My volume output is not working
Volume all the way up still doesnt work
    New Friend:
  • 109 Answers
Scroll down to your settings and check the volume setting you may have turned it off in your pocket or backpack
Posted on Jan 16, 2013
When my tv is playing regular cable the volume doesnt work but when i play a dvd in the dvd player volume comes out of the tv, whats wrong?
Good--sound when playing a DVD means either a setting is wrong and it can be in the set or a box if connected---it also means the audio output circuit is good.
Worst case is where sound is developed by the set's tuner there may be a problem but check all audio settings first---
Jun 12, 2012 | Hisense LHD3204US 32 in. LCD HDTV
Connecting to ports?
Generally the input/output jacks on computers are color coded and the green is for speak output. If you still don't get sound, verify you have working sound card drives installed in your OS and that the volume isn't muted.
Jun 09, 2010 | HP JBL Platinum Computer Speakers
The tv sounds doesnt work
Check the mute control from your remote. If ON/OFF is working ok, it may be sound circuit problem or speaker
Apr 23, 2010 | Daewoo DTQ-13V1FC TV
How to install klipsch sub woofer to yamaha reciever rx-v559. everything working properly but sub wont be adjusted with volume. i got my stuff moved out here but had a mate help me set up. didnt pull it...
Does the sub work at all? How is it hooked up? The sub needs to be fed by an RCA cable from the Subwoofer Output jack for the receiver to control its output.
Mar 01, 2010 | Yamaha RX-V559 Receiver
At a time only two speaker works out of 4
1. Open Control Panel > Sounds and Audio Devices. 2. Click 'Advanced' Button near the bottom. 9d7466a.jpg
3. Select proper sound system (Quadrophonic or surround sound) according to your speaker system.fc6ac4d.jpg 4. Click 'OK'. 5. Also check volume. 6. Double-click Volume icon in taskbar. 7. Click Options > Properties (From menu) and select 'Playback'. 8. Select all Audio components. 9. Click 'OK' 10. Increase all the volumes.
Now try playing a sound. Good Luck!
Jul 30, 2009 | Computers & Internet
Output port for left speaker Z2300
I've been having the same problem actually.
In my situation, turning the volume up and down using the speaker volume control will fix the problem. I only have the faint volume problem at some positions of the dial. turning it up usually fixes it. I'm thinking that opening it up and cleaning it might fix the problem (it used to work with an older set of Creative speakers i had).
If that doesnt work im going to try to get a new remote from logitech.
Jul 02, 2009 | Logitech Z-2300 Computer Speakers
Connection
The monitor outputs on most Sony TV's are regulated by the volume level. In other words if the volume is set low then the output will be low. Go into the menu of the TV and turn the internal speakers off and then see if there is an option to set the audio output to FIXED or VARIABLE. Set it to fixed and all should be good to go.
Jun 08, 2008 | Sony BRAVIA KDL-40V3000 Television
Audio
Go to START, PROGRAMS, ACCESSORIES, ENTERTAINMENT, Volume control. With the volume control open, see if the volume is muted (Checkbox marked mute at bottom of Master volume) If it is checked, uncheck it, and you should have sound.
May 16, 2008 | Computers & Internet
My Tx-sr600 shuts off when watching movies at level 65
You are either getting DC voltage leaking into the final amp stage or the unit is heating up and the temp sensor is shutting down the outputs. Without taking measurements, it will be hard to determine remotely. I would suggest a trip to the service shop. If you are getting DC voltage leakage, the parts cost will be arount $10 or so. Add in the local labor rate for the total repair cost.
Dan
Apr 08, 2008 | Onkyo TX-SR601 Receiver
Problem with boston acustics subwoffer
> check it in another computer
> if problems persist check setting of speaker also connectivity
Dec 02, 2007 | Boston Acoustics MicroMedia Computer...
29 people viewed this question
 Grubhead
Grubhead
