Question about Ford 555 backhoe
Ally...where is drain plug on transmission for drainign/changing fluid on ford 555
  • Ford Master
  • 2,478 Answers
Look on bottom of transmission.
Posted on Feb 26, 2013
Where is the transmission fluid drain plug located on 2006 ford freestar
The videos indication you need an oil transfer machine which is a vacuum cleaner machine. The third link explains how to fit a drain plug to a Freestar. It is probably a job better done by Jiffy Lube or similar.
2006 ford freestar transmission fluid drain plug Google Search
Ford CVT transmission service 2006 2009 Freestyle 500
Mar 10, 2018 | Ford Cars & Trucks
How to flush ford falcon 4,0L engine automatic 1996 model transmission
I'm not familiar with your vehicle, however the principle is the same for virtually all auto transmissions.
Get underneath your vehicle and look on the transmission fluid pan. Somewhere at the lowest point you will see a drain plug.
The plug may either be a nut or a recessed square, or even a hex recess.
Undo the drain plug and allow the transmission fluid to drain into a large plastic dish/container.
The link below shows you generic images of drain/filler plugs. It is not your vehicle:
auto transmission filler plug Google Search
When drained, replace the plug.
Then look for the filler plug. It will be higher up on the transmission case than the drain plug. Again, it may be a nut or a recessed square/hex.
You then have to use bottles of transmission fluid to refill the transmission. It can be messy ... The small bottles of transmission fluid - they have small tubes attached - can be very awkward to turn upside down when you're under the vehicle.
Alternatively, if you have a a long tube and a funnel you can use it to refill the transmission via the transmission dipstick tube. It can take a while to fill it as the fluid is slow to go down the tube.
Be prepared to get transmission fluid everywhere ...
Replace the same amount of fluid that came out. Start the car and move it through its range of gears. Check the fluid level.
It's not a difficult job. The link below is an easy guide:
How to Add Transmission Fluid
The job is worth doing. It will extend the life of your transmission. Most people never bother. Transmission fluid is supposed to be changed every 20,000 miles.
Mar 27, 2016 | Ford Cars & Trucks
How to change transmission fluid
There is a drain plug on the tranmission pan on the 2003 Ford Escape. Unscrew it to drain the fluid, put the plug back, and then refill the fluid through the dipstick under the hood. Capacity is listed as 10.1 quarts, but eye how much comes out. You might want to change the fluid, drive it for a bit, and then do it again to get as much gunk out as possible. I would recommend reading through this forum topic, it has a lot of good information.
http://www.ford-trucks.com/forums/810270-escape-transmission-fluid-change.html
Apr 27, 2015 | 2003 Ford Escape
2008 ford escape transmission fluid change
If you do not have an oil dip stick for the transmission the you will not be able to do this service. the drain plug (if there is one) will be in the bottom to one side . But if you do not have one then the pan comes off and the filter changed and then the correct volume of oil is sucked into the transmission by the pump. IT requires fully qualified people to carry out this service
Dec 26, 2013 | 2008 Ford Escape
1995 ford aspire trans axle fluid level
you should see a plug that looks different from the oil drain plug on the transmission pan, or near the bottom, on the side of the transmission.
remove, drain. You refill through the dipstick tube for trans fluid.
If it's a manual trans, there will be another plug higher up on the trans.
this one will be the fill plug.
Also on the manual trans, some people just remove the shifter and add fluid in the large hole up top.
Youtube and google will be your friend here.
Dec 24, 2012 | 1995 Ford Aspire
How do i check tranmision fluid on a 2004 ford exployer xlt. It has no dipstick to check level or to add fluid.
On transmission pan drain plug will have a small hex screw in the center of drain plug, with engine running and in park remove little center screw, if fluid comes out, transmission level is good, of no fluid come out, will have to pump fluid in that same little plug hole, till fluid starts to come out.
Aug 05, 2010 | 2004 Ford Explorer
I cant figure out how to check my transmission oil on my 89 ford tempo,
Manual or automatic? If it is automatic it should have a dipstick (like the oil dipstick) that will let you check it. It will most likely be red and if I remember correctly on the passenger side of the car. If it is a manual checking your transmission isn't so easy. I've heard it said that your transmission fluid is supposed to be changed every 50,000 miles or so but if it is still red and you're not having problems with it you should leave it alone (in my experience changing it a lot of times will just cause problems). If it is manual the transmission has two plugs on the side of the transmission (passenger side if I remember correctly). They both have a square insert in the middle of them that is the perfect size for the end of a regular size socket wrench. The plug on top is the "fill plug" and the one below is the "drain plug". First you remove the drain plug and let the fluid drain completely and be sure to clean the plug before putting back in. It should be magnetic to collect metal shavings that have ground up in the transmission. Once the transmission has been drained and the drain plug inserted back in. Remove the "fill plug" and use a fluid transfer pump to pump the new  transmission fluid from your container up into your transmission. When fluid starts to overflow from the fill plug you know the transmission is full and you can now put the fill plug back in. Be sure to be clean and check for any leaks around the transmission. Hope this helps. Be sure to let me know how it goes and if you need some more help. I probably made the process of changing your transmission fluid seem complicated but it really isn't so don't worry. Good luck!
May 03, 2009 | Ford Tempo Cars & Trucks
Where is the transmission fluid drain plug for a 2000 Cougar
Your Ford has no drain plug, to change/drain the trans fluid u must remove the transmission pan, u may be able to lower fluid level with a fluid siphon pump (rated for oil) through the dipstick tube, harbor freight tools sells a pump for this purpose.
Mar 14, 2009 | 2000 Mercury Cougar
2004 jaguar x-type trans drain and fill
use a 1/2 inch ratchet to remove the drain/fill plug, stick your pinky in the hole, if you do not get any thing on your finger you need ot add. there is a second plug on the bottom for drainign.
Aug 30, 2008 | 2004 Jaguar X-Type
Where is transmission drain plug 2001 FRD Explorer Sport
2001 Ford Explorer,depending on the engine option,will have either a 4R70W or 5R55E model transmission.Neither trans has a drain or fill plug in the pan or case.Changing the fluid is achieved either by removing all the pan bolts,removing the pan and fluid,then reinstalling and adding fluid through the filler tube,or by a shop that has a total flush machine that usually hooks into the cooler lines.I also change the filter on both transmissions as part of the fluid service.The 4R70W trans has a gasket that is reuseable for the life of the vehicle.The 5R55E pan requires a new gasket if dropping the pan.
Jul 17, 2008 | 2001 Ford Explorer Sport
Garden Logo
187 people viewed this question
Top Ford Garden Experts
Dennis Key
Dennis Key
donald boissonneault
fordexpert
Are you a Ford Garden Expert? Answer questions, earn points and help others
