Question about Sewing Machines
Sears sewing machine Model 158.10400 Serial 0059105 !!! I think i'm missing parts ?
Hello Everyone, I have a Kenmore Sears Roebuck and Co - USA Model # 158.10400 Serial # 0059105. Everything on the sewing machine seem to work fine. But I think I'm missing some parts. Can someone please give me a list of all the parts that's for this sewing machine ?
  • Phillip Jan 16, 2013
    I found this Sewing Machine in the dumper with everything seem to be working fine. But couple people that I know. Say that I'm missing the bobbin and the bobbin case too. Also I don't know one thing about sewing machine. I think I'm better having someone to look at it. How much does it normal cost for someone to look and fix a sewing machine?
SOURCE: Instruction Manuel
I took the foot off and don't know how to get it back on. There is a curly pin that came off with it and I don't know where it goes.
There is the foot, screw, and pin. Help!
Thanks
Model# 385.17628890
Posted on May 02, 2008
  • 323 Answers
SOURCE: instructions for theading a Sears Kenmore Sewing machine model 158.14000
all machines thread the same. TTN tension,take up, needle.
Beginning with the spool, guide the thread through the thread guides to the tension assembly. Pull the thread through the tension assembly and test it to make sure the tension is working correctly.
(To do this test,adjust your tension setting to normal or medium or 5 or something in the middle. Raise the presser foot and pull the thread through the tension. It should pull easily!! Lower the presser foot and pull the thread. It should pull noticeably harder.) If it passes this test, continue up through the take up lever,then down through the thread guides to the needle. Make sure your needle is fully inserted and turned the correct way.( If you load your bobbin case from the left side,the needle rule is normally FLAT to the RIGHT is RIGHT. There are some exceptions. If you have a newer style drop in bobbin or your bobbin case loads in the front then the rule is FLAT to the BACK.
To wind the bobbin, guide the thread around the thread guide on
the left top of your machine, then to the bobbin winder. Wind the thread around the bobbin several times, place the bobbin on top of the bobbin winder, push it against the wheel and press the foot pedal. It should stop winding when the bobbin is full or you take your foot off the control
Sewman7
Posted on Jun 05, 2008
SOURCE: 1964 sears suburban 725 riding tractor model # 917.60634 manual. Sears Kenmore vintage sewing machine manual model# 148.12071.
go to www.sears.pammar.net for a few bucks he will send you the manual in a pdf. format
newbeginning1983@yahoo.com
Posted on Apr 04, 2009
  • 980 Answers
SOURCE: I need a manual for a Sears Kenmore sewing machine model 148.231
Try www.sewing-machine-manuals.com and click on relics and don't be put off by the word relics
Posted on Oct 24, 2009
  • 32 Answers
SOURCE: Owner's manual
I found a website for you that might help. They have a lot of kenmore manuals including one similiar to your model#148.12051. The manual opened as model 1205 so maybe searching for your model as the 1201 might help too. hope this helps! =)
http://homeappliance.manualsonline.com/manuals/mfg/kenmore/kenmore_sewing_machine_product_list.html
Posted on Feb 04, 2010
Minnnesota model E : threading the machine?
Try Sears. A lot of brands were similar back in those days (because they copied or re-badged other brands), so finding a threading diagram for an old Singer would probably be helpful.
Sears Roebuck and their Sewing Machines
Minnesota Model given to sister in law
Instructions For Operating the Minnesota Model Sewing Machine Sears...
Apr 18, 2017 | Sewing Machines
How to thread kenmore sear roebuck sewing machine model 158. 1789181 got at auction no books
Sears carries a lot of manuals for their machines, although usually not free. In the meantime, there are many threading videos that demonstrate machine threading. Machines of similar models will thread similarly.
Threading mom old kenmore sewing machine
Kenmore 158 17550 Sewing Machine Tutorial
Probably best to raise the presser foot when threading so the thread will seat in the tension disk.
Before trying to sew, be sure to oil your machine with fresh, good quality sewing machine oil. Open the top, the side near the needle bar, and turn it on its back to get the underside. Place a couple drops of oil every place that metal rubs on metal. Adding hot air from a handheld hairdryer will make the oil effective quicker.
Be sure to install a brand new needle and use good quality thread--not old or bargain bin variety!
On the top left, there is probably a push button. This is the presser foot pressure adjustment. When the machine is stored, this pop-up button should be released (press down on the outer ring). Being stored with the pressure full on will eventually compress the spring that provides the pressure. Also, be sure to store the machine with the presser foot in the down position (preferably on a piece of scrap fabric). Avoid running the machine with the presser foot in direct contact with the feed dogs as this will wear the feed dogs and also create grooves in the presser foot.
Kenmore 158 1601 Sewing Machine Cleaning oiling and Maintenance
Jul 29, 2016 | Kenmore Sewing Machines
I have been looking for 3 days! Still can't find the manual for the Kenmore Sewing machine model #148.13110! Please can someone HELP terryrp@icloud.com
Unfortunately, the manual is not available for free. Sew USA, http://www.sewusa.com , has various Kenmore sewing machine manuals available. I believe the manual you need will cost $10: http://www.sewusa.com/Sewing_Machine_Manuals/Kenmore_Manuals/Kenmore_1311_Instruction_Manual.htm .
I hope this helps.
Dec 02, 2014 | Kenmore Sewing Machines
How old is my sears Kenmore sensor sew 70 model# 3851950180? Iwould like to know if it can be repaired
Almost any machine CAN be repaired, but it may not be worth the money to get it repaired and with older machines finding parts can be a real problem.
If you call Sears and tell them the model and serial number they should be able to tell you the age of the machine, and whether or not they are still willing to repair a machine like it. They may not have parts though.. sometimes independent repair shops are a better bet. Ebay is often a good source for old machine parts too.
Nov 18, 2014 | Kenmore Sewing Machines
Need a manual for sears and Roebuck sewing machine model 158.15150
I've also looked for a manual, I suggest going to the sites listed
below & emailing them or calling them & ask them about a manual
sewvacdoctor.com
a1sewingmachines.com
Sep 24, 2012 | Sewing Machines
I am looking for a Sewing Machine Manuel for a Sears Roebuck
Do you have a model number? That looks like a serial number.
Pre 1955 machines were made by companies like National Sewing Machine company. After that they were made in Japan. So maybe to help us out... you can post a picture of your machine?
Jul 12, 2012 | Sewing Machines
Owner's manual
Feb 04, 2010 | Brother PC-420
Sewing Machines Logo
71 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
