Streaking or banding on the papaer
I have an old sharp SF-7370 that is giving mw veryicle lines on the copies that are not related to what is being reproduced. What could be the problem?
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 126 Answers
*** NOTE*** does machine have an ADF (auto document feeder)? Are you feeding the paper through the ADF to make copy? IF machine has ADF and you get the lines from that, place original on the glass and make copy. Does the copy have the lines? If so continue. If not lines then clean the '**** glass' ( thin small glass that the original is pulled over in the copy/scan process. This is under the ADF.
Next, if problem not rectived, it depends on how the paper is fed ( comes out of the machine). Let us say that the paper cover out of the machine 'letter' or ' portrait' and you look at the copy --- the lines are from left to right on the copy, okay. These lines could be from the fuser ( the hot area), pull the fuser out and look at the fuser rollers. Do the fuser rollers have lines -- if so then the rollers need to be replaced. If not then you are looking at the drum / transfer unit. Probably a blade is bad and will need replaced. To tell whether it is drum or transfer -- start to make a copy and open the front cover as to stop the paper in mid-stream. This way you can tell which unit has the problem.
NOW -- lets us say that the paper is coming out 'letter' again but the lines are from Top to Bottom. You will also want to look at the drum and/ or transfer units. This would but a 'stall' or 'blade skip' problem. Again, start to make a copy and open cover in mid-stream to see which unit has the problem.
If the drum unit is the problem, replace blade and maybe drum. IF the transfer unit is bad, replace transfer blade, roller and maybe the transfer belt ( if belt is present). Some transfer units use belts and other rollers.
Posted on Jan 24, 2009
Sharp arm236 photocopier with white and black banding on copies
Try replacing the main charger also inspect the drum if worn replace it too Copy Systems
Jul 27, 2016 | Sharp Office Equipment & Supplies
Sharp SF-7370 copier, with a dark line going from top to bottom
check the drum cleaning blade maybe the blade is worn out
Jan 04, 2010 | Sharp Office Equipment & Supplies
SHARP SF-7370 Developer replacement light is on and periodic maintenance light is on How do I fix this
you need a technician to vacume out old developer, install new and callibrate copier.
Nov 11, 2009 | Office Equipment & Supplies
SF-7370 multiple black streaks on copies even when set to lighest setting.
Sounds like the drum cleaning blade is failling. If you open the machine and the drum is dirty, then it is the blade.
Sep 24, 2009 | Office Equipment & Supplies
My copier is a Sharp SF Model 2215. I replaced
It is the drum.
Reasonable cost? That's up to you.
Call a few service depots and ask. Then decide if you want to invest the cash.
Jul 14, 2009 | Sharp AR-M205 Copier
Black blotches and streaks on copies
Sounds like a worn drum unit primarily the cleaning blade on the drum is failing. If you don't change it out soon the dirt escaping from the drum and dirty copies will foul-out you fixing unit, = more $$.
Jul 09, 2009 | Sharp AR-5316 Advanced Digital Imager...
Big streaks on copies from Sharp SF-7800 copier, not fax machine.
You probably have some build up on the glass, which happens if you use the auto feeder most often. Alcohol type cleaner will remove with a very softcloth. One small dot will look like a long streak on a feeder, much like a streaked fax. The other issue is the photoreceptor belt has nicks or is dirty eaither way it needs to be replaced. Try the cleaning first and you may have to look hard for the small dots built up on the glass.
May 11, 2009 | Sharp Office Equipment & Supplies
H4 error on Sharp SF 7370
The heater lamp isn't coming on either because of blown heater lamp or thermostat reset itself . Clean the thermistor and replace any of the above defective part.Then press C, 0, 0, C and press 14 press READY.
Mar 12, 2009 | Sharp Office Equipment & Supplies
LONG WHITE VERTICAL LINES
It sounds like the drum may need to be replaced. The streaks may be caused by sections of the drum no longer being able to hold a charge and therefore, toner will not properly stick to the paper in those sections and you'll be left with long white streaks on the paper. This is a usual symptom of a bad drum.
Jan 13, 2008 | Sharp AL-1000 Laser Printer
137 people viewed this question
jasbo
jasbo
