Question about ASUS Computers & Internet
One letter is not working on my keyboard
Only 1 letter is not working - think my son has pressed something.... there is a small symbol on key not working - an S in a box? The letter not working is the one missing from this word _ AT (meow).
    Renaissance:
    An user who is expert in 3 categories / brands.
  • ASUS Master
  • 1,001 Answers
  • Fashion,your best gift for your friends:Professional,stylish,your best gift for your friends in X-mas,Thanksgiving Days,New Year and other festivals.
Chornic Hair Straightener Brush Instant Magic Silky Straight Hair Styling...
Posted on Dec 16, 2016
  • ASUS Master
  • 27,725 Answers
One moment you are typing on your computer keyboard as usual, when suddenly a key sticks or does not produce a character on the screen. Perhaps you have a group of keys that suddenly stop working. Laptop and desktop keyboards alike can stop functioning due to a number of causes, most of which can be resolved by troubleshooting. Knowing how to fix some keyboard keys that do not work can save you time, and save you the cost of buying a new keyboard.
Update the device driver for your keyboard by going to the manufacturer's website of your keyboard, and then download and install the latest driver matching the brand and model number of your keyboard. Disconnect your keyboard from your computer and inspect the pins in the keyboard connector if you have a PS/2 connector. The PS/2 connector for your keyboard has six pins, which connect into a PS/2 port of your personal computer, to allow for communication to and from your keyboard. Straighten any bent pins you may find, by gently using a ballpoint pen. Y ou must replace your keyboard if you see broken pins. Try testing your keys using a different application, such as another word processing program. Keys like the function keys on your keyboard labeled F1 through F12 may not work in one application but will work fine in another. b> Clean Under Desktop Keys b> Disconnect your standard desktop keyboard, then press down on a key not working. Slip a car key or a flathead screwdriver underneath the key. Twist the screwdriver or car key until the keyboard key pops off. Use a damp cloth, moist cotton swabs or compressed air to remove dust, hair, and food crumbs under the key. Use only water or rubbing alcohol to moisten the cloth and cotton swabs other cleaners can damage the plastic of your computer. Position and press down on the key to snap it into place. Repeat this for all of the keys to clean underneath them, if necessary. b> Clean Under Laptop Keys b> Turn your laptop off, then use a flathead screwdriver or knife under a key corner, prying the key off gently. You will hear a snap as the key detaches. Remove the key retainer remaining on your laptop using your knife or screwdriver under the corner, then popping it off with a gentle twist. Remove the space bar by pulling it off after your insert the screwdriver or knife underneath the bar. Clean underneath your laptop keys using cotton swabs or a soft cloth dampened with water or alcohol. You can also use compressed air to remove dust, hair and other debris. Replace your laptop keys by placing the key retainer into position. If you cannot remember the position, copy another retainer's position by removing another key. Insert the keypad into the retainer, then position the key over the retainer while pressing down on the key. You should hear the key snap into place. Place your laptop's space bar over the space bar slots, then snap it into place.
Posted on Jan 16, 2013
3 Suggested Answers
  • 39 Answers
SOURCE: hp mini keyboard shift key 2 does not type @
it has to do with your keyboard setting, currently you are set to the united kingdom keyboard layout, you will need to change this to Unite States settings assuming that you got vista, you will need to do the following
goto control panel
click on regional and language option (there will be a pop up)
click on the keyboard and languages tab
click on the change keyboard button (another pop up will appear)
click on add
and add the United States Keyboard
change the keyboard setting on the upper drop down menu to United States, and then click ok.....this should solve your problem.
Posted on Sep 27, 2009
moisrkj
  • 7 Answers
SOURCE: my keyboard is not working well
Hi Friends,
Problem with Dell Laptops?
For solutions for your problem you need to visit a site by just Click Here .
For any hardware problem with Dell Laptop you can Click Here
Posted on Jul 23, 2010
What is wrong with my laptop? It is as if the shift key is stuck
Go into device manager in windows and delete it and reboot. If it comes back when it detects the keyboard and it works then it was a driver, if it does detect it or it wont work correctly then it is a bad keyboard. You can also try a plug in keyboard to see how it behaves, ps keyboards are not that expensive.
Oct 11, 2015 | Toshiba Computers & Internet
This afternoon my laptop was working fine, then the keyboard started messing up, when I pressed any letter it came up with 4 other letters. Then i pressed '9' once and it continuously typed 9 until I
First thing I would ask is this. Was anything spilled on the key board? I had a situation similar to this and I found that my son spilled a Sprite and wiped it up but didn't tell me about it. One way to check this is to hook an aftermarket keyboard that runs off your USB2 port and see if the keys work correctly that way. If they do, I would suspect that something was spilled into your laptop keyboard.
Feb 06, 2013 | Computers & Internet
Secret keypad letters in computer
hi
Click on a text box or open a text document.
  • 2 Press the "Num Lock" key to activate your keyboard's numeric keypad.
  • 3 Press and hold the "Alt" key.
  • 4 Enter the numeric code on the number pad. Press "1" to create a "smiley face." Display a musical note by pressing "14". To make a heart symbol, press "3".
  • 5 Release the "Alt" key after entering each numeric code. The symbol will appear.
  • Jan 15, 2011 | Computers & Internet
    Symbols
    You hit a keystroke combination. You'll have to press the Fn key in the lower left side of your keyboard and one of the special function keys (in a HP, I think it's something like F11 or F12--look at the symbols on the keyboard. Anyway, that combo locks the special characters on. Just hit it again to get back to normal typing.
    Sep 22, 2009 | HP Pavilion dv6000z Notebook
    My blitz doesnt text
    Try this. Touch Keypad simulates a wireless phone keypad on the touch screen to allow you to enter text, numbers, and symbols just as if you were using a wireless phone keypad. Touch Keyboard simulates a 20-key QWERTY (typewriter) keyboard on the touch screen to allow you to enter text, numbers, and symbols similar to the way you would using a QWERTY keyboard. To use Touch Keypad or Touch Keyboard:  In a program, tap the Input Selector arrow, and then tap Touch Keypad or Touch Keyboard. To type lowercase letters, tap the keys on the dial pad or keyboard. To type a single uppercase letter, tap the Shift key and then tap the corresponding key. To type all uppercase letters, tap the Shift key twice. To change back to all lowercase letters, tap again. To enter a space after the word, tap the Space key. To start a new line, tap the Enter key. To backspace and delete a single character in any input mode, press the Back key. To open the Symbol pad, tap the Symbol key. To change the input mode:  Tap the Input mode key to switch to a different input mode: XT9 (predictive), Multitap (abc), or Numeric (123).
    Hope this helps, let me know if this works or if I can help you with anything else.
    JimmyC
    Aug 05, 2009 | UTStarcom Blitz Cell Phone
    Cannot use letters of my laptop unless use fn key but not capital
    You need to press the NumLock key to get the keyboard to get back to alphanumeric - it has a symbol of a lock with a number 1 on it. A LED should also go out/icon in your tool tray should disappear as well.
    Jul 05, 2009 | Acer NSK8458AN Keyboard
    Keyboard will not work
    Try this and see if this works for you. Touch Keypad simulates a wireless phone keypad on the touch screen to allow you to enter text, numbers, and symbols just as if you were using a wireless phone keypad. Touch Keyboard simulates a 20-key QWERTY (typewriter) keyboard on the touch screen to allow you to enter text, numbers, and symbols similar to the way you would using a QWERTY keyboard. To use Touch Keypad or Touch Keyboard:  In a program, tap the Input Selector arrow, and then tap Touch Keypad or Touch Keyboard. To type lowercase letters, tap the keys on the dial pad or keyboard. To type a single uppercase letter, tap the Shift key and then tap the corresponding key. To type all uppercase letters, tap the Shift key twice. To change back to all lowercase letters, tap again. To enter a space after the word, tap the Space key. To start a new line, tap the Enter key. To backspace and delete a single character in any input mode, press the Back key. To open the Symbol pad, tap the Symbol key. To change the input mode:  Tap the Input mode key to switch to a different input mode: XT9 (predictive), Multitap (abc), or Numeric (123).
    Let me know if this works for you, if not let me know.
    JimmyC
    May 07, 2009 | UTStarcom Blitz Cell Phone
    Ibm thinkpad keyboard. i type letters, numbers show up. fix?
    With my IBM Thinkpad, I had to hold Shift+ScrLk to turn off Number Lock.
    Mar 27, 2009 | IBM Thinkpad 560 Series Laptop 20h4241...
    How do you use the green keys on an LG R500 laptop keyboard?
    I had a similar problem, kept getting french accented letters such as è, ç,à,é when i pressed keys like ", / , \ .... Anyways to solve the problem i pressed ctrl and then shift.
    it switched back after pressing this a couple times.
    Jan 21, 2009 | LG NB E500-JAP51A Notebook
    Code
    Look for a key with a coloured symbol,ie,indicating "keyboard 1",or something similar. Hold the code key down and at the same time press your selected key. Order should be restored. If not,look up an Olympia dealer and they will help you over the phone. One thing for sure ,you have inadvertely selected a 2nd or 3rd keyboard setting to accommodate an other daisy-wheel/language. Good luck!
    Nov 01, 2007 | Olympia Startype 3 Typewriter
    Computers & Internet Logo
    262 people viewed this question
    Top ASUS Computers & Internet Experts
    Alun Cox
    Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
