Question about Star trac ST Fitness 8910 Treadmill
L13 Perform Scheduled Maintenance on Screen. Then it did not work.
Carry out maintenance
1. Perform cleaning cycle.
2. if machine does not clear then it time for Scheduled service. (powering down machine won't reset this warning)
Nov 01, 2011 | Espresso RMI La Cimbali Espresso Machine
Lamar 1400 message "Perform Scheduled
My Lamar 1400 says" L 14 scheduled maintenance" and will not run.
Nov 02, 2010 | Startrac Fitness Products Lamar L1400...
The scheduled maintenance light has turned on. What do I need checked/replaced?
For the above head computer display, press the STEP button until you see the screen indicating that there's 0 miles remaining for scheduled maintenance. Then press and hold the reset button until that value returns to it's default state. This alarm is simply a mileage count down alarm to remind you of oil changes, air filter changes, etc. Resetting it will clear the alarm.
Oct 19, 2010 | 2005 Jeep Grand Cherokee
Displays a message "perform printer maintenance" What maintenance am I supposed to do?
This means that the printer is due for it's scheduled maintenance. Things like paper feed rollers, separation roller, transfer roller and fusing unit are due. Now if I were you I would just ignore it as long as you are not having a lot of jamming problems or double imaging/print rubbing off issues. I have seen these HP's run way past the maintenance schedule. You will do absolutely no harm if you continue to run it. The parts that are due to be replaced will continue to wear and eventually you may have to do at least some or all of the maintenance but for now I would not worry about it at all unless like I said you are having problems. As a side note I work on HP laser printers for school districts that do not want to spend money on printers so I have seen lots of these printers with the "perform maintenance" indicators on for a year or more with no problems.
Good Luck and Thank You for using Fixya.
Sep 07, 2010 | HP LaserJet 5100tn Printer
I am trying to find out what maintenance needs to be done on my 2008 ford fusion. It has 42000 miles on it.
The best place to get this answer would be the user manual. If you no longer have the user manual get the Haynes Repair Manual for your vehicle from the local auto parts store. This manual will have all your scheduled maintenance and instructions on how to perform the maintenance yourself.
Jun 18, 2010 | 2008 Ford Fusion
Mileage for next scheduled maintenance 2003 Acura 3.2 TL
the next scheduled maintenance should be at 50,000 miles and the car should be under warranty still.
May 14, 2010 | 2003 Acura 3.2TL
Is there a scheduled maintenance for the throttle in the fisrt year of ownership?
i work for a dealership and we check throttle, brake,and clutch freeplay and adjustment on every bike we work on.
Jul 04, 2009 | 2007 Suzuki GSX-R 600
Contact clubhouse, overiding or attempting to change setting may cause more damage than good. Especially if you don't know what you are doing.
Jun 02, 2009 | Startrac Fitness Products Lamar L1400...
Lexmark T642
There is a great video that shows step by step how to install the fuser, transfer roller, charge roller, pick up tires and then reset the 80 Scheduled maintenance message
Apr 03, 2009 | Lexmark T642 Laser Printer
Lexmark x642e MPF Reset maintenance counter
Hi~
You can reset the maintenance count by going to the Configuration Menu.
Step 1: Turn off your X64x printer
Step 2: Hold the 2 and 6 buttons while the printer is off
Step 3: Turn on the printer but don't release the buttons yet. Keep holding those buttons for about 10 secs
Step 4: On your Operator Panel, you should see "Configuration Menu"
Step 5: Scroll down and look for "Reset Maint Count" and select it.
Step 6: Exit Config Menu and powercycle your printer (turn it off then back on)
Hope this is helpful... =)
<<ichtuscheeky>>
Jan 30, 2009 | Lexmark X642e All-In-One Laser Printer
Star trac ST Fitness 8910 Treadmill Logo
54 people viewed this question
Top Star trac Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you a Star trac Exercise and Fitnes Expert? Answer questions, earn points and help others
