Question about Sharp AQUOS 52" Flat-Panel LCD HDTV
How do I scan channels with no remote - Sharp AQUOS 52" Flat-Panel LCD HDTV
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 12 Answers
Menu button on TV, then toggle up and down,left and right with the Programme + and -, and Volume +and -, and you may be able to scan your channels.
Posted on Jan 16, 2013
LEDTV24FHDF
You should be able to get OTA (over the air broadcast) just make sure you have an antenna plugged in and that the tuner is set to AIR.
Setting the Tuner Mode
If you are using a device that is connected to the RF input, such
as an external antenna or cable TV connection, you must set the
tuner mode.
1. Press the MENU button on the remote. The on-screen menu is
displayed.
2. Use the Arrow buttons on the remote to highlight the
Settings icon and press OK. The Settings menu is displayed.
3. Highlight Tuner and press OK. The Tuner Mode menu is
displayed.
4. Highlight Antenna or Cable and press OK.
5. Press the EXIT button on the remote.
Scanning for Channels
Before the TV can detect and display channels and their
associated information, you must scan for channels. A channel
scan may also be necessary when the TV has been moved to an
area where different free-to-air broadcast television channels are
available.
1. From the Tuner Settings menu,
highlight Auto Channel Scan.
The auto channel scan begins.
2. Wait until the channel scan is
100% complete. Highlight Done
and press OK.
3. Press the EXIT button on the
remote.
Apr 08, 2014 | Televison & Video
Need to find a "enter" button on the TV
You won't have much luck attempting a channel scan without the remote.
Nov 11, 2013 | Kitchen Ranges
How to scan for TV channels
Channel searching is performed as part of the setup process. Your remote should have a way to direct the TV to display the setup steps
Jan 10, 2013 | JVC LP21036-023A Remote Control...
How to get it to do a new channel scan
by the original remote thats my problem now all i really need is to at least scan
Sep 01, 2011 | Coby Electronics DTV102 ATSC...
I do not know how to do a channel scan, can you help me please? I seriously thought that I could find anything online but I have not been able to find how to channel scan this tv.
What brand/model TV do you have? If the TV has several input options, make sure that the TV is set to the TV mode. (Use the Input or Source button on the remote, some TVs have this on the TV as well but not always)
Some can only do a channel scan with the original remote. My old Emerson CRT (~20 years old) launched a channel scan when I pressed the Add and Delete Channel buttons together on the remote. Fortunately even when most of the buttons failed on that remote, the channel scan still launched.
Other TVs from that time frame have an channel scan button in the control panel. Often these are hidden behind a panel to avoid accidental resets.
More modern TVs usually have the scan as part of the menu. Depending on the TV, press Menu on the remote (or if available on the TV (sometimes can be done by pressing Ch+/Ch- together)). Then look for a Setup option or a TV icon. If you have a Setup menu, you will then need to go to the TV submenu. Then find the option for setting the input signal (TV/cable) and then you should be able to launch a channel scan. (Usually the Ch+/Ch- (up/down) and Vol+/Vol- (left/right) buttons will navigate through the menus.)
Unfortunately, without the make and model, I can't give you any more help. Please write back with your brand of TV and I'll check if I have the manual in my stack.
(low end universal remotes do not always include the menu or source button. If your TV doesn't have them, you may need a different remote. The ones that can be programmed via a USB connection are the easiest to set up.)
Apr 29, 2011 | Televison & Video
How can I program my remote with scan
Hello
In the CBL/SAT or TV mode, use the FAV key to start a 3-second scan of all
channels.Or, if programmed, use the FAV key to scan only your favorite
channels to view a desired channel
Press CBL/SAT or TV once.
Press FAV once.
• IfFavorite Channel Scan has been set up, scanning of
favorite channels will start with up to 100 channel changes
or until stopped by pressing any key.
IfFavorite Channel Scan has not been set up, scanning
will start with the current channel, and continue up to
100 channel changes or until stopped by pressing any key.
To stop scanning channels at any time, press any key
once.
Mar 24, 2011 | One For All URC-4021 Remote Control
I want to go to channel 3 so i can go on cable , but the remote doesnt let me !
Hello; All TV's made in the last 20 years are computer controlled. The TV wants you to do a "scan ", so it can MEMORIZE all active channels. IF you are connecting your set to a cable BOX or OTHER, the set can only SEE the Channel 3 output from the boxes. No scan will work when doing this! In this case don't expect to be able to use the channel UP or Down keys on the set or remote, because the set does not know any channels due to no memory of a scan. You can, however key in the channel # and the set should go to that channel, unless the set is defective. John
Dec 19, 2010 | RCA Televison & Video
I hooked my tv up to cable, but cannot get cable channels to work... you can get them by putting numbers in remote, but will not show up when you scan up/down button on remote. Don't haveoriginal remote,...
Is there a Menu button on the remote that activates the Menu function on the TV? If there is, launch the Menu and look for an option titled Channel Memory, or Channel Scan, Add to Memory, etc. This functon will scan the channels and add active channels to memory.
Jul 05, 2009 | Zenith Televison & Video
Sharp AQUOS 52" Flat-Panel LCD HDTV Logo
53 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
