Question about Gateway FPD1810 18.1" LCD Monitor
Gateway lcd monitor
My monitor is not booting up this morning. I keep getting just the Gateway logo and no further activity. At times logo flashes and other times is steady. I did not shut my computer or monitor off last evening. I have shut down the system by turning off power to no avail.
    Novelist:
    Champion:
  • 254 Answers
First, narrow down the problem to either the monitor, or to the computer itself. Either try the monitor on a spare or friend's computer, or try a known working monitor on your computer. I'd guess your computer is where the issue is at- it isn't booting the Operating System (MS XP or whatever O/S is present on the hard disk. if the computer is the issue, try booting from the CD which came with the computer, (assuming you have that CD). Or, you could see if some computer tech savvy person has a bootable floppy diskette. Basically a "no-boot" problem, can point to a number of problems: hardware issue (bad hard drive etc.), or an operating system problem.
Posted on Jul 10, 2007
SOURCE:
Screen is blank (white) when turned on.
Welcome to Fixya Support
I am Michelle, and i will be assisting you regarding the issue
Turn off the system. Unplug the power cord from the mains. Keep the power button of the cpu (not the monitor) pressed for 5-6 seconds. turn the unit bcak on and check.
Please reseat the monitor cable that connects to the desktop ensuring a secure connection.
Further, if you are able to see the Lenovo Logo on startup try booting to safe mode by tapping F8 key on the lenovo logo itself.
Howevre, in case you are not even able to view the lenovo logo on startup, then it could be a fault with the lcd monitor itself requiring a repair.
Nov 17, 2010 | Lenovo L191 (Black) LCD Monitor
My monitor doesn't want to stay on when I first turn my computor on in the morning. The screen keeps going black after a few seconds. I have to keep turning it off and back on several times before the...
That is a sign of dying power supply due to bad cDC filter caps.
Please read my guide and look at the album of bad caps so you will know what to look for.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed GATEWAY and other monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Oct 31, 2010 | Gateway FPD1975W 19" LCD Monitor
My gateway monitor flashes gateway logo then it (FPD 2185 W)
Look for bad DC filter caps in the power/inverter board.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
http://www.badcaps.net
Jul 27, 2010 | Gateway FPD2275W LCD Monitor
The screen goes very dark within a minute after booting up = I can just barely see the menu page
When you say screen goes very dark when it booted to windows so it means that when you turned on the laptop when the dell logo flashes the screen was fine? if thats the case could you please try this. after turning on the laptop you will see the dell logo flashes immediately keep tapping on F2 and then it will show you the BIOS setup utility, please check if in BIOS setup display goes dark as well. If yes then try this, after turning on the computer when dell logo flashes keep tapping on F12 to boot menu then select utility partition to run the diagnostics. Please run test on the LCD check if display goes black when running the LCD test. Then try this when you sees the dell logo keep tapping on F8 to boot in safe mode check if in safe mode display goes very dark. Try this too, boot in F8 then select last known good configuration check if the settings on your display will be fix. If you can boot to safe mode no problem then uninstall the display or video driver. then restart computer.
You can also try to connect an external monitor if you have one just try to isolate if issue is on the LCD or the video card. If the display is dark as well in external monitor then video card needs to be reseated if fails then replaced. In situation like this most video cards is integrated to the motherboards. So replace motherboard.
Dec 08, 2009 | Dell Inspiron 2200 Notebook
Screen on laptop keeps going black
please explain further. keeps going black from where? after turning on the laptop? of after windows logo? if after windows logo screen turns black if a no boot issue where laptop cannot load system files. if screen is black after turning on no manufacturer logo and windows logo or anything then it might be the LCD or video card / motherboard. to isolate try connecting your laptop to an external monitor and check if you will be getting the same problem. if no display from the external monitor then its a video card issue, if video card is integrated needs to replace motherboard.
Oct 01, 2009 | Computers & Internet
Gateway MA7 laptop
If display issue: connect an external monitor to see if any change.
Could be spyware - boot in Safe Mode (F8) - download, install and run SpyBot (spybot.com).
Good luck.
Jun 12, 2009 | Computers & Internet
No signal from computer to monitor 8/13/08!
I had the exact same problem!! Drove me crazy for days. Couldn't find any answers online, contacted Gateway tech support and they told me my warranty was expired but they'd be happy to discuss my issue for $2 per minute. Gateway can **** it!!
At first I thought the problem might be a malfunctioning NVIDIA card, a problem with my DVI cable, or the monitor itself. But, after turning off the computer, unplugging the DVI cable, replugging the DVI cable and restarting the computer, I noticed I could get the firmware flash screen to show, including the BIOS menu boot and the Gateway system reinstall screen to show. As soon as the Windows flash logo would display, however, the monitor would drop out and display the dreaded "No Signal" error.
This indicated the problem was a software one and not hardware! The cable, monitor and video card were all working fine. Then I remembered that Windows installed its automatic update a few days prior. In fact...
THE PROBLEM TURNED OUT TO BE A WINDOWS UPDATE INSTALLED A FEW DAYS PRIOR.
After succesfully booting into safe mode (F8 during the flash/bootup screens), I went to Add or Remove programs in the control panel, clicked on the "Show Updates" box on the top, and uninstalled the Windows update from a few days prior to the occurance of the error. After a reboot the problem was solved.
I hope this will help anybody else struggling with this error!
Aug 15, 2008 | Gateway FPD2185W 21 in. LCD Television
Monitor won't turn on, just keeps flashing the gateway logo on and off
Unless there is inadequate ventilation, your monitor could remain on all the time with little ill effect. Actually turning on and off your monitor actually puts more strain on it then leaving it on all the time.
If the gateway screen is displayed for a moment and then just turns off, I believe the inverter board inside the monitor has broken.
What's actually happening is that somewhere in the board more voltage then needed is "leaking" in and the safeguards on the board turn it off to prevent damage.
I would go and get an estimate from a shop. If the price is within 30-50 dollars of a new monitor, get a new one.
Mar 14, 2008 | Gateway FPD1975W 19" LCD Monitor
Gateway FPD 1960-uk 19 " LCD?TFT Monitor keeps going into standby
It sounds like the monitor whose writing comes up in pink has a problem with the RGB usually IC driven and all of them sound like they have faulty power supply boards. Will investigate further and give a more detailed answer. Hope this helps for the time being.
Oct 11, 2007 | Gateway 19" Flat Panel LCD Monitor
Open Questions:
AOL MAil CuStOMeR #!#$$%%{1.855.536**5666}#[email protected] HeLpliNe NuMbER NEW YORK This AoL MaiL USA phone number is ranked #2 out of 2 because 7,728 AoL MaiL USA customers tried our tools and information and gave us feedback after they called. The reason customers call # I855%^536%^5666is to reach the AoL MaiL USA Tech Support department for problems like Where to buy, Complaint, Tech support, Repairs, Returns. As far as we can tell, AoL MaiL USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. AoL MaiL USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I855%536%5666 and ways to call or contact AoL MaiL USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling AoL MaiL USA Calling AoL MaiL USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from AoL MaiL USA Tech Support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with AoL MaiL USA's Tech Support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare AoL MaiL USA's phone numbers against each other. Contacting AoL MaiL USA in General While I855%536%5666 is AoL MaiL USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I855%536%5666 is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach AoL MaiL USA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact AoL MaiL USA.
Oct 16, 2019 | AOL Computers & Internet
ROADRunner mail +I844~819,3382,~} customer service pHone NuMbeR - Roadrunner mAil customer serVicE pHone Number @+I844~819~3382 tMICo resolve all Roadrunner email mail products. ROADRUNNER EMAIL MAILAntivirus is an American multinational company which was founded by Roadrunner email mail using its company headquarters in Round Rock, United States of America.Contact Roadrunner email mail for Setup & Installation Roadrunner email mail Setup toll Free & Installation Roadrunner email mail Helpline number Connect is a utility carrier that lets in you to print and scan from anywhere. The Wi-Fi characteristic in it makes it very on hand and easy to use. So, when you have in the end determined to head for Roadrunner email mail Connect, Roadrunner email mail Helpline Phone Number you'll be searching out Roadrunner email mail Connect setup as well. So, here we're with all cthe setup process and for your to Roadrunner email mail Connect. Get Roadrunner email mail Setup Instant toll Free Roadrunner email mail Toll free Service Phone Number Usually, the setup technique takes a number of time. One technique if accomplished incorrect, they could break the entire manner and you may should do it again. That's why here you may ROADRUNNER EMAIL MAILAntivirus locate the approaches simplified to help you even if you aren't Toll free -savvy. Let us undergo the method Of Roadrunner email mail Connect setup for Windows and for Mac Out. So, Outright here we go thirdpartie_
Oct 16, 2019 | Carrier Computers & Internet
See all Gateway FPD1810 18.1" LCD Monitor Questions
Computers & Internet Logo
118 people viewed this question
Top Gateway Computers & Internet Experts
Ekse
Prashant M
Prashant M
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
