Question about Pioneer VSX-D409
Have a load uncontrollable volume with my Pioneer VSX-d409 receiver. A suggestion for a low volume problem was to correct with tuner cleaner (potentiometer ) problem. Can this be corrected by me as perhaps suggested on your forum or do I need professional service?
    Top Expert:
  • Pioneer Master
  • 41,853 Answers
Your problem is not with FixYa, but rather the volume control potentiometer on your Pioneer receiver. As for whether you can fix it yourself, that depends upon your ability to disassemble the receiver to gain access to the volume control and make the repair
Posted on Jan 16, 2013
Hdmi has no volume from sources
Not surprising. The VSX-D409 doesn't have HDMI.
Aug 11, 2011 | Pioneer VSX-D409
I can get the surround speakers to work, but can not get the main 2 speakers to work.. what am i doing wrong?
You're guessing.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Pioneer-VSX-D409-Receivers-manual/id/385ci977/t/2/
Of course, the speakers are also a part of this. I imagine they have manuals, too.
Apr 09, 2011 | Pioneer VSX-D409
Where do I connect the sub on the amp
The manual:
A powered subwoofer would get its Line Level input from the Subwoofer PreOut (page 14)
Pages 16-22 discuss speaker type, distance, levels settings
Jan 25, 2011 | Pioneer VSX-D409
Pioneer Amp VSX-D409 Volume
I have a VSX D508 Looks just like the VSX D409. Had the same prob with the volume control when I bought it. I first tried the cleaner. Better than what it was but didn't compleatly solve the problem and before long it was getting worse again.
It does have a rotary encoder instead of the traditional varible restance volume control. I finally broke down and removed it from the board and lightly sanded the contacts with fine sandpaper.
This involves removing the whole face from the main board and chassis. Not that bad, a couple screws and some ribbon jumpers and latches and it's off.
Next carefully pull the volume control straight off the shaft, remove the nut under it and lay it face down on a soft surface. Remove the screws that hold the circuit board to the face and slowley seperate the too, you'll have to release some latches also to sepperate them.
If you replace the volume control with a new one or clean the old one you have to go this far because it's soldered to the front side of the board. Yes, it has to be de-soldered from the board.
This control was not designed to be dissassembled but I was able to carefully open it and remove the shaft to totaly expose the contacts for a complete even couple of passes with the sandpaper.
I did have to use some 5-minute opoxy when I put it back together because I couldnt get the metal tabs to close as tightly as they were before it was opened.
I soldered in the volume control, put it back together and it's worked perfectly ever since. I don't know how much pioneer wants for a new one but I can tell you they wanted $69 plus shipping for a new remote for my receiver. And with this style of volume control you might be at their mercy as far as finding one from another source that fits.
Feb 13, 2010 | Pioneer VSX-D409
I need a help to find the nomber part of the volume control
Volume control or rotary encoder part number: ASX7004, located on a small board - rotary encoder assembly: AWX7386
http://futureshop.partsearch.com/Part/Pioneer+Electronics/Pioneer/VSXD409/Pioneer+Electronics/Pioneer/AWX7386/New.aspx
Jul 10, 2009 | Pioneer VSX-D409
Im trying to hook my pioneer vsx-d409 multi channel receiver to work with my new3 philips hdtv. it would not work please help
What isn't it doing - audio, video, both? What model is the TV. How are you trying to do it. Do you have the manual? The simplest hookup is to just have the a single RCA cable from "TO TV Monitor" to a Video In on the TV. Modifications may be required depending on what else you have for video sources and how they're attached.
Go here for it. Register and search for things, like vsx-d409...
Feb 02, 2009 | Pioneer VSX-D409
Volume problem with VSX-D409
Had the same problem. I had to replace the volume contol. It was inside the receiver behind the knob. It has a part# on it. Mine was part# AWX7386 (control assembly) from Pioneer.com. If you can figure out how to open the case than you can change this piece. Good luck
Dec 23, 2008 | Pioneer VSX-D409
VSX-D409 - Standby Light - Does not Power On
Hi...
Make sure all the speakers are connected properly at BOTH ends.
If still **** then seek a service tech
Nov 27, 2008 | Pioneer VSX-D509S Receiver
Popping noise and loss of sound
Check the preamp Coupling Capacitor, which might have lost its value, or might have leaky dielectric.
Feb 24, 2008 | Pioneer VSX-D409
Open Questions:
Pioneer VSX-D409 - Remote Control Problem Hello. I'm from Brazil and I have a 12 years old Pioneer VSX-D409 Receiver. My problem is related to the page 16 and 17 of the Owner's Manual. I'm trying to do the steps to Set up the surround mode, changing some settings and the type of connection I use to delivers sound to receiver, using optical cables. Well... I just cannot enter this mode, the surround setting mode. At this moment I'm hearing the sound from a FM station on the speakers. But just this function works. Tuner, wiht FM station. The remote control works only to: - Turn on or off the receiver. - Change the volume level. - Set the loudness function (on or off). - Change the function of the receiver (to select Tuner, DVD, TV or other device in, but I don't gain access to change some specs like distance, speakers volume levels or type of connection of each device). And nothing more. The remote control has seven buttons on the top: DVD/LD, TV/SAT, VCR/DVR, CD, TUNER, CD-R/TAPE/MD and TV CONT. According to the source device you want to use, you just press the button and the receiver selects the IN connection (coaxial or optical or just the Tuner to listen FM stations) and reproduces the audio. Until last week, anytime I press this button, the source device was selected. But, of course, I didn't use all of them. Just two: TV SAT and DVD. Why? This receiver has two optical IN units on its backside. I have two optical cables connected in the receiver. Optical 1 is connected to a PS3 and Optical 2 is connected to a SmarTV. Before my hollyday's trip, all the connections were allright. But not today!! The problem is: I do not have access to the process to change the type of connection that is assigned to the device I've choosen. I want to do this: TV/SAT --> OPT1 (to the audio from PS3); DVD --> OPT2 (to the audio from Smartv); The process is described at the page 16 to 21 of the owner's manual. But, it doesn't starts. Seems my remote control just forgeted how to do this or is blocked in another function. I don't know how to fix it and need some tip or help. Thank You! :)
Jan 07, 2014 | Pioneer VSX-D409
See all Pioneer VSX-D409 Questions
Pioneer VSX-D409 Logo
178 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
