Question about Pioneer IS-21MD CD Shelf System
Pioneer dv55sw-k speakers
Pls i need the cables or connector to my pioneer model;xv-dv55 speakers
SOURCE: I need a ac power
I need the ac charger for Audiovox portable DVD Player D1812
Posted on Nov 04, 2008
techjuli
  • 157 Answers
SOURCE: How to multi region my Pioneer XV-DV55
Most have "hack codes" but yours is in a select group of a few that simply cant be done with a couple pushes of a button.
As far as I am aware the only way to get thesemachines to play Region 1 discs is to have them chipped. A variety of solutionsare available, and it needn't be expensive (typically £30 to £70) but youshould be aware that any internal modifications to your players wouldinvalidate the warranty. Have a look at the following web sites for moreinformation:http://www.techtronics.com/uk/shop/50-000-dvd.html
http://www.maxking.co.uk/dvdmod.htm
http://www.dvdchips.co.uk/
I know you were looking for a free solution you could do in a matter of seconds and sorry it didnt work out that way. Regardless, I hope I pointed you in the right direction and feel free to ask if you have any more question.
Happy Holidays,
TJ
Posted on Dec 15, 2008
  • 3 Answers
SOURCE: I have a Pioneer xv dv55 . My sub or speakers are not working!
I've had mine for nine (9) years and it fine, first make sure all coloured wire are connected to the sub correctly, press sys on your remote then press button 8 to test if the speakers are working then increase the volume to hear the spaekers. so to link TV audio/sound with DVD press sys then A-2 on the DVD remote, I hope these will solve ur problem?
Posted on Jun 25, 2009
  • 336 Answers
SOURCE: Lost Pioneer XV-DV55 Remote Control
http://parts.pioneerelectronics.com/model.asp?modelNum=XVDV55
You can also look on ebay or other sites.
Posted on Nov 25, 2009
Testimonial: "Thankyou ever so much for your help, just what I was looking for!! "
  • 4 Answers
SOURCE: for the pioneer dvd tuner system xv-dv55 what is
the dvd player, speakers etc take their power from the subwoofer.
Posted on Apr 19, 2010
I have a pioneer XV-DV55 and the center speaker and Left and Right rear speaker are not working. What should i do?
Did you check your speaker selection switch to make sure that those units are getting power? If that is not it I am afraid that you may have a problem with the dts audio chip responsible for the decoding of the different channels ..I had this happen with my Pioneer 9700 receiver.
If you have an amplifier module that powers certain channels see if there is an amp module that powers those three areas. If so, it could be THAT amp module that is defective since lots of newer receivers do not have discrete amps for each channel and resort to modules to supply power to two or three channels at a time ala Panasonic receivers.
Aug 27, 2015 | Pioneer Xv-dv55 5.1 Home Cinema System
Pioneer xv dv55 does not recognise CDs
You have a bad optical pickup, meaning a bad laser. For more information, or should you have any further questions, please visit my website at audioserviceclinic.com. You may contact me directly through the website. Thank you.
May 29, 2013 | Pioneer Xv-dv55 5.1 Home Cinema System
Is it possible to upgrade my xv-dv55 with a new blue ray player but retain the sub and speakers?
Just an opinion. Probably not. It's not just the physical player that is different. Supporting electronics would need some changes, too.
Apr 23, 2011 | Pioneer Audio Players & Recorders
How do I connect the Pioneer subwoofer s-dv55sw-k to a different receiver.
I'd take a clue from the highly-proprietary interconnection and this warning printed right on the back, "USE only with XV-DV55";
http://cgi.ebay.co.uk/Pioneer-S-DV55SW-Q-HiFi-component-Active-Sub-Subwoofer-/400202114586
... and this warning from the seller in this example, "NOTE this is a specialized component unit, meaning it is only compatible with certain Hi-Fi's of the same brand, be sure to check compatibilty on the web BEFORE purchasing."
The little molex connector leading up to the subwoofer itself is probably one way to access it as a passive speaker without the lower section's amplifier. Measure its resistance. If it's about 8-ohms you may be able to drive it with an external amp.
Apr 23, 2011 | Pioneer IS-21MD CD Shelf System
No sound from front center and rear speakers on my xv-dv55
Hi
1st check your cables are inserted into the subwofer (which is the powersource)
however it sounds as though you have switched the player to mono mode to reset it try this
2. On your remote press the system button with the green ring around it 3. Then press the dts button (number 7) keep pressing it until the auto option appears (watch the little black display screen)
hope fully that should fix it
I am assuming that you no longer have the manual other wise you would have checked in there? But if you do and this does not work try read the first few pages on setting up the sound for your system.
Lou
Apr 05, 2010 | Pioneer DV-340 DVD Player
For the pioneer dvd tuner system xv-dv55 what is its power source?
Jan 14, 2010 | Televison & Video
Jun 06, 2009 | Audio Players & Recorders
Dvd player only plays in b&w, and connectors dont seem to match up with tv
I had this problem too. I had to use the cables that have red white and yellow and the back of the dvd player had red whit yellow but also had another set of red blue and green. I had to hook white to white,yellow to green and red to blue and it fixed it. Hope this helps
Sep 09, 2007 | Televison & Video
Pioneer IS-21MD CD Shelf System Logo
197 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
