Question about Cobra FRS 100 (2 Channels) 2-Way Radio
What frequency are they onCobra FRS 100 (2 Channels) 2-Way Radio
    Top Expert:
  • Cobra Master
  • 2,931 Answers
Recommend asking Cobra directly Support Cobra Electronics Corporation
what frequency are they onCobra FRS 100 (2 Channel - easy-4xcgpgmbsyetxdvhu0rk3j02-3-0_3.png
Posted on Feb 04, 2018
2 Suggested Answers
SOURCE: how to tell frequency on FRS-70
Channel A is FRS channel 8, at 467.5625MHz.
Channel B is FRS channel 13, at 467.6875MHz.
If you ever have another question like this one, search by FCC ID # at http://www.fcc.gov/oet/ea/fccid/Welcome.html .
Regards!
Posted on Sep 05, 2009
COBRA MICRO TALK1 FRS 100
THEY SHOULD ALL WORK TOGETHER ON THE FRS FREQUENCIES. MAKE SURE THAT YOU SET THE CHANNELS AND SUBCHANNELS TO THE SAME ON ALL FRS RADIO.
Oct 07, 2012 | Cobra Frs-120 Microtalk 2-mile 14-channel...
Does the T/A 250 use standard CB fequencies?
No. The TalkAbout 250 has 14 FRS frequencies built in to it. These are FM UHF 2-way radio frequencies which differ from CB frequencies.
Best regards.
Mar 04, 2012 | Motorola Talkabout FRS 250 (14 Channels)...
Can two different style motorola 2 way radios be changed to same frequency
Hi Kate,
The short answer to your question is: no, or "not readily". Here's why:
The Motorola 4900 radio operates in the FRS (family radio service) and GMRS (general mobile radio service) in the UHF band. This radio will work with any other FRS / GMRS band radios (no reprogramming of transmit and or receive frequencies is possible for these radios). The trick is that the numbering of the channels may differ from brand to brand ie: Ch1 on your Motorola may not necessarily be Ch1 on a Midland radio or other brand. A complete list of the frequencies and channel assignments for FRS /GMRS can be found on Pg. 17 of the manual. It is important to note that without a valid GMRS license, you are prohibited from transmitting on the GMRS only channels (Ch 15 through Ch 22). The combination GMRS/FRS channels (Ch1 through Ch7) and the FRS only channels (Ch8 through Ch14) are for individuals and family members that do not have valid GMRS licenses. If this is you, you should limit your transmissions to Ch1 through Ch14 only, as FRS does not require a license in the US. Unlicensed use of GMRS only Ch15 through Ch22 can result in fines and imprisonment if caught by the FCC.
Further complicating the issue are the so called "privacy tones". This is simply a very low or "sub-audible" frequency that is sent whenever transmitting. Motorola calls these "Interference Eliminator Codes". When another radio receiver is set to listen for a particular privacy tone, it stays silent until a transmission with the exact same privacy tone is detected. Again, these tones are listed in no particular order, but are generally listed as 1, 2, 3, etc. or a, b, c, etc. instead of the actual frequency in hertz. You can selectively set your radio to transmit & receive one of the 38 codes or, set the code to "0" to communicate with radio that do not offer these privacy codes - or does not use the same frequencies for these codes. You can read more on Motorola's codes on Pg. 19 of the manual.
The Motorola CP200 radio on the other hand is a commercial radio, and requires computer programming with Motorola software. The CP200 is offered as both Low & High sub-banded VHF and Low, Mid & High sub-banded UHF radios. You would need to have a CP200 that is designed to accept the Mid UHF band (438Mhz - 470Mhz) frequencies in order to program the 462Mhz & 467Mhz FRS / GMRS frequencies into it. The final obstacle would be what is called "FCC Type Acceptance". The CP200 is probably NOT Type Accepted for transmitting FRS/GMRS frequencies, and as such the Motorola dealer doing the programing might balk at putting them in. You can read a spec sheet on the CP200 here.
I hope this helps & good luck!
Feb 29, 2012 | Motorola Radio Communications
How to set low power in midland LXT300
  • The Hi and Low power are built into the radio and is dependent on the frequency/ channel you are on. Hi power is 1 Watt and Low power is .5 Watt. The radio is GMRS and FRS. The FRS are low power and the GMRS are Hi power.
  • Channels 1-14 are FRS frequencies and Low power.
  • Channels 15-22 are High power and are GMRS frequencies.
  • FRS = Family Radio Service.
  • GMRS = General Mobile Radio Service.
  • If you have any comments please feel free to leave them here.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Sep 28, 2011 | Midland LXT303-A 2-Way Radio
Frequency range
The T5720 has
- 7 GMRS/FRS 1 watt Channels
- 7 FRS 1/2 watt Channels
- 8 GMRS 1 watt Channels
All of these frequencies are between 462-467 MHz. There is a list of the specific frequencies assigned to each channel on page 19 of the user guide. Here is a link http://www.giantintl.com/RadioPDFs/Outdated%20Manuals/T56XX_57XX_User_Manual_E.pdf
Best regards.
Jun 16, 2010 | Motorola Talkabout T5720 (7 Channels)...
Require Frequencies for CTCSS codes for Motorola GP 2000
check this link at page 21 or see below
CTCSS PRIVACY CODES FREQUENCY CHART (Hz) Code Freq. Code Freq. Code Freq. Code Freq. Code Freq. 1 67.0 9 91.5 17 118.8 25 156.7 33 210.7 2 71.9 10 94.8 18 123.0 26 162.2 34 218.1 3 74.4 11 97.4 19 127.3 27 167.9 35 225.7 4 77.0 12 100.0 20 131.8 28 173.8 36 233.6 5 79.7 13 103.5 21 136.5 29 179.9 37 241.8 6 82.5 14 107.2 22 141.3 30 186.2 38 250.3 7 85.4 15 110.9 23 146.2 31 192.8 8 88.5 16 114.8 24 151.4 32 203.5 * Channel 8,9 and 10 are designated Canadian Marine Frequencies * Channels 8~14 are low-power FRS license free channels Note: Privacy codes can be programmed for use on Channels 1~22 only
Feb 01, 2010 | Motorola GP300 Compatible 2 Way Radio...
How to tell frequency on FRS-70
Regards!
Apr 03, 2009 | Cobra FRS 70 (2 Channels) 2-Way Radio
Channels
All gmrs radios also have frs frequencies in them. The frequencies are staggered.....1 frs....1 gmrs....1 frs....gmrs etc etc.
The only difference between frs and gmrs is power.... you are allowed to use more power on gmrs freq. So thats why they have more range. But the frequencies are right beside each other.
I would be surprised if your friends radio did not have frs channels in it also.
They should be able to communicate... most likly not on every channel but there should be some that the 2 of you share.
May 09, 2008 | Chatterbox HJC-FRS Stereo Communicator (2...
What is the frequency for UFR650?
these are FRS radios, and use only the 14 FRS channels within the GMRS band. they will not operate on the other GMRS channels in the GMRS band. FRS Channel Frequency Assignments: Channel 1: 462.5625mhz Channel 2: 462.5875mhz Channel 3: 462.6125mhz Channel 4: 462.6375mhz Channel 5: 462.6625mhz Channel 6: 462.6875mhz Channel 7: 462.7125mhz Channel 8: 467.5625mhz Channel 9: 467.5875mhz Channel 10: 467.6125mhz Channel 11: 467.6375mhz Channel 12: 467.6625mhz Channel 13: 467.6875mhz Channel 14: 467.7125mhz
May 23, 2006 | Unwired UFR650 (14 Channels) 2-Way Radio
Cobra FRS 100 (2 Channels) 2-Way Radio Logo
21 people viewed this question
Top Cobra Radio Communications Experts
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
