bosch wall oven (electric) heats up but baking 2 pumpkin pies & 1" cubed sweet potatoes took over 2 hours, crust still doughy and not browned, potatoes cooked but did not brown.
Have you checked your elements? They could be going bad otherwise your oven control board is going bad and needs to be repaired. The Repair Shack offers a service which can fix this issue of the problem is in fact the Conteol Board. Check your elements first and then give them a call, they will be able to save you some money on the element(s). Otherwise they can help you get the control boards repaired.
Nov 28, 2015 | Bosch Ovens
Thermador oven sc272t f-c code I have a F-C code on the oven and it beeps continunually. Do I need to call a repairman?
Hello, welcome to FixYa.
Based on your post I understand you have an error "FC" on your Thermador SC272 wall oven, correct ?
There are two common scenarios with these Thermador wall ovens fitting what you've described. Either the lower oven control board has failed or there is a communication error between the control board and the display.
Here is an exert from my Thermador service documents explaining in their terms...(hopefully it won't get partially cut-off when I click "submit" as it sometimes does with attachments, that's out of my control unfortunately).
In either scenario I'd suggest calling in an authorized B/S/H/ (Thermador/Bosch/Gaggenau) service technician since it is pretty involved to trace and possibly replace (hopefully not) any failed/faulty component on these units.
Hope this helps move you forward. Let me know if I can assist you further and good luck.
Regards,
Macmarkus :)
Oct 23, 2011 | Thermador SC272T Electric Double Oven
I have a Bosch HMB405. It no longer heats food at all. It went from full function to failed in one day. Reset power level to no avail. Reset breaker to no avail.
Hello & Welcome to FixYa
This indicates a open/shorted oven temperature sensor and to solve this problem the sensor needs replacement. If you wan to be sure before replacing the sensor then you can test it with a voltmeter for around 1100ohms....if it reads more then this then it needs replacement however, if the reading is around or less then 1100ohms then it is the control board that needs replacement. Please get back to me if you have any other questions.
Kevin
Jan 08, 2011 | Bosch HMB405 Oven
Bosh double oven. Temp is 100 degrees cooler on top oven, any ideas? both on bake mode
The fact that top oven is 100degrees less than bottom is no relation between the two; they are controlled by independent stat controls and if the only way you know if the temp is correct, is to set a temp (such as 350 degrees) and put a thermometer in that oven to see if the thermometer is with in 25degrees of the control settting. You need to do this for the bottom oven as well to see if it is aslo within 25degrees of the setting. then you make adjustments for each unit independently. If the controls are mechanical (knob), then the adjustment is within the control (usually by removing knob and serching for a small screw). If the controls are electroonic, then you need to search the circuit board to see if there is adjstments mounted on the board. Goodluck,Macgivor
Jan 31, 2010 | Bosch HBN 455 Stainless Steel Electric...
My Whirlpoolis showing F-1 Error of the LCD display? What can I do?
F1 code on your oven means "Electronic control malfunction". Clean contacts and reconnect all wires on the control board. If it does not help - replace oven control board. You'll also need to program the oven cavity size in the new control board. Model number is incomplete, so can't tell the part number, can be either 8301919 or 8301345
Oct 13, 2009 | Whirlpool RBS245PDS Electric Single Oven
Bosch HBN745AUC control panel broken and needs to be replaced. Any DIY advise appreciate, included the parts no. and cost information.
If you mean the glass in front of the display and touch panel is smashed, you can buy a new glass panel, about $200, part 239424 (for a stainless oven), see bosch parts link below. Probably the electronic touch sensor board underneath is fine, but its basically glued to the glass panel so will be a bit tricky to peel off and re-glue to the new one.
http://www.bosch-eshop.com/eshop(bD1lbiZjPTAwOQ==)/bosch/us/prodp.htm?prod=HBL745AUC%2f02&ESHOPTYPE=S
Jul 12, 2009 | Bosch HBL 745 Stainless Steel Electric...
Thermador model sc272t oven 2 doors have dim display
there is a dispay kit you can order from bosch to fix this problem. it will come with a new display board and power control which is located behind control panel as well
Nov 18, 2007 | Thermador SC272T Electric Double Oven
Ovens Logo
53 people viewed this question
Top Bosch Ovens Experts
ashburton
reliableservice
Are you a Bosch Oven Expert? Answer questions, earn points and help others
