Dvd player des not work on aveis 19 inch tv dvd combo new out of the box?
  • 4234 Answers
SOURCE: Toshiba TV Combo MW24FP1, DVD player doesn't work on some discs
This is a common problem for all combo units. The high voltage of the TV section attracts large amounts of particulate dust from the air and often it collects inside the DVD unit. The best way to deal with this is to clean the lens of the DVD unit u sing a cotton swab and alcohol. The store bought "cleaners" MAY work, but that is rare. These cleaners are nothing but small brushes embedded into a disc. They attempt to brush off hte dust. This rarely works. Open up the unit (if you feel comfortabel in doing so) to access the DVD section. Remove the top cover and carefully clean the lens. That should resolve the problem.
Dan
Posted on May 21, 2008
SOURCE: DVD Stuck in TV/DVD Combo
This may not sound technical, but I stuck the end of a paper clip into the opening until I could feel the dvd.....jiggled it a bit, and out it popped while pushing the eject button!!!
Posted on Jul 17, 2008
Shuttle83
  • 1139 Answers
SOURCE: no remote
Hello sweettexas,
I you use a universal remote you might be able to use some of your programming features, you can get such a remote from Best Buy, Radio Shack, Target, or Wal-Mart. Now for the down side with the universal remote you will only get some of your programming functions as I said earlier. If you want all of those features you are going to have to contact the manufacture and order a remote for your television. There are places on line such as ebay, or amazon where you can buy a remote for this set, and this might be considered as an option also. In any event whether
you buy a universal remote or buy an OEM remote, you will need a remote to "properly" setup your TV. You can use the front panel controls for limited setup however doing that is tedious.
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Posted on Jan 26, 2009
ruben_barrer
  • 117 Answers
SOURCE: Panasonic PV-20DF64 20 inch TV/DVD Combo TV can not read disc
If the disc loads up and you can hear it spin, then you get the error, more than likely the optical lens has been damaged. This will have to be repaired by a local shop if its worth the cost. if the part is available it would probably run anywhere from 130-165 to repair
Good Luck!
Ruben
Posted on Jul 23, 2009
AndystUK
  • 131 Answers
SOURCE: TV/DVD combo does not work with Freeview box
check your scart leads for pins damage.
Replace scart lead or try another one
AndystUK
Posted on Aug 31, 2009
Hi i have a 19 inch alba tv dvd combo in dvd mode the tv says no signal dvd is just dead tv works fine says call argos
The player has failed, it is not a product that is really repaired due to the low cost of a new one, I would just buy a stand alone player and right this off.
Nov 25, 2016 | Alba Televison & Video
Veon tv manual
The eject button on the remote appears as an upward-pointing arrow with an underline - see below image. The eject button on the TV has a similar symbol.
However, I suspect that in your case, you might not be having a Remote.
This link says that your TV doesn't come with a Remote and DVD cannot be ejected without the remote :
VEON 19 LED TV DVD FREEVIEW COMBO A1823511 1
Jun 28, 2014 | Televison & Video
Sanyo TV connect to cable box connect DVD player
If your DVD/VCR combo player has three RCA connectors (yellow, red, and white), you can connect them to the corresponding inputs on the front of your TV.
Dec 29, 2012 | Sanyo Televison & Video
I have a Haier HLC19K1 19" tv/ DVD combo that
If you have tried more than one commercial DVD and are getting the same results then the problem is the player has failed. Actually what happens is the heads go out of alignment and it doesn't have the accuracy to read the tracks any more. This is a typical failure of dvd players in desktop and laptop computers and standalone players. While the heads can be aligned it isn;t worth doing. It was when a dvd or cd player was $1500 but not now.
Unfortunately the only cost effective fixes are replacing the dvd drive or replacing the entire unit. The replacement dvd would cost more than a new replacement tv/dvd combo. So you can buy a new tv or buy an external player ($40ish).
Feb 02, 2011 | Haier HLC19K1 19 in. LCD TV
Digital labs 19 inch tv/dvd combo
Wish I knew the answer ... I have the same problem after switching to Dish Network (Satellite). It worked fine with Time Warner Cable. I'm suspecting the signal over Dish is analog (NTSC) which is not supported by this particular TV. I wish I still had the box and receipt!
Feb 01, 2010 | Televison & Video
My son has a 19
the noise that you can hear is most likly to be a hum this is the power supply transformer ocillating it is quit common normally on cheaper range items but this is not always the case the noise is there when it is in use but the hum is obscured by the sound from the unit ie music of films i have dab stuff that does it really annoying at night
Jan 17, 2010 | Televison & Video
Proscan 37 inch LCD 37LB30Q Model
I used a swicher box form monster I plug in my viedo games and cable tv into it and then you run the composit cable which is high def into the tv but the sound into the swicher box the swicher box sound is run into the surround sound you just hit a button and you have the sound go to wall mart has the box for 20 dollars
Jul 08, 2009 | Proscan 19LB30QD 19 in. LCD HDTV/DVD Combo
Tv code for remote
Sorry but to my understanding there are no universal remote codes in existence for combos. Call an electronics repair shop. Give them the make and model number of your combo. They will be able to order you a new remote for your brand and model. If it is not too old they should be able to get one for you. I got one and it was only $21.00. Well worth it cannot use half of the features without proper remote... Good Luck!
May 28, 2009 | Emerson EWD2203 DVD Player/VCR
Poor viewing with VCR
how do you have the combo connection and dish network hooked to the tv ? if you have an s-video , yellow RCA jack video or component video hooked to the same input then it will act this way, because two inputs cannot be on the same video input # on the tv.
is this what is happening? or how are you connecting it?
Jan 04, 2009 | Samsung DVD-V4600 DVD Player/VCR
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
