Question about Toshiba Satellite L305D-S5895 Notebook
Keyboard keys malfunctioning
The keyboard on my laptop is not working as it should. When pressing the '1' key, it loads Windows Media Player. '2' opens up IE. The laptop works fine with a USB keyboard and the internal keyboard unplugged. I figured this would be a hardware issue with the internal keyboard, so I replaced it with a new one - but alas, same issue. Any ideas?
    New Friend:
  • 109 Answers
Need to take the laptop apart and clean or replace the keyboard
Posted on Jan 16, 2013
4 Suggested Answers
LRL Computer
  • 64 Answers
SOURCE: Toshiba Laptop Keyboard Malfunction
If you boot a XP cd and select repair will it let you type?
Posted on Sep 21, 2007
  • 1087 Answers
SOURCE: I have a Toshiba M35-S320 laptop that starts
The beep tone is not just for ram its as well for CPU. Could as well be a power grid issue with the board.
Posted on Aug 10, 2011
  • 6771 Answers
SOURCE: problem in keyboard keys are displaying multiple characters at the same time
Hook external keyboard to the laptop, if okay! replace the laptop keyboard, but if problem is the same, it may be device driver issue, or possible virus attack on your system, update definitions and run a deep or full scan, if okay, try a system restore and bring the laptop back to an earlier time before this happened.
Posted on Mar 11, 2012
My Samsung laptop's (np-r430-jb01ae) function keys are not working. how could i solve it?
Step 1:
Function keys are special keys used for assigning program shortcuts and specialty tasks to the keyboard. They are located at the top of most keyboards and labeled "F1" through "F12." Some keyboards may only feature 10 function keys, while others may have as many as 18. These keys often go unutilized by the average computer user, but they may have very important tasks for some users, which can lead to problems when the keys do not respond. Fixing nonresponsive or malfunctioning function keys is quite simple, and should only take a few minutes.
Connect your keyboard to your computer, and power it up. Open a program that uses the function keys such as Microsoft Word or Microsoft Excel. Check your keyboard for an "F-Lock" or "Function Lock" key. This key is used to toggle function-key support; when it is toggled on, the function keys will not work. Press the "F-Lock" key and then try using a function key in the selected program. "F1" is a good key to test, because it is set to open a "Help" document in all Microsoft software. If the key does not work, press the "F-Lock" key a second time, and test the keys again. If the keys still do not work and you are running the Windows 7 operating system, you may need to install a "hotfix" from Microsoft to fix the key functionality. Navigate to the link entitled "Microsoft Support: Some Function Keys do not Work Correctly." (See Below.) Some function keys or keyboard shortcuts do not work correctly on a computer that is running Windows 7 http://support.microsoft.com/kb/975741 Resolve unexpected Function (F1 - F12) or other special key behavior on a Microsoft keyboard http://support.microsoft.com/kb/894513 Click on "View and request hotfix downloads" located beneath the title of the article to access the Microsoft Hotfix database. Agree to the terms and conditions, then download the hotfix. When the download is finished, run the downloaded file and follow the on-screen instructions. You may need to restart your computer after the installation is complete. Your function keys should now work properly.
Feb 25, 2013 | Computers & Internet
How to replace the keybord on an advent 9517 laptop
Advent laptops are manufactured by DSG International, which owns the names to other name-brand computers such as Acer and Hewlett-Packard.
The Advent laptop keyboard has integrated mouse touch-pad functions that allow you to move the mouse around the screen with your fingers.
Function keys at the top of the board contain alternate ways to exit and enter software applications.
Function Keys
The Advent laptop keyboards function keys are "hot keys" that act as shortcuts to applications and functions on the computer. The function keys sometimes don't work and won't carry out the function assigned to the key. This problem is considered a hardware malfunction, and the solution is to replace the keyboard or use a universal serial bus (USB) keyboard for the laptop. b> Malfunctioning Keys b> Advent keyboards are made of thin plastic. Striking the keys too hard will cause the keys to break or stick awkwardly in the housing unit that supports the keyboard. When these keys get stuck in the housing unit, a pin tool can easily set the keys back on track. If there are too many keys that get stuck or broken, you can purchase a replacement Advent keyboard and have it installed. b> Mouse Problems b> The mouse is located at the bottom of the Advent keyboard but is connected to the keyboard data strip that sends information through the keyboard unit to move the mouse on the screen. If the mouse malfunctions, check the connector under the keyboard to see if it is loose. A loose connector can cause the mouse or other keys not to function on the laptop. b> Electrical Shortage b> An electrical shortage can cause an Advent keyboard not to work properly. A shortage is when the main board of the laptop is not getting the voltage needed to efficiently operate the computer. When this happens, certain devices underperform or become inoperable. Check to see if your power supply is extremely hot or if your system heats up around the keyboard. If so, replace the electrical adapter. b> Wire Damage From Keystrokes b> The wire that is responsible for the liquid crystal display (LCD) on the Advent laptop extends from under the middle of the keyboard to the LCD display unit. This wire is unprotected and can be damaged from striking the keys over the wire. When this happens, the display will not show the correct colors or the screen will go black. To eliminate this problem, purchase a keyboard cover that fits the keys to relieve the pressure between the keyboard and video cable. b> Keyboard Drivers b> Problems have been reported with upgrades from Windows Vista to Windows 7. Windows 7 will not recognize the system drivers that operate the Advent keyboard. To get the keyboard to work, you must load the old drivers in Windows 7 Safe mode, which is used anytime there is a hardware or software discrepancy. Advent keyboard drivers can be loaded from the original restore CD, which is included with the system at the time of purchase.
http://www.laptopkeyboard.com/Guides.php/Advent/Advent Series/9517 (Black)/KBAD3
Jan 29, 2013 | Computers & Internet
How do i reset my toshiba satellite L305-S5955 to factory default & erase all data from it?
Close out any software currently running on your Toshiba Satellite L305 laptop.
Navigate to the laptop's "Start" menu and choose "Shut Down."
Hold down the laptop's "0" key and press the power button.
Keep the key held down during the boot up process until the "Toshiba Recovery Wizard" window loads on the screen.
Click the check box labeled "Recovery of Factory Default Software." Choose the "Next" option.
Choose the "Recover to out-of-box state" radio button. Select the "Next" button and click "Next" again.
Wait for the "Press any key" prompt to appear and tap a key to restart the laptop.
Use the prompts that appear on the screen to choose your region, time zone and keyboard settings.
Type your new Windows user name and password in the text boxes when prompted. Click "Finish" to load the new operating system.
hope this helps
Sep 06, 2012 | Toshiba Satellite L305-S5955, L305-S5956,...
How to fix key on Toshiba Satellite L655-S5061 Laptop Keyboard
The keyboard is made that limited to no service can be done, replacement of the entire keyboard is required. Short term solution is use external keyboard if available.
Apr 15, 2012 | Toshiba Satellite L655-S5160 Laptop PC...
Key 'U' defaults to '4'
You have selected the Number Lock which turns the RHS keyboard into a number pad.
The NumLk key also doubles up as a ScrLk key, it is located near the F12 function key. When you press this key it will turn off the Number Lock, also the NumLk LED light will switch off.
Mar 02, 2012 | Sony VPCEE34FX/BJ Laptops. 15.5 screen...
I got windows loaded but keyboard is locked. i can't type anything.
perform the following on the keyboard
  1. On the keyboard press the windows logo (image below)
  2. keep holding the windows key whiles you press the key U key in addition
  3. You should have a list of options.............choose on screen keyboard and with your mouse you can login and keep using your pc without a physical mouse.
Aug 04, 2011 | Compaq Computers & Internet
Keyboard of myASUS K50IJ-XA1 15.6-Inch Versatile Entertainment Laptop (Black) is locked How to unlock the same? Kindly help
Well, do you mean only the keyboard is locked? Can you boot the system properly? Is the mouse working? Which Operating System is running on your Laptop?
Here are a couple solutions you can try before you let me know the above queries.
1. Press and hold down the Windows Logo key on the keyboard while pressing the L key on the keyboard once. In other words, Press Windows Key + L once. If this doesn't work, don't forget to include the Fn key while pressing these two keys. Windows+Fn+L. Still nothing?
2. Turn off the Machine, remove the battery and unplug the charger. Leave it for at least 10 seconds, you can press the power On button on the laptop without the battery and the charger installed/plugged in. Now re-install the battery, and turn back On the machine. It should work.
If you need further help, if the problem persists, Let me know with the details.
Good Luck.
Thanks for using FixYa.
Jul 24, 2011 | ASUS K50IJXA1 156Inch Versatile...
Some keys in my keyboard are malfunctioning. how do i correct this. if i press key( m) it will minimize the windows page am working on.when i press key (e) it will bring out my computer windows. i had to...
It seems like the control/alt button is in press state. If U can get air blower pass air to the key board.
There are some dust below the keyboard buttons
Mar 26, 2011 | Acer TravelMate 4150LCi Notebook
Laptop turns on but windows wont load. i ran diagnostic check and got error codes. error code 0f00:0244 uncorrectable data media or media is write protected
Please let us know which windows you are running and you mentioned that it doesnt load windows so doesnt it give you any message.
Also, Please try turnning on the pc in safe mode and let us know if its booting up there? Please follow the steps below.
1. Shutdown the pc.
2. Turn on the pc and as soon as you turn it on tap F8 key on the key untill you see advanced boot option.
3. Use the down arrow key on the keyboard and select safe mode with networking and press enter.
4. If it ask to select windows select windows and press enter.
5. It should show you the drivers loading window and then it should show you the normal screen with big icons.
Please let us know if it works and send us exact error and which windows (xp, vista)
Rashish
Aug 16, 2010 | Dell Inspiron 1000 Notebook
Keyboard keys L/G/R acting weird
It sounds like the Windows is registering the "Windows Key" as being in the "Pressed" position. This is the key between control and alt on the left side of the keyboard. Press it a few times and see if that helps. If it does not it sounds like that key or the keyboard may need replacement.
May 20, 2009 | Compaq Presario 700 470024-192 Notebook
Toshiba Satellite L305D-S5895 Notebook Logo
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
