Question about Zebra ZM400 Thermal Label Printer - ZM400-3001-3000T
LIGHT PRINTING ISSUE WITH ZEBRA ZM400 PRINTER 300DPI
WE ARE USE NK21 RIBBON & SAME RIBBON AND LABLE WE ARE USE S4M PRINTER BUT S4M IS WORKING FINE. I HAVE DO ALL ACTIVITIS BUT PROBLEM IS SAME LIGHT PRINTING?
2 Suggested Answers
printertech1
  • 96 Answers
SOURCE: Have A Zebra Z6M Plus 300dpi printer
Print configuration from both printers and compare. Print config- Hold cancel button 10 sec. while power on. Check Resolution parameter. 203dpi=8MM Full , 300dpi=12MM Full. Sounds like perhaps they are different dpi.
Posted on Apr 11, 2011
Error condition power supply
Dear,
you have not mentioned, whether print continues with that error or it doesn printer..?
anyway,
first thing, check your power cable.
If that error is on, it means that label media or ribbon sort of errors.
try re inserting both ribbons and media.
if tat error is flashing and printer continues printing, it may coz of over heat of head..! if so try reducing the pressure of the head.
if you are using continous labels, then calibrate the media and ribbon sensor.
for more details, please reach us.
www.trridevlabelss.com
Feb 05, 2013 | Zebra ZM400 PRINTERS 4 Inch DT/TT 300DPI...
Can't get the Zebra S4m printer to align? How should I trouble shoot this? Sonya
I am assuming you mean misalignment of lable top or start of print moving on label.
check sensor for lable debris.
if OK then perform media calibration:
Enter menu and scroll to ADVANCED
press enter and use password 9999
scroll to MEDIA and RIBBON CALIBRATE
Remove a few labels and remove ribbon
Press right arrow to continue display CALIBRATING PLEASE WAIT.
When complete reload ribbon and labels press right arrow printer will feed approx 39"
printer should now print OK.
Aug 08, 2011 | Zebra S4M Thermal Label Printer
For ZM400 and S4M, Has anyone had any luck with printing a white ribbon and a black or dark label without covering up the ribbon sensor with electrical tape? Isn't there a setting that can be...
You can try this: on the S4M, you can press the Menu key to go into setup mode. Under password level 3 parameters,there is a setting for ribbon which by default is set to Yes thermal trans. If you set it to No for direct thermal mode, this will in effect turn off the ribbon sensor. The printer won't stop now if it runs out of ribbon but usually you are there when printing to see that the ribbon is running out.
On other Zebras, you can turn down the sensitivity of the RIBBON LED sensor but the S4M doesn't have that setting.
See if that helps.
Jun 20, 2011 | Zebra 203DPI Printer
Have A Zebra Z6M Plus 300dpi printer Z6M00-2006-0000, then purchased a Zebra ZM400 300dpi printer, attempting to print using formats from Z6Mplus, result is a print approx 150 % larger ??? Downloaded...
Apr 03, 2011 | Zebra ZM400 Thermal Label Printer -...
Error in position of the output for ZM400
this is usually caused by a pressure imbalance across the printhead. Check the printhead pressure adjust dials located on top of the printhead. You might find that the left side has more down pressure than the right side causing the ribbon to move to the right.
Hope that helps !
Apr 09, 2010 | Zebra 300DPI CUTTER [zm400-3001-1000t]...
Zebra zm400 turn printed info 180 degrees
Yu can rotate the print orientation in the Z Designer printer driver, in the OPTIONS tag tick the 180Deg box
Dec 17, 2009 | Zebra 300DPI CUTTER [zm400-3001-1000t]...
Zebra S4M prints one label then goes to flashing pause light.
most likely it is a printer driver issue. There's 2 drivers, one for 200dpi and one for 300dpi. Use the one for 200dpi. It could also be the label setting is incorrect. Try running a calibration.
Jan 21, 2009 | Zebra Z4M Printer
Zebra ZM400 Thermal Label Printer - ZM400-3001-3000T Logo
56 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
