Question about Toys
Backhoe will not go in reverse 1973 jcb 3c3 backhoe
I have removed the valve body found a spring broke have replaced it and reinstalled the valve body and still only goes frontwords
5 Suggested Answers
  • 164 Answers
SOURCE: I would like to know the weight of a jcb 1400b
if it is standard clutch and the weight is 8,550lbs w/converter and 8,430lbs with dry clutch and if equip with extendahoe pwer shuttle is 9,210lbs and dry clutch is 9,090lbs and those weights do not include front or rear buckets of backhoe and loader as this can vary because of the size of bucket equip with. hope this will help you. jcmarleau@aol.com
Posted on Aug 29, 2009
udesh99
  • 97 Answers
SOURCE: find the switch for the John Deere on the 2002 JCB Backhoe
I need more datials. Witch switch location you need ?
Posted on Sep 23, 2009
udesh99
  • 97 Answers
SOURCE: Transmission on Backhoe
I think you need Check your Transmission Pressuer of your machine. After That Change Recormanded Transmission Oil & Right Quntity. Transmission Pressure Should be 10-12 bar.
ranimaria79
  • 39 Answers
SOURCE: Have wiring fault on a JCB Backhoe 1987 3CX and
Hi
you can get wiring diagram from here.
Hope this helps, thanks!
Posted on Oct 29, 2011
Can't swing the backhoe arm left or right with the controls
The travel lock is either in place keeping it from moving in transport or there is something wrong with the hydraulics. Look for a push button release. The other thing is the stabilizers have to be engaged
Jul 21, 2014 | Jcb Bruder JCB Loader Backhoe
I have a jcb 214s will operate forward&reverse in any gear for approx. 20 minutes then seizes up and won't go either direction. Replaced layshaft-mainshaft valve and solenoids, replaced 4 wd valve and...
Old.
This forum states they are crap
http://www.heavyequipmentforums.com/showthread.php?540-jcb-214s-owners-opions
You should try asking there for more help.
Oct 28, 2013 | Jcb Bruder JCB Loader Backhoe
I need to know where the bleeding screw for brakes on jcb214e backhoe
most of those type of equipment have inboard brakes in the axle tubes of the rear gear assembly i.e. follow your brake lines from the master cylinder to the rear axle assembly,the lines usually go in and to a caliper and another line comes out to a bleeder tip nipple ,some models are actually inside the axle tubes them selves requiring disassembly of the wheels ,axle tubes etc. until you get to the inboard rotors and calipers ,major work for such a minute ordeal this is done to keep the system protected believe it or not,i would obtain yourself a model repair manual if i were you or you could also go to jcb and ask them for a photo copy of the entire brake hydraulic system
Feb 28, 2012 | Jcb Bruder JCB Loader Backhoe
Jsb will go forward and back for few seconds and then dont want to go forward and back
there will be oil leak or malfunctioning in the front & reverse gear ratio..its better to get ir repaired by a Mechanic
Thanks for rating Good luck
Jan 18, 2011 | Jcb Bruder JCB Loader Backhoe
Where i can order jcb 3cx part?
If I talk about India than I can suggest to you a good amount of JCB Spare Parts Manufactures and You can deal all parts Related to JCB And Backhoe Spare parts also Order From Here.
Nov 29, 2010 | Jcb Bruder JCB Loader Backhoe
I would like to know the weight of a jcb 1400b backhoe
Aug 29, 2009 | Bruder Mack Flatbed Truck with JCB Backhoe
Jun 14, 2009 | Bruder Jcb 4CX Loader
Toys Logo
37 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Toy Expert? Answer questions, earn points and help others
