Question about Water Sport
I need to know how a 1992 Yamaha Waverunner III crankshaft comes apart
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 118 Answers
You need a press, a hand full of jigs, a few special tools and a manual for specs. Believe me your gonna be better off sending it out for repair or buying an aftermarket one from either ADR, Crankworks, or competitive crankshafts.
Posted on May 27, 2013
2 Suggested Answers
PWCYoda
  • 118 Answers
SOURCE: I have a 1992 Yamaha Waverunner III that needs a
No gasket, just an o-ring that should already be installed on the new starter.
Posted on Oct 24, 2011
Yamaha waverunner 111 1992 model will not restart after running and then shutting off for 5 minutes or longer
sounds like the coil,as the 5 minutes it needs to cool down,the primary or secondary winding insulation has broken down.
Jun 01, 2014 | Yamaha XL700Z Waverunner
Yamaha waverunner does not start
hi there it sounds like the switch gear need pulling apart and the copper contacts cleaned as it sounds like the kill switch is closed up and the starter button contacts need cleaning as well also check to see if the stater soliniod might need a cleanup where the wires go,also check your fuses to see if there contacting alright if you ride in all weather or the bike sits outside it can have these problems as mouisture gets into everything. hope this helps cheers pete
Jun 12, 2013 | Yamaha 98 Gp 1200 Air Box Intake Mount...
Jet ski start is not working
is the starter button putting out power to the starter?
Jun 29, 2012 | Yamaha Jet Ski Pwc Cover For Waverunner...
I have a 1992 Yamaha Waverunner III that needs a new starter. Is a gasket used between the starter and engine?
Oct 19, 2011 | Yamaha 12V Air Pump
My 1992 yamaha waverunner iii 650 is taking on water?
I know this sounds obvious, but make sure the plugs are screwed in.
usually 2 of them at the back of the waverunner.
i know i forgot to put them in one day and by the time i parked the truck & trailer it took on so much water the motor was half submerged.
Hurried and pull the truck back and got it out and let her drain iout the plugs, then fired it up.
anyhow, if thats not it then your hull must be cracked and leaking in, take seat off at the ramp and see if you can see where its coming from, if you don't notice anything, then its coming in through
the ports at the top of the wave runner under the steering assembley housing, those tubes are made to direct the water to the bottom, if you have an auto matic bilge pump, make sure that is working or it won't pump out the water like it is supposed to.
hope that helps
Big Al
Jun 01, 2011 | Yamaha Boating
YAMAHA WAVERUNNER 2000 XL 800, WILL NOT RUN PAST 12 MPH
Have you done a compression test on all cylinders? My guess is you have a dead cylinder (no oil to one or more cylinders causing loss of power). If the compression test passes (all cylinders equal and higher than 100-110 psi) you have a restricted exhaust from a failed catalytic converter that has broken apart.
Apr 05, 2010 | 2003 Yamaha YZ 250
Yamaha waverunner excessive smoke
White smoke means coolant in the combustion chamber. Most likely a blown head gasket. You will have to tear the engine apart to be sure.
Jul 12, 2009 | Yamaha XS 650 G Motorcycles
MY YAMAHA WAVERUNNER 3 RUNS GRATE FOR ABOUT THREE MIN AND THEN ACTA LIKE THE REV LIMITER KICKS IN IVE REPLACED THE COIL AND OVERHAULED CARB ANY HELP WILL BE THANK FULL 1992 650 YAMAHA WAVERUNNER 3
You should check your feul filter or maybe the feul tank it could be you have trash in your tank and it takes a few minutes to pick up the trash and restrict feul flow possibly not clogging the filter all the way allowing just enough feul for it to idle
Jul 08, 2009 | 1979 Yamaha XS 500
Water Sport Logo
66 people viewed this question
Top Water Sport Experts
Tom Chichester
Bill Boyd
Are you a Water Sport Expert? Answer questions, earn points and help others
