Question about Garmin Forerunner 305 GPS Receiver
Can't change date on garmin forerunner 305
Anyone know how to change the date on the forerunner 305? its brand new and have been for a few runs but all the dates are wrong and I've been through all the menus and there's no way of altering (or either seeing) the date. The time is right so that's something. also seems to take 5 mins to locate satelites...
  • 2 more comments
  • petersjunk Feb 28, 2009
    the 305 keeps recording incorrect dates for the workouts
  • maudigz Mar 08, 2009
    same problem with the Garmin listing an incorrect date for a run when I download into my PC... Any solutions?? Can the downloaded date be cjanged once downloaded??
  • tjseeley Mar 29, 2009
    I ran today (3/29/09) at about 6:30. It posted the date as 3/18 at after 9 p.m. This is rediculous! How can I change the date (the time appears correct on the forerunner).
  • struck1 Apr 14, 2009
    Yesterday was only the 3rd time I rode with my Forerunner 305 and the date it recorded was 6 days off. How do you change the date on this unit?
    NOTE: the first two rides were correct.
My 305 takes a while to locate satelites sometimes too, otherdays it is only a minute or so. Try not to be standing near the sides of any buildings / houses (out in the open) and also stand still if you are wearing it while it is locating the sattelites. Better still, I like to put it on the ground or on a table (outside) when I turn it on so the receiver is facing directly up to the sky when it is first turning on (while you are stretching or something), then put it on when it is ready to go.
Have you tried in the settings to change your location, then it will get you to confirm the date?
Posted on Jan 25, 2009
  • pseely Apr 27, 2011
    I have had the same problem a couple times with the date. "Maybe" we "paused" a previous workout, when we were actually done, and then when we began our "next" workout it inadvertently uses the previous date?
    Anyway, you can change the "wrong" date after you download into your PC. Once downloaded into Training Center, you then "export" it to your Garmin Backup folder. Then open it (it will be a text file) and do a "edit" - "replace" , searching for the erroneous date and replacing it with the actual date. However, save it not as a .txt extension, but rather with a .tcx extension. Otherwise, Garmin software will not recognize it. Go to "save as" - "all files" and add .tcx to the end of the filename. Good luck!
IT would appear the it is taking the time from the GPS signal ...
Posted on Mar 09, 2010
Just how is the date and time corrected or changed. The question is asked alot on this blog. But why no answer???????
Posted on Dec 14, 2009
It does not turn or or charge. Connected to laptop but got same results. Tried to install latest software but it would not the unit (forerunner 305). Message was that there was no unit connected...
Here's a few options: Soft Rest
- Hold down MODE + RESET for few seconds
- Press the Power button to turn on the device
Hard Reset
(This will erase all of your data inside the device)
- Hold down MODE + RESET + POWER for few seconds
Firmware Downgrade/Upgrade (2.9 > 2.8 > 2.9)
(This will erase all your data inside the device)
Software Downgrade/Upgrade
- Connect your Garmin Forerunner 305 to the computer
- Press the UP arrow button and hold while doing all the other steps below
- Press MODE + RESET for a moment (the computer will recognize the device)
- Dowload the Firmware from Garmin's website.
- Downgrade Firmware from 2.90 to 2.80. (You are still holding on that UP arrow button!)
- When the update is finished the Forerunner 305 should power on running the Firmware 2.80.
- Let go of the UP arrow button, disconnect the device from USB, connect it again and the computer should recognize it normally
- Update the Firmware to the current version.
Nov 04, 2012 | Garmin Forerunner 305 GPS Receiver
Garmin forerunner 305
You need to make sure the drivers and software is up to date.
Jul 20, 2008 | Garmin Forerunner 305 GPS Receiver
I have bought a new computer, windows 7. I cannot install driver for forerunner 305.
Glad to HELP YOU!
It's a well-known issue between Windows 7 and Garmin Forerunner.
Garmin company says it's a compatibility issue concerning the USB connection between the computer and the device and usually they recommend to be an Intel Chipset.
Try to download and install using the latest drivers available on their site on WIN 7 and Forerunner 305.m You have them ALL here and the USB driver was released this year and it's the last one on that list.
Mar 26, 2011 | Garmin Forerunner 305 GPS Receiver
Forerunner 305 GPS Receiver: How can I change my Garmin 305 from miles to kilom...
Page 48 of your manual, Changing Units of Measure. Settings > General > Units
May 17, 2010 | Garmin Forerunner 305 GPS Receiver
Garmin Forerunner 305 won't turn on and won't charge. Is there a fix or is this it for the device?
Look at
You can soft reset or hard reset the device. Hard reset deletes all data.
Apr 01, 2010 | Garmin Forerunner 305 GPS Receiver
Unable to acquire satellites with my garmin forerunner 305. a couple of guys using their 305s were able to quickly acquire.
I find my Garmin 305 is a slug to locate and lock on. But if I pull it off the charger just before I go for a run it locks on all most immediately. Give it a try and let me know if it works.
Jan 19, 2010 | Garmin Forerunner 305 GPS Receiver
No way to change the date, either from the device or from the PC...
The unit gets the date and time from the GPS satellite system, so you don't have to "change the date".
Jul 04, 2009 | Garmin Forerunner 305 GPS Receiver
Garmin Forerunner 305 GPS Receiver Logo
3,206 people viewed this question
Top Garmin GPS Experts
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
